LowPower noob question
Can someone help me on this low power library thing? I cant seems to understand which and where to put the correct code. I try follow the example sketch but it just wonk work, here is my full code without lowpower. I want it to sleep if no activity and wake after pin 2 is press.
static const unsigned char PROGMEM FLM [] = {
0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF,
0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x06, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x00, 0x03, 0xFE, 0x0E, 0x00, 0x00, 0x70, 0x03,
0xFE, 0x00, 0x00, 0x03, 0xFE, 0x0E, 0x00, 0x00, 0x70, 0x03, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x0C,
0x00, 0x00, 0x30, 0x00, 0x00, 0x00, 0x00, 0x02, 0x00, 0xDE, 0xFF, 0xFF, 0x7B, 0xF8, 0x00, 0xFC,
0x00, 0x03, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x03, 0x1F, 0xF0, 0x00, 0x00, 0x3F, 0xF8, 0x00, 0x00, 0x00, 0x03, 0x1F, 0xF0,
0x00, 0x01, 0xFF, 0xFB, 0x80, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xF9, 0xE0, 0x00,
0x00, 0x03, 0x00, 0x00, 0x00, 0x07, 0xFF, 0xF9, 0xF0, 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xFE, 0x13,
0xFF, 0xF9, 0xF8, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x3C, 0xFF, 0xFD, 0xFE, 0x00, 0x00, 0x03,
0x80, 0x00, 0x00, 0x7E, 0x3F, 0xFD, 0xFF, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0xFF, 0x9F, 0xFD,
0xFF, 0x00, 0x00, 0x03, 0x80, 0x00, 0x01, 0xFF, 0xC7, 0xFD, 0xFF, 0x80, 0x00, 0x03, 0x80, 0x00,
0x03, 0xFF, 0xF3, 0xFD, 0xFF, 0xC0, 0x00, 0x03, 0x80, 0x00, 0x03, 0xFF, 0xF8, 0xFC, 0xFF, 0xC0,
0x00, 0x03, 0x80, 0x00, 0x07, 0xFF, 0xFE, 0x7C, 0xFF, 0xE0, 0x00, 0x03, 0x80, 0x00, 0x07, 0xFF,
0xFE, 0x1C, 0xFF, 0xC0, 0x00, 0x03, 0x80, 0x00, 0x0F, 0xFF, 0xE0, 0x0C, 0xFF, 0x90, 0x00, 0x03,
0x80, 0x00, 0x0F, 0xFF, 0x00, 0x06, 0xFF, 0x30, 0x00, 0x03, 0x80, 0x00, 0x0F, 0xF8, 0x00, 0x00,
0xFE, 0x70, 0x00, 0x03, 0x80, 0x00, 0x0F, 0xC3, 0x80, 0x00, 0xFC, 0xF0, 0x00, 0x03, 0x80, 0x00,
0x1E, 0x1F, 0x00, 0x00, 0xF9, 0xF0, 0x00, 0x03, 0x80, 0x00, 0x10, 0xFF, 0x00, 0x00, 0xF3, 0xF8,
0x00, 0x03, 0x80, 0x00, 0x03, 0xFF, 0x00, 0x00, 0xE7, 0xF8, 0x00, 0x03, 0x80, 0x00, 0x1F, 0xFE,
0x00, 0x00, 0xCF, 0xF8, 0x00, 0x03, 0x80, 0x00, 0x1F, 0xFE, 0x00, 0x00, 0x9F, 0xF8, 0x00, 0x03,
0x80, 0x00, 0x1F, 0xFC, 0x00, 0x00, 0x3F, 0xF8, 0x00, 0x03, 0x80, 0x00, 0x1F, 0xFD, 0x00, 0x00,
0x7F, 0xF0, 0x00, 0x03, 0x80, 0x00, 0x1F, 0xFD, 0x80, 0x00, 0xFF, 0xF0, 0x00, 0x03, 0x80, 0x00,
0x0F, 0xF9, 0x80, 0x01, 0xFF, 0xF0, 0x00, 0x03, 0x80, 0x00, 0x0F, 0xFB, 0xC0, 0x03, 0xFF, 0xF0,
0x00, 0x03, 0x80, 0x00, 0x0F, 0xF3, 0xC0, 0x0F, 0xFF, 0xF0, 0x00, 0x03, 0x80, 0x00, 0x07, 0xF3,
0xE0, 0x03, 0xFF, 0xE0, 0x00, 0x03, 0x80, 0x00, 0x07, 0xF7, 0xF7, 0xE0, 0x01, 0xE0, 0x00, 0x03,
0x80, 0x00, 0x07, 0xE7, 0xF3, 0xFF, 0xE0, 0x00, 0x00, 0x03, 0x80, 0x00, 0x03, 0xE7, 0xFB, 0xFF,
0xFF, 0xC0, 0x5C, 0x03, 0x80, 0x00, 0x01, 0xEF, 0xF9, 0xFF, 0xFF, 0x80, 0x3E, 0x03, 0x80, 0x00,
0x01, 0xCF, 0xFC, 0xFF, 0xFF, 0x80, 0x3E, 0x03, 0x80, 0x00, 0x00, 0xCF, 0xFE, 0xFF, 0xFF, 0x00,
0x3C, 0x03, 0x80, 0x00, 0x00, 0x5F, 0xFE, 0x7F, 0xFE, 0x00, 0x18, 0x03, 0x80, 0x00, 0x00, 0x1F,
0xFF, 0x3F, 0xFC, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x1F, 0xFF, 0x3F, 0xF8, 0x00, 0x00, 0x03,
0x80, 0x00, 0x00, 0x07, 0xFF, 0x9F, 0xE0, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x01, 0xFF, 0xCF,
0x80, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x7F, 0xCE, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00,
0x00, 0x00, 0x03, 0xE0, 0x00, 0x00, 0x00, 0x03, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x03, 0x80, 0x07, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x80, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x80, 0x00, 0x00, 0x3E, 0xCC, 0xF9,
0x99, 0xF0, 0x20, 0xE7, 0x80, 0x00, 0x00, 0x30, 0x58, 0x89, 0x9B, 0x10, 0x20, 0xE7, 0xFF, 0xFF,
0xFE, 0x30, 0x70, 0x99, 0x9B, 0x00, 0x20, 0xEF, 0xFF, 0xFF, 0xFE, 0x3C, 0x30, 0xF1, 0x99, 0xF0,
0x20, 0xBB, 0x00, 0x00, 0x00, 0x30, 0x30, 0xB1, 0x98, 0x10, 0x20, 0x9B, 0x00, 0x00, 0x00, 0x30,
0x30, 0x99, 0x9B, 0x30, 0x30, 0xDB, 0x00, 0x00, 0x00, 0x30, 0x30, 0x98, 0xF1, 0xE0, 0x3C, 0xD3 };
static const unsigned char PROGMEM _full [] =
{ 0x7F, 0xE0, 0x40, 0x20, 0x5F, 0xB8, 0x5F, 0xB8, 0x5F, 0xB8, 0x5F, 0xB8, 0x40, 0x20, 0x7F, 0xE0 };
static const unsigned char PROGMEM _threequarters [] =
{ 0x7F, 0xE0, 0x40, 0x20, 0x5C, 0x38, 0x5E, 0x38, 0x5E, 0x38, 0x5F, 0x38, 0x40, 0x20, 0x7F, 0xE0 };
static const unsigned char PROGMEM _half [] =
{ 0x7F, 0xE0, 0x40, 0x20, 0x58, 0x38, 0x58, 0x38, 0x5C, 0x38, 0x5C, 0x38, 0x40, 0x20, 0x7F, 0xE0 };
static const unsigned char PROGMEM _low [] =
{ 0x7F, 0xE0, 0x40, 0x20, 0x50, 0x38, 0x50, 0x38, 0x50, 0x38, 0x50, 0x38, 0x40, 0x20, 0x7F, 0xE0 };
static const unsigned char PROGMEM _empty [] =
{ 0x7F, 0xE0, 0x40, 0x20, 0x40, 0x38, 0x40, 0x38, 0x40, 0x38, 0x40, 0x38, 0x40, 0x20, 0x7F, 0xE0 };
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#include <BH1750.h>
#include <Adafruit_TCS34725.h>
#include <EEPROM.h>
#include <Battery.h>
// REPLACE 1 //////////////////////////////
/* 4 Pin Oled display
 * VCC -> 3.3V
 * GND -> GND
 * SDA -> pin A4
 * SCL -> pin A5
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
// END REPLACE 1 //////////////////////////
BH1750 lightMeter;
uint8_t Rp = 2;                           // Metering button pin
uint8_t Bn1p = 3;                         // + increment button pin
uint8_t Bn2p = 4;                         // - increment button pin
#define DomeMultiplier          2.17      // define 1.0 if no white translucide Dome on the sensor.
#define MaxISOIndex             57
#define MaxApertureIndex        27        // max 70 (default f1.0 ~ f22.0) editable
#define MaxTimeIndex            80
#define MaxFlashMeteringTime    3000      // flash metering in milisecond (default 3 seconds)
/* CONSTANT FOR WHITE BALANCE /////// */
#define TCS34725_R_Coef         0.136
#define TCS34725_G_Coef         1.000
#define TCS34725_B_Coef         -0.444
#define TCS34725_GA             1.0
#define TCS34725_DF             310.0
#define TCS34725_CT_Coef        3810.0
#define TCS34725_CT_Offset      1391.0
//#define C_const 129
float   lux;                              // Lux value from BH1750
float   ct;                               // Color Temp value from TCS34725
boolean Overflow = 0;                     // Sensor got Saturated and Display "Overflow"
float   ISOND;
boolean ISOmode = 0;
boolean Bn1;                              // + increment button state
boolean Bn2;                              // - increment button state
boolean R;                                // Metering button state
boolean mainScreen = false;
boolean ISOset = false;
// EEPROM for memory recording
#define ISOIndexAddr           1
#define apertureIndexAddr      2
#define modeIndexAddr          3
#define T_expIndexAddr         4
#define meteringModeAddr       5
#define ndIndexAddr            6
#define defaultApertureIndex   12
#define defaultISOIndex        11
#define defaultModeIndex       0
#define defaultT_expIndex      19
uint8_t ISOIndex =          EEPROM.read(ISOIndexAddr);
uint8_t apertureIndex =     EEPROM.read(apertureIndexAddr);
uint8_t T_expIndex =        EEPROM.read(T_expIndexAddr);
uint8_t modeIndex =         EEPROM.read(modeIndexAddr);
uint8_t meteringMode =      EEPROM.read(meteringModeAddr);
uint8_t ndIndex =           EEPROM.read(ndIndexAddr);
Battery battery(3000, 4200, A0);  // MinVoltage / MaxVoltage / BattPin
class ColorSensor {
    public:
    void getColorTemp();
    uint16_t r, g, b, c, ir;
    uint16_t ct, lux, r_comp, g_comp, b_comp;
    float cpl;
} rgb_sensor;
void ColorSensor::getColorTemp() {
    Adafruit_TCS34725 tcs = Adafruit_TCS34725(TCS34725_INTEGRATIONTIME_101MS, TCS34725_GAIN_1X);
    tcs.getRawData(&r, &g, &b, &c);
    //lux = tcs.calculateLux(r, g, b);
    // DN40 calculations
    ir = (r + g + b > c) ? (r + g + b - c) / 2 : 0;
    r_comp = r - ir;
    g_comp = g - ir;
    b_comp = b - ir;
    //c_comp = c - ir;
    cpl = (700) / (TCS34725_GA * TCS34725_DF);
    lux = (TCS34725_R_Coef * float(r_comp) + TCS34725_G_Coef * float(g_comp) + TCS34725_B_Coef * float(b_comp)) / cpl;
    ct = TCS34725_CT_Coef * float(b_comp) / float(r_comp) + TCS34725_CT_Offset;
    //ct = ct*DomeSum;
  pinMode(Bn1p, INPUT_PULLUP);
  pinMode(Bn2p, INPUT_PULLUP);
  pinMode(Rp, INPUT_PULLUP);
  battery.begin(5000, 1.0);
  Wire.begin();
  lightMeter.begin(BH1750::ONE_TIME_HIGH_RES_MODE_2);
  //lightMeter.begin(BH1750::ONE_TIME_LOW_RES_MODE); // for low resolution but 16ms light measurement time.
// REPLACE 2 ////////////////////////////////
/* 4 pin 0.96 Oled Display */
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
// END REPLACE 2 ////////////////////////////
  display.clearDisplay();
  display.drawBitmap(24, 0, FLM, 80, 64, 1);
  display.display();
  delay(3000);
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setCursor(40, 1);
  display.println("FYRUS LM");
  display.drawLine(31, 12, 95, 12, WHITE);
  display.drawLine(31, 51, 95, 51, WHITE);
  if (battery.level() > 80 && battery.level() < 100) {
    display.drawBitmap(44, 22, _full, 16, 8, WHITE);
  } else if (battery.level() > 60 && battery.level() < 80) {
    display.drawBitmap(44, 22, _threequarters, 16, 8, WHITE);
  } else if (battery.level() > 40 && battery.level() < 60) {
    display.drawBitmap(44, 22, _half, 16, 8, WHITE);
  } else if (battery.level() > 20 && battery.level() < 40) {
    display.drawBitmap(44, 22, _low, 16, 8, WHITE);
    display.setCursor(29, 29);
     display.print(F("Low Battery!"));
    display.setCursor(31 ,57);
     display.println("NEED CHARGE");
if (battery.level() > 20 && battery.level() < 100) {
  display.setCursor(61, 22);
   display.print(battery.level());
    display.println(F("%"));
  display.setCursor(45, 34);
   display.print(battery.voltage());
    display.print(F("mV"));
  display.setCursor(25, 57);
   display.println("<<< READY >>>");
  display.display();
  delay(2000);
  // IF NO MEMORY WAS RECORDED BEFORE, START WITH THIS VALUES otherwise it will read "255"
  if (apertureIndex > MaxApertureIndex) {
    apertureIndex = defaultApertureIndex;
  if (ISOIndex > MaxISOIndex) {
    ISOIndex = defaultISOIndex;
  if (T_expIndex > MaxTimeIndex) {
    T_expIndex = defaultT_expIndex;
  if (modeIndex < 0 || modeIndex > 1) {
    // Aperture priority. Calculating shutter speed.
    modeIndex = 0;
  if (meteringMode > 1) {
    meteringMode = 0;
  lux = getLux();                      // get Lux reading from BH1750
  rgb_sensor.getColorTemp();           // get White Balance Value from TCS34725
  readAll();
  menu();
  if (!R) {
    // Save setting if Metering button pressed.
    SaveSettings();
    lux = 0;
    refresh();
    if (meteringMode == 0) {
      // Ambient light meter mode.
      lightMeter.configure(BH1750::ONE_TIME_HIGH_RES_MODE_2);
      lux = getLux();
      if (Overflow == 1) {
        delay(10);
        getLux();
      refresh();
      delay(200);
    } else if (meteringMode == 1) {
      // Flash light metering
      lightMeter.configure(BH1750::CONTINUOUS_LOW_RES_MODE);
      unsigned long startTime = millis();
      uint16_t currentLux = 0;
      lux = 0;
      while (true) {
        // check max flash metering time
        if (startTime + MaxFlashMeteringTime < millis()) {
        currentLux = getLux();
        delay(16);
        if (currentLux > lux) {
          lux = currentLux;
      refresh();
void outOfrange() {
  display.println(F("--"));
void SaveSettings() {
  // Save lightmeter setting into EEPROM.
  EEPROM.write(ndIndexAddr, ndIndex);
  EEPROM.write(ISOIndexAddr, ISOIndex);
  EEPROM.write(modeIndexAddr, modeIndex);
  EEPROM.write(apertureIndexAddr, apertureIndex);
  EEPROM.write(T_expIndexAddr, T_expIndex);
  EEPROM.write(meteringModeAddr, meteringMode);
void footer() {
  Get light value
float getLux() {
  uint16_t lux = lightMeter.readLightLevel();
  if (lux >= 65534) {
    // light sensor is overloaded.
    Overflow = 1;
    lux = 65535;
    Overflow = 0;
  return lux * DomeMultiplier;        // DomeMultiplier = 2.17 (calibration)*/
float log2(float x) {
  return log(x) / log(2);
float lux2ev(float lux) {
  return log2(lux / 2.5);
// return aperture value (1.4, 1.8, 2.0) by index in sequence (0, 1, 2, 3, ...).
float getApertureByIndex(uint8_t indx) {
  float roundIndx = 10.0;
  if (indx > 39) {
    roundIndx = 1;
  float f = round(pow(2, indx / 3.0 * 0.5) * roundIndx) / roundIndx;
// the formula returns exact value, but photographers uses more memorable values.
// convert it.
  if (f >= 1.1 && f < 1.2) {
    f = 1.1;
  } else if (f >= 1.2 && f < 1.4) {
    f = 1.2;
  } else if (f > 3.2 && f < 4) {
    f = 3.5;
  } else if (f > 5 && f < 6.3) {
    f = 5.6;
  } else if (f > 10 && f < 11) {
    f = 10;
  } else if (f >= 11 && f < 12) {
    f = 11;
  } else if (f >= 12 && f < 14) {
    f = 13;
  } else if (f >= 14 && f < 16) {
    f = 14;
  } else if (f >= 20 && f < 22) {
    f = 20;
  } else if (f >= 22 && f < 25) {
    f = 22;
  } else if (f >= 24 && f < 28) {
    f = 25;
  } else if (f >= 28 && f < 40) {
    f = 36;
  } else if (f >= 40 && f < 45) {
    f = 40;
  } else if (f >= 45 && f < 50) {
    f = 45;
  } else if (f >= 50 && f < 57) {
    f = 51;
  } else if (f >= 71 && f < 80) {
    f = 72;
  } else if (f >= 80 && f < 90) {
    f = 80;
  } else if (f >= 90 && f < 101) {
    f = 90;
  return f;
// Return ISO value (100, 200, 400, ...) by index in sequence (0, 1, 2, 3, ...).
long getISOByIndex(uint8_t indx) {
  if (indx < 0 || indx > MaxISOIndex) {
    indx = 0;
  indx += 10;
//  float iso = pow(10, (indx - 1) / 10.0);
//  iso = (long)(round(iso / 10.0) * 10);
  long int factor = 1;
  float iso = 0;
  if (indx > 60) {
    indx -= 50;
    factor = 100000;
  } else if (indx > 50) {
    indx -= 40;
    factor = 10000;
  } else if (indx > 40) {
    indx -= 30;
    factor = 1000;
  } else if (indx > 30) {
    indx -= 20;
    factor = 100;
  } else if (indx > 20) {
    indx -= 10;
    factor = 10;
  if (indx == 10) {
    iso = 8;
  } else if (indx == 11) {
    iso = 10;
  } else if (indx == 12) {
    iso = 12.5;
  } else if (indx == 13) {
    iso = 16;
  } else if (indx == 14) {
    iso = 20;
  } else if (indx == 15) {
    iso = 25;
  } else if (indx == 16) {
    iso = 32;
  } else if (indx == 17) {
    iso = 40;
  } else if (indx == 18) {
    iso = 50;
  } else if (indx == 19) {
    iso = 64;
  } else if (indx == 20) {
    iso = 80;
  iso = (long)floor(iso * factor);
  return iso;
float getMinDistance(float x, float v1, float v2) {
  if (x - v1 > v2 - x) {
    return v2;
  return v1;
float getTimeByIndex(uint8_t indx) {
  if (indx < 0 || indx >= MaxTimeIndex) {
    indx = 0;
  float factor = 0;
  float t = 0;
  if (indx < 10) {
    factor = 100.0;
  } else if (indx < 20) {
    indx -= 10;
    factor = 10.0;
  } else if (indx < 30) {
    indx -= 20;
    factor = 1.0;
  } else if (indx < 40) {
    indx -= 30;
    factor = 0.1;
  } else if (indx < 50) {
    indx -= 40;
    factor = 0.01;
  } else if (indx < 60) {
    indx -= 50;
    factor = 0.001;
  } else if (indx < 70) {
    indx -= 60;
    factor = 0.0001;
  } else if (indx < 80) {
    indx -= 70;
    factor = 0.00001;
  if (indx == 0) {
    t = 100;
  } else if (indx == 1) {
    t = 80;
  } else if (indx == 2) {
    t = 64;
  } else if (indx == 3) {
    t = 50;
  } else if (indx == 4) {
    t = 40;
  } else if (indx == 5) {
    t = 32;
  } else if (indx == 6) {
    t = 25;
  } else if (indx == 7) {
    t = 20;
  } else if (indx == 8) {
    t = 16;
  } else if (indx == 9) {
    t = 12.5;
  t = 1 / (t * factor);
  return t;
// Convert calculated time (in seconds) to photograpy style shutter speed.
double fixTime(double t) {
  double divider = 1;
  float maxTime = getTimeByIndex(MaxTimeIndex);
  if (t < maxTime) {
    return maxTime;
  t = 1 / t;
  if (t > 99999) {
    divider = 10000;
  } else if (t > 9999) {
    divider = 1000;
  } else if (t > 999) {
    divider = 100;
  } else if (t > 99) {
    divider = 10;
  t = t / divider;
  if (t >= 10 && t <= 12.5) {
    t = getMinDistance(t, 10, 12.5);
  } else if (t >= 12.5 && t <= 16) {
    t = getMinDistance(t, 12.5, 16);
  } else if (t >= 16 && t <= 20) {
    t = getMinDistance(t, 16, 20);
  } else if (t >= 20 && t <= 25) {
    t = getMinDistance(t, 20, 25);
  } else if (t >= 25 && t <= 32) {
    t = getMinDistance(t, 25, 32);
  } else if (t >= 32 && t <= 40) {
    t = getMinDistance(t, 32, 40);
  } else if (t >= 40 && t <= 50) {
    t = getMinDistance(t, 40, 50);
  } else if (t >= 50 && t <= 64) {
    t = getMinDistance(t, 50, 64);
  } else if (t >= 64 && t <= 80) {
    t = getMinDistance(t, 64, 80);
  } else if (t >= 80 && t <= 100) {
    t = getMinDistance(t, 80, 100);
  t = t * divider;
  if (t == 32) {
    t = 30;
  if (t == 16) {
    t = 15;
  t = 1 / t;
  return t;
// Convert calculated aperture value to photograpy style aperture value.
float fixAperture(float a) {
  for (int i = 0; i < MaxApertureIndex; i++) {
    float a1 = getApertureByIndex(i);
    float a2 = getApertureByIndex(i + 1);
    if (a1 < a && a2 >= a) {
      return getMinDistance(a, a1, a2);
  return 0;
  Return ND from ndIndex
  int ND[] = {0, 3, 6, 9, 12, 15, 18, 21, 24, 27, 30, 33, 36, 39, 42, 45, 48}; // eg.: 1) 0.3 ND = -1 stop = 2^2 = 4; 2) 0.9 ND = -3 stop = 2^3 = 16;
uint8_t getND(uint8_t ndIndex) {
  if (ndIndex == 0) {
    return 0;
  return 3 + (ndIndex - 1) * 3;
// Calculate new exposure value and display it.
void refresh() {
  ISOset = false;
  mainScreen = true;
  float EV = lux2ev(lux);
  float T = getTimeByIndex(T_expIndex);
  float A = getApertureByIndex(apertureIndex);
  long  iso = getISOByIndex(ISOIndex);
  uint8_t ndStop = getND(ndIndex);
  // if ND filter is configured then make corrections.
  // As ISO is a main operand in all EV calculations we can adjust ISO by ND filter factor.
  // if ND4 (ND 0.6) filter is configured then we need to adjust ISO to -2 full stops. Ex. 800 to 200
  if (ndIndex > 0) {
    ISOND = iso / (pow(2, ndIndex));
    ISOND = iso;
  if (lux > 0) {
    if (modeIndex == 0) {
      // Aperture priority. Calculating time.
      T = fixTime(100 * pow(A, 2) / ISOND / pow(2, EV)); //T = exposure time, in seconds
      // Calculating shutter speed index for correct menu navigation.
      for (int i = 0; i <= MaxTimeIndex; i++) {
        if (T == getTimeByIndex(i)) {
          T_expIndex = i;
    } else if (modeIndex == 1) {
      // Shutter speed priority. Calculating aperture.
      A = fixAperture(sqrt(pow(2, EV) * ISOND * T / 100));
      // Calculating aperture index for correct menu navigation.
      if (A > 0) {
        for (int i = 0; i <= MaxApertureIndex; i++) {
          if (A == getApertureByIndex(i)) {
            apertureIndex = i;
      T = 0;
      A = 0;
  uint8_t Tdisplay = 0; // Flag for shutter speed display style (fractional, seconds, minutes)
  double  Tfr = 0;
  float   Tmin = 0;
  if (T >= 60) {
    Tdisplay = 0;  // Exposure is in minutes
    Tmin = T / 60;
  } else if (T < 60 && T >= 0.5) {
    Tdisplay = 2;  // Exposure in in seconds
  } else if (T < 0.5) {
    Tdisplay = 1;  // Exposure is in fractional form
    Tfr = round(1 / T);
/* /////// DISPLAY /////// */
  uint8_t linePos[] = {17, 37};
/* APERTURE DISPLAY /////// */
  display.setCursor(0, 1);
  display.print(F("f/"));
  display.setCursor(13, 1);
  display.setTextSize(3);
  if (A > 0) {
    if (A >= 100) {
      display.print(A, 0);
      display.print(A, 1);
    outOfrange();
/* SHUTTER DISPLAY /////// */
    display.setTextSize(2);
    display.setCursor(0, 38);
  if (Tdisplay == 0) {
    display.print(Tmin, 1);
    display.print(F("m"));
  } else if (Tdisplay == 1) {
    if (T > 0) {
      display.print(F("1/"));
      display.print(Tfr, 0);
      outOfrange();
  } else if (Tdisplay == 2) {
    display.print(T, 1);
    display.print(F("s"));
  } else if (Tdisplay == 3) {
    outOfrange();
/* DEFINE SAME TEXT SIZE & COLOR BELOW THIS RANGE /////// */
/* PRIORITY MARKING (Aperture/Shutter) /////// */
    // Aperture mode
    display.setCursor(36, 26);
    display.print(F("Aperture"));
    display.drawLine(0, 26, 26, 26, WHITE);
    display.drawLine(26, 26, 32, 32, WHITE);
    // Shutter mode
    display.setCursor(0, 26);
    display.print(F("Shutter"));
    display.drawLine(50, 32, 82, 32, WHITE);
    display.drawLine(44, 26, 50, 32, WHITE);
/* METERING MODE DISPLAY (SWITCHING AMBIENT/FLASH) /////// */
    display.setCursor(50, 57);
    display.print(F("+FLASH"));
/*  LINE DIVISOR  /////// */
   display.drawLine(91, 28, 91, 52, WHITE);
/* BATTERY PERCENTAGE /////// */
    display.drawBitmap(89, 56, _full, 16, 8, WHITE);
    display.drawBitmap(89, 56, _threequarters, 16, 8, WHITE);
    display.drawBitmap(89, 56, _half, 16, 8, WHITE);
    display.drawBitmap(89, 56, _low, 16, 8, WHITE);
    display.drawBitmap(89, 56, _empty, 16, 8, WHITE);
  display.setCursor(104, 57);
  display.setCursor(96, 47);
  display.print(battery.voltage() / 1000.0, 1);
  display.print(F("v"));
/* WHITE BALANCE DISPLAY /////// */
   display.drawRect(91, 1, 37, 25, WHITE);
   display.setCursor(98, 5);
   display.print(F("TEMP"));
  if (rgb_sensor.ct > 9999) {
    display.setCursor(101, 15);
    display.print(rgb_sensor.ct / 1000.0, 0);
    display.setCursor(98, 15);
    display.print(rgb_sensor.ct / 1000.0, 1);
 }  display.print(F("K"));
/* LUX DISPLAY ///////
  display.setCursor(90, 27);
  display.print(lux, 0);
  display.print(F("lx")); */
/* EV DISPLAY /////// */
  display.setCursor(96, 33);
  display.print(F("EV:"));
  if (lux > 0) {
    display.println(EV, 0);
    display.println(0, 0);
/* ISO DISPLAY /////// */
  display.setCursor(0, 57);
  display.print(F("ISO:"));
  if (iso > 999999) {
    display.print(iso / 1000000.0, 2);
    display.print(F("M"));
  } else if (iso > 9999) {
    display.print(iso / 1000.0, 0);
    display.print(iso);
  display.display();
void showISOset() {
  ISOset = true;
  mainScreen = false;
/* ISO MENU /////// */
  display.setCursor(47, 1);
  display.println(F("ISO"));
  display.setCursor(44, 18);
  display.println(F("SETTING"));
  if (iso > 999999) {
    display.setCursor(0, 35);
  } else if (iso > 99999) {
    display.setCursor(10, 35);
    display.setCursor(20, 35);
  } else if (iso > 999) {
    display.setCursor(30, 35);
  } else if (iso > 99) {
    display.setCursor(40, 35);
    display.setCursor(50, 35);
  display.print(iso);
  display.display();
  delay(200);
/* /////// FUNCTION /////// */
void menu() {
  if (!Bn1 && !Bn2) {
    if (mainScreen) {
      showISOset();
      refresh();
      delay(200);
  if (ISOset) {
    // ISO change mode
    if (!Bn1) {
      // increase ISO
      ISOIndex++;
        ISOIndex = 0;
    } else if (!Bn2) {
      if (ISOIndex > 0) {
        ISOIndex--;
        ISOIndex = MaxISOIndex;
    if (!Bn1 || !Bn2) {
      showISOset();
  if (!R && !Bn1) {
    // switching between Aperture priority and Shutter Speed priority.
    if (mainScreen) {
      modeIndex++;
      if (modeIndex > 1) {
        modeIndex = 0;
    refresh();
    delay(200);
  if (mainScreen && !R && !Bn2) {
    // Switch between Ambient light and Flash light metering
      meteringMode = 1;
      meteringMode = 0;
    refresh();
    delay(200);
  if (mainScreen && (!Bn1 || !Bn2)) {
      // Aperture priority mode
      if (!Bn1) {
        // Increase aperture.
        apertureIndex++;
          apertureIndex = 0;
      } else if (!Bn2) {
        // Decrease aperture
        if (apertureIndex > 0) {
          apertureIndex--;
          apertureIndex = MaxApertureIndex;
      // Time priority mode
      if (!Bn1) {
        // increase time
        T_expIndex--;
          T_expIndex = 0;
      } else if (!Bn2) {
        // decrease time
        if (T_expIndex > 0) {
          T_expIndex++;
          T_expIndex = MaxTimeIndex;
    delay(200);
    refresh();
void readAll() {
    Bn1 = digitalRead(Bn1p);
    Bn2 = digitalRead(Bn2p);
    R = digitalRead(Rp);
What low power library thing? Nothing in your code about low power library that I could spot.
LowPower.h library, yes there is not in my sketch because i dont know which part to add
Take a look in the \examples folder of the library, there are examples there that show you how to use the library.
It's a long and complex sketch. I would imagine someone who could write a sketch like that would be able to, at least, attempt to add the low power library. But you don't feel able to attempt it. Is that because someone else wrote the sketch and you want to modify it?
Try many adjustment, all makes the button and screen just freeze
Post one of those attempts. Any one you like.
Also please get into the habit of answering questions asked of you, otherwise forum members will become annoyed and no longer wish to help you.
Topic closed at the request of @fyrus
