Arduino working code does not work teensy3.1 pin 11 pin 13 tied teensy3.1
TCCR1B |= clockSelectBits; // reset clock select register
I get an error
TCCR1B’ was not declared in this scope
teensy3.1 LPD6803 led for How do I find the code to work
please help
* A 'fork' of the adalight code, with a nice case statement.
* Tested with the LPD6803 50 led string
* should work with the WS2801 as well
#include "FastSPI_LED.h"
#define NUM_LEDS 110
* pin 11 -> blue for the LPD6803 'yellow' for the WS2801 string
* pin 13 -> green for the LPD6803 'green' for the WS2801 string
#define PIN 4
#define MODE_HDRA 0
#define MODE_HDRd 1
#define MODE_HDRa 2
#define MODE_HDRhi 3
#define MODE_HDRlo 4
#define MODE_HDRchk 5
#define MODE_DATAr 6
#define MODE_DATAg 7
#define MODE_DATAb 8
// Sometimes chipsets wire in a backwards sort of way
struct CRGB { unsigned char r; unsigned char b; unsigned char g; };
struct CRGB *leds;
unsigned long t,
startTime,
lastByteTime,
lastAckTime;
uint8_t hi, lo, chk,
mode = MODE_HDRA;
int channels,channel;
FastSPI_LED.setLeds(NUM_LEDS);
//Change this to match your led strip
FastSPI_LED.setChipset(CFastSPI_LED::SPI_LPD6803);
//FastSPI_LED.setChipset(CFastSPI_LED::SPI_TM1809);
//FastSPI_LED.setChipset(CFastSPI_LED::SPI_HL1606);
//FastSPI_LED.setChipset(CFastSPI_LED::SPI_595);
//FastSPI_LED.setChipset(CFastSPI_LED::SPI_WS2801);
FastSPI_LED.setPin(PIN);
//Change datarate to match your led strip as well
FastSPI_LED.setDataRate(3);
FastSPI_LED.init();
FastSPI_LED.start();
leds = (struct CRGB*)FastSPI_LED.getRGBData();
clearLeds();
Serial.print("Ada\n");
lastByteTime = startTime = lastAckTime = millis();
int readByte(){
while(Serial.available()==0){
//FastSPI_LED.stop();
//FastSPI_LED.start();
return Serial.read();
void clearLeds(){
memset(leds, 0, NUM_LEDS * 3);
FastSPI_LED.show();
delay(20);
void loop(){
int16_t c;
c = readByte();
t = millis();
if((t - lastAckTime) > 1000) {
Serial.print("Ada\n"); // Send ACK string to host
lastAckTime = t; // Reset counter
if ((t - lastByteTime) > 5000) {
mode = MODE_HDRA; // After 5 seconds reset to HDRA
lastByteTime = t;
lastAckTime = t;
switch(mode){
case MODE_HDRA:
if (c == 0x41) {
mode = MODE_HDRd;
case MODE_HDRd:
if (c == 0x64) {
mode = MODE_HDRa;
case MODE_HDRa:
if (c == 0x61) {
mode = MODE_HDRhi;
case MODE_HDRhi:
hi = c;
mode = MODE_HDRlo;
case MODE_HDRlo:
lo = c;
mode = MODE_HDRchk;
case MODE_HDRchk:
chk = c;
if (chk == (hi ^ lo ^ 0x55)){
mode = MODE_DATAr;
channels = (long)hi*256+(long)lo;
channel = 0;
// wrong checksum, reset header
mode = MODE_HDRA;
case MODE_DATAr:
// we are in the data business ;-)
// ignore all data for channels higher than NUM_LEDS
if (channel<NUM_LEDS) { leds[channel].r = c; }
mode = MODE_DATAb;
case MODE_DATAb:
if (channel<NUM_LEDS) { leds[channel].b = c; }
mode = MODE_DATAg;
case MODE_DATAg:
if (channel<NUM_LEDS) { leds[channel].g = c; }
channel++;
if (channel>channels) {
FastSPI_LED.show();
mode = MODE_HDRA;
mode = MODE_DATAr;
default:
// I should not be here, back to
mode = MODE_HDRA;
