LPH7366 Cellphone Display Board Success
I bought this little board a while ago through eBay but I could never get it to work.
I finally got serious and popped the display off the carrier to trace the circuits. I'm not sure if, in the end I did things much differently but I understood the pinouts and was able to use the PCD8544 software from the playground successfully. I'm just posting it here so people can see what a nice little display this is and maybe it will help someone else get going.
The connector pins at the top and bottom on this board are:
1 3.3V
2 ground
3 /CS active low chip select - I just have it grounded
4 /RES active low reset - i just have it tied to plus V
5 D/C data/command control line
6 SI serial data input (like MOSI)
7 SCK serial data clock
8 dims the backlights if pulled low
Here's a few more pics of the carrier board. The distinguishing point to me is that the LCD itself has a 9 pin connector rather than the alternative 8 pins. This site pcd8544 based displays (serdisplib) has an excellent description of the two LCD types.
The code from Arduino Playground - HomePage here worked great once I had figured out the pins.
Nice work! What about the back light? Is it controlled over SPI commands?
liudr:
the backlight is controlled separately from the screen contents. There are six very bright white leds permanently connected to +V and grounded through separate resistors to a common transistor at the bottom of the board. The transistor is connected to pin 8 such that if it's pulled to ground the leds are fairly bright but if pin 8 is left open or high the lights are VERY VERY bright. I cut the trace to the leds because they were just distracting and drew a lot of power.
I had also cut another trace that connected the leds to what i took to be bypass caps but they may have had some other function that would make the dimming more effective - too late now!
