Salut a tous,
Je suis bloqué sur un problème que je ne comprends pas.
En fait je veux avoir la tension interne de l'Atmega en utilisant ce code:
const long InternalReferenceVoltage = 1124; // Adjust this value to your board's specific internal BG voltage
// Code courtesy of "Coding Badly" and "Retrolefty" from the Arduino forum
// results are Vcc * 100
// So for example, 5V would be 500.
int getBandgap ()
// REFS0 : Selects AVcc external reference
// MUX3 MUX2 MUX1 : Selects 1.1V (VBG)
//ADCSRA |= (1<<ADEN); //Enable ADC
ADMUX = bit (REFS0) | bit (MUX3) | bit (MUX2) | bit (MUX1);
ADCSRA |= bit( ADSC ); // start conversion
while (ADCSRA & bit (ADSC))
{ } // wait for conversion to complete
int result = (((InternalReferenceVoltage * 1024) / ADC) + 5) / 10;
return result;
} // end of getBandgap
Le souci que j'ai c'est que cumulé avec une mise en veille et un réveil par watchdog le convertisseur ADC me revoie n'importe quoi comme valeurs.
Le code complet est le suivant:
#include <avr/sleep.h>
#include <avr/wdt.h>
#include <avr/power.h>
const int LED = 13; //LED on pin 13
const unsigned long KEEP_RUNNING = 2000; //milliseconds
byte previousADCSRA;
byte previousADCSRA1;
// LOWPOWER FUNCTIONS
// watchdog intervals
// sleep bit patterns for WDTCSR
enum
WDT_16_MS = 0b000000,
WDT_32_MS = 0b000001,
WDT_64_MS = 0b000010,
WDT_128_MS = 0b000011,
WDT_256_MS = 0b000100,
WDT_512_MS = 0b000101,
WDT_1_SEC = 0b000110,
WDT_2_SEC = 0b000111,
WDT_4_SEC = 0b100000,
WDT_8_SEC = 0b100001,
}; // end of WDT intervals enum
// watchdog interrupt
ISR (WDT_vect)
wdt_disable(); // disable watchdog
void go_to_sleep_for (const byte sleep_time)
// clear various "reset" flags
MCUSR = 0;
// allow changes, disable reset
WDTCSR = bit (WDCE) | bit (WDE);
// set interrupt mode and an interval
WDTCSR = bit (WDIE) | sleep_time; // set WDIE, and delay
wdt_reset(); // pat the dog
set_sleep_mode (SLEEP_MODE_PWR_DOWN); // prepare for powerdown
sleep_enable();
// turn off brown-out enable in software
MCUCR = bit (BODS) | bit (BODSE);
MCUCR = bit (BODS);
Serial.println("BEFORE:");
Serial.print("ADCSRA=");
Serial.println(ADCSRA);
delay(20);
previousADCSRA = ADCSRA;
Serial.print("previousADCSRA=");
Serial.println(previousADCSRA);
delay(20);
ADCSRA &= ~(1<<ADEN); //Disable ADC
ACSR = (1<<ACD); //Disable the analog comparator
DIDR0 = 0x3F; //Disable digital input buffers on all ADC0-ADC5 pins
DIDR1 = (1<<AIN1D)|(1<<AIN0D); //Disable digital input buffer on AIN1/0
power_twi_disable();
power_spi_disable();
power_usart0_disable(); //Needed for serial.print
power_timer0_disable(); //Needed for delay and millis()
power_timer1_disable();
power_timer2_disable(); //Needed for asynchronous 32kHz operation
sleep_cpu (); // power down !
void wakeup() {
power_twi_enable();
power_spi_enable();
power_usart0_enable();
power_timer0_enable();
power_timer1_enable();
power_timer2_enable();
power_adc_enable();
ADCSRA = previousADCSRA;
Serial.println("AFTER:");
Serial.println(" ");
delay(20);
// BOD is automatically restarted at wakeup
void setup(void)
for (byte i=0; i<20; i++) { //make all pins inputs with pullups enabled
pinMode(i, INPUT_PULLUP);
digitalWrite(i, LOW);
pinMode(LED, OUTPUT); //make the led pin an output
digitalWrite(LED, LOW); //drive it low so it doesn't source current
// set analog reference voltage
analogReference(INTERNAL);
void loop(void)
Serial.println (getBandgap ());
delay(20);
delay(KEEP_RUNNING); //opportunity to measure active supply current
digitalWrite(LED, HIGH); //one blink before sleeping
delay(10);
go_to_sleep_for (WDT_8_SEC);
sleep_disable();
wakeup();
int getBandgap ()
return result;
L'ADCSRA renvoie des valeurs bidon et est perturbé par l'interogation "ADCSRA |= bit( ADSC ); // start conversion" ce qui fait que je n'ai pas les bonnes valeurs en sortie.
La mesure devrait renvoyer une valeur aux alentours des 500 (5v) alors que ça renvoi tantot des 200 ou des 330 etc...
Quelqu'un aurait une idée de ce qui se passe?
