i am using the LSM303 board from polo
I am using the lib. from the playground area for this board.
heres a bit of the code:
int LSM303DLH::heading(vector from)
// shift and scale
m.x = (m.x - m_min.x) / (m_max.x - m_min.x) * 2 - 1.0;
m.y = (m.y - m_min.y) / (m_max.y - m_min.y) * 2 - 1.0;
m.z = (m.z - m_min.z) / (m_max.z - m_min.z) * 2 - 1.0;
vector temp_a = a;
// normalize
vector_normalize(&temp_a);
//vector_normalize(&m);
// compute E and N
vector E;
vector N;
vector_cross(&m,&temp_a,&E);
vector_normalize(&E);
vector_cross(&temp_a,&E,&N);
// compute heading
int heading = round(atan2(vector_dot(&E,&from), vector_dot(&N,&from)) * 180/M_PI);
if(heading < 0) heading += 360;
return heading;
I am calibrating it to get the max and min values using this code:
void LSM303DLH::calibration(void)
int respond = 0;
Serial.println("Hit any key when ready to calibrate.");
//wait till R is pressed
while ( respond == 0)
while (Serial.available()==0);;
while (Serial.available()>0)
respond = Serial.read();
Serial.println("Rotate board until Min and Max values are reched for all axis.");
Serial.println("WHen calibration done press D...");
delay(3000);
while (respond != 100)
//Loop till D is pressed
read();
if (m.x > m_max.x)
m_max.x = m.x;
if (m.y > m_max.y)
m_max.y = m.y;
if (m.z > m_max.z)
m_max.z = m.z;
if (m.x < m_min.x)
m_min.x = m.x;
if (m.y < m_min.y)
m_min.y = m.y;
if (m.z < m_min.z)
m_min.z = m.z;
//Display results
Serial.print("Maxx: ");
Serial.print(m_max.x);
Serial.print(" MaxY: ");
Serial.print(m_max.y);
Serial.print(" MaxZ: ");
Serial.print(m_max.z);
Serial.print("Minx: ");
Serial.print(m_min.x);
Serial.print(" MinY: ");
Serial.print(m_min.y);
Serial.print(" MinZ:: ");
Serial.println(m_min.z);
//D pressed -> end loop
Serial.println("DONE");
delay(2000);
i am using a 10 as a sample rate for the readings at the moment
My issue is i get heading readings above 360 degrees…which doesn’t make sense.
any ideas?
