I am attempting to take the LowLatencyLogger from the SdFat library and separate it from the serial monitor. Ideally I would turn on my device, it would run for a specified time, covert to CSV, and then I would cycle power for the next run.
At line 394, I have changed it from
if (Serial.available()) {
closeFile = true;
to
if (logTime > 10000000) {
closeFile = true;
The code creates a bin file without any data.
Here is my setup and loop
void setup(void) {
if (ERROR_LED_PIN >= 0) {
pinMode(ERROR_LED_PIN, OUTPUT);
SerialUSB.begin(9600);
// Allow userSetup access to SPI bus.
pinMode(SD_CS_PIN, OUTPUT);
digitalWrite(SD_CS_PIN, HIGH);
// Setup sensors.
userSetup();
// Initialize at the highest speed supported by the board that is
// not over 50 MHz. Try a lower speed if SPI errors occur.
if (!sd.begin(SD_CS_PIN, SD_SCK_MHZ(50))) {
sd.initErrorPrint(&SerialUSB);
fatalBlink();
// Blink a Couple Times.
pinMode(LED_BUILTIN, OUTPUT);
for (int i = 1; i <= 5; i++) {
digitalWrite(LED_BUILTIN, HIGH); // turn the LED on (HIGH is the voltage level)
delay(1000); // wait for a second
digitalWrite(LED_BUILTIN, LOW); // turn the LED off by making the voltage LOW
logData();
binaryToCsv();
void loop(void) {
delay(250); // wait for a second
I think the issue has to do something with my if statement: if (micros() > 10000000) {
The program gets to the loop function if I run 10,000,000 micros, but it only takes about a second to get there. It doesn't run if I set it to 20,000,000.
void recordBinFile() {
const uint8_t QUEUE_DIM = BUFFER_BLOCK_COUNT + 1;
// Index of last queue location.
const uint8_t QUEUE_LAST = QUEUE_DIM - 1;
// Allocate extra buffer space.
block_t block[BUFFER_BLOCK_COUNT - 1];
block_t* curBlock = 0;
block_t* emptyStack[BUFFER_BLOCK_COUNT];
uint8_t emptyTop;
uint8_t minTop;
block_t* fullQueue[QUEUE_DIM];
uint8_t fullHead = 0;
uint8_t fullTail = 0;
// Use SdFat's internal buffer.
emptyStack[0] = (block_t*)sd.vol()->cacheClear();
if (emptyStack[0] == 0) {
error("cacheClear failed");
// Put rest of buffers on the empty stack.
for (int i = 1; i < BUFFER_BLOCK_COUNT; i++) {
emptyStack[i] = &block[i - 1];
emptyTop = BUFFER_BLOCK_COUNT;
minTop = BUFFER_BLOCK_COUNT;
// Start a multiple block write.
if (!sd.card()->writeStart(binFile.firstBlock())) {
error("writeStart failed");
SerialUSB.print(F("FreeStack: "));
SerialUSB.println(FreeStack());
SerialUSB.println(F("Logging - type any character to stop"));
bool closeFile = false;
uint32_t bn = 0;
uint32_t maxLatency = 0;
uint32_t overrun = 0;
uint32_t overrunTotal = 0;
uint32_t logTime = micros();
// uint32_t startTime = micros();
while(1) {
// Time for next data record.
logTime += LOG_INTERVAL_USEC;
// if (SerialUSB.available()) {
closeFile = true;
if (closeFile) {
if (curBlock != 0) {
// Put buffer in full queue.
fullQueue[fullHead] = curBlock;
fullHead = fullHead < QUEUE_LAST ? fullHead + 1 : 0;
curBlock = 0;
if (curBlock == 0 && emptyTop != 0) {
curBlock = emptyStack[--emptyTop];
if (emptyTop < minTop) {
minTop = emptyTop;
curBlock->count = 0;
curBlock->overrun = overrun;
overrun = 0;
if ((int32_t)(logTime - micros()) < 0) {
error("Rate too fast");
int32_t delta;
do {
delta = micros() - logTime;
} while (delta < 0);
if (curBlock == 0) {
overrun++;
overrunTotal++;
digitalWrite(ERROR_LED_PIN, HIGH);
#if ABORT_ON_OVERRUN
SerialUSB.println(F("Overrun abort"));
#endif // ABORT_ON_OVERRUN
#if USE_SHARED_SPI
sd.card()->spiStop();
#endif // USE_SHARED_SPI
acquireData(&curBlock->data[curBlock->count++]);
#if USE_SHARED_SPI
sd.card()->spiStart();
if (curBlock->count == DATA_DIM) {
curBlock = 0;
if (fullHead == fullTail) {
// Exit loop if done.
if (closeFile) {
} else if (!sd.card()->isBusy()) {
// Get address of block to write.
block_t* pBlock = fullQueue[fullTail];
fullTail = fullTail < QUEUE_LAST ? fullTail + 1 : 0;
// Write block to SD.
uint32_t usec = micros();
if (!sd.card()->writeData((uint8_t*)pBlock)) {
error("write data failed");
usec = micros() - usec;
if (usec > maxLatency) {
maxLatency = usec;
// Move block to empty queue.
emptyStack[emptyTop++] = pBlock;
bn++;
if (bn == FILE_BLOCK_COUNT) {
// File full so stop
if (!sd.card()->writeStop()) {
error("writeStop failed");
SerialUSB.print(F("Min Free buffers: "));
SerialUSB.println(minTop);
SerialUSB.print(F("Max block write usec: "));
SerialUSB.println(maxLatency);
SerialUSB.print(F("Overruns: "));
SerialUSB.println(overrunTotal);
// Truncate file if recording stopped early.
if (bn != FILE_BLOCK_COUNT) {
SerialUSB.println(F("Truncating file"));
if (!binFile.truncate(512L * bn)) {
error("Can't truncate file");
I have tested the following code and it does exit the while loop:
while(1){
if (micros() > 30000000) {
closeFile = true;
if (closeFile) {
delay(250);
If your timing is that long, switch to millis() and make you numbers smaller. You need to be aware of how large your constants are becoming. You can also mark them with 'UL' (e.g. 30000000UL) to make sure the compiler treats them as unsigned long values
