Hello,
how can I write the below code in Arduino?
* @file sensor_fusion.c
* @author Sensors Software Solution Team
* @brief This file how to configure compressed FIFO and to retrieve acc
* and gyro data. This sample use a fifo utility library tool
* for FIFO decompression.
* @attention
* <h2><center>© Copyright (c) 2020 STMicroelectronics.
* All rights reserved.</center></h2>
* This software component is licensed by ST under BSD 3-Clause license,
* the "License"; You may not use this file except in compliance with the
* License. You may obtain a copy of the License at:
* opensource.org/licenses/BSD-3-Clause
* This example was developed using the following STMicroelectronics
* evaluation boards:
* - STEVAL_MKI109V3 + STEVAL-MKI196V1
* - NUCLEO_F411RE + X_NUCLEO_IKS01A3
* - DISCOVERY_SPC584B + STEVAL-MKI196V1
* Used interfaces:
* STEVAL_MKI109V3 - Host side: USB (Virtual COM)
* - Sensor side: SPI(Default) / I2C(supported)
* NUCLEO_STM32F411RE - Host side: UART(COM) to USB bridge
* - I2C(Default) / SPI(supported)
* DISCOVERY_SPC584B - Host side: UART(COM) to USB bridge
* - Sensor side: I2C(Default) / SPI(supported)
* If you need to run this example on a different hardware platform a
* modification of the functions: `platform_write`, `platform_read`,
* `tx_com` and 'platform_init' is required.
/* STMicroelectronics evaluation boards definition
* Please uncomment ONLY the evaluation boards in use.
* If a different hardware is used please comment all
* following target board and redefine yours.
//#define STEVAL_MKI109V3 /* little endian */
//#define NUCLEO_F411RE /* little endian */
//#define SPC584B_DIS /* big endian */
/* ATTENTION: By default the driver is little endian. If you need switch
* to big endian please see "Endianness definitions" in the
* header file of the driver (_reg.h).
#if defined(STEVAL_MKI109V3)
/* MKI109V3: Define communication interface */
#define SENSOR_BUS hspi2
/* MKI109V3: Vdd and Vddio power supply values */
#define PWM_3V3 915
#elif defined(NUCLEO_F411RE)
/* NUCLEO_F411RE: Define communication interface */
#define SENSOR_BUS hi2c1
#elif defined(SPC584B_DIS)
/* DISCOVERY_SPC584B: Define communication interface */
#define SENSOR_BUS I2CD1
#endif
/* Includes ------------------------------------------------------------------*/
#include <string.h>
#include <stdio.h>
#include "lsm6dsv16x_reg.h"
#if defined(NUCLEO_F411RE)
#include "stm32f4xx_hal.h"
#include "usart.h"
#include "gpio.h"
#include "i2c.h"
#elif defined(STEVAL_MKI109V3)
#include "usbd_cdc_if.h"
#include "gpio.h"
#include "spi.h"
#include "tim.h"
#include "components.h"
#endif
/* Private macro -------------------------------------------------------------*/
* Select FIFO samples watermark, max value is 512
* in FIFO are stored acc, gyro and timestamp samples
#define BOOT_TIME 10
#define FIFO_WATERMARK 32
/* Private variables ---------------------------------------------------------*/
static uint8_t whoamI;
static uint8_t tx_buffer[1000];
static lsm6dsv16x_fifo_sflp_raw_t fifo_sflp;
/* Extern variables ----------------------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* WARNING:
* Functions declare in this section are defined at the end of this file
* and are strictly related to the hardware platform used.
static int32_t platform_write(void *handle, uint8_t reg, const uint8_t *bufp,
uint16_t len);
static int32_t platform_read(void *handle, uint8_t reg, uint8_t *bufp,
uint16_t len);
static void tx_com( uint8_t *tx_buffer, uint16_t len );
static void platform_delay(uint32_t ms);
static void platform_init(void);
* Original conversion routines taken from: https://github.com/numpy/numpy
* uint32_t npy_halfbits_to_floatbits(uint16_t h);
* float_t npy_half_to_float(uint16_t h);
* Released under BSD-3-Clause License
static uint32_t npy_halfbits_to_floatbits(uint16_t h)
uint16_t h_exp, h_sig;
uint32_t f_sgn, f_exp, f_sig;
h_exp = (h&0x7c00u);
f_sgn = ((uint32_t)h&0x8000u) << 16;
switch (h_exp) {
case 0x0000u: /* 0 or subnormal */
h_sig = (h&0x03ffu);
/* Signed zero */
if (h_sig == 0) {
return f_sgn;
/* Subnormal */
h_sig <<= 1;
while ((h_sig&0x0400u) == 0) {
h_sig <<= 1;
h_exp++;
f_exp = ((uint32_t)(127 - 15 - h_exp)) << 23;
f_sig = ((uint32_t)(h_sig&0x03ffu)) << 13;
return f_sgn + f_exp + f_sig;
case 0x7c00u: /* inf or NaN */
/* All-ones exponent and a copy of the significand */
return f_sgn + 0x7f800000u + (((uint32_t)(h&0x03ffu)) << 13);
default: /* normalized */
/* Just need to adjust the exponent and shift */
return f_sgn + (((uint32_t)(h&0x7fffu) + 0x1c000u) << 13);
static float_t npy_half_to_float(uint16_t h)
union { float_t ret; uint32_t retbits; } conv;
conv.retbits = npy_halfbits_to_floatbits(h);
return conv.ret;
static void sflp2q(float quat[4], uint16_t sflp[3])
float sumsq = 0;
quat[0] = npy_half_to_float(sflp[0]);
quat[1] = npy_half_to_float(sflp[1]);
quat[2] = npy_half_to_float(sflp[2]);
for (uint8_t i = 0; i < 3; i++)
sumsq += quat[i] * quat[i];
if (sumsq > 1.0f) {
float n = sqrtf(sumsq);
quat[0] /= n;
quat[1] /= n;
quat[2] /= n;
sumsq = 1.0f;
quat[3] = sqrtf(1.0f - sumsq);
/* Main Example --------------------------------------------------------------*/
void lsm6dsv16x_sensor_fusion(void)
lsm6dsv16x_fifo_status_t fifo_status;
stmdev_ctx_t dev_ctx;
lsm6dsv16x_reset_t rst;
lsm6dsv16x_sflp_gbias_t gbias;
/* Uncomment to configure INT 1 */
//lsm6dsv16x_pin_int1_route_t int1_route;
/* Uncomment to configure INT 2 */
//lsm6dsv16x_pin_int2_route_t int2_route;
/* Initialize mems driver interface */
dev_ctx.write_reg = platform_write;
dev_ctx.read_reg = platform_read;
dev_ctx.mdelay = platform_delay;
dev_ctx.handle = &SENSOR_BUS;
/* Init test platform */
platform_init();
/* Wait sensor boot time */
platform_delay(BOOT_TIME);
/* Check device ID */
lsm6dsv16x_device_id_get(&dev_ctx, &whoamI);
if (whoamI != LSM6DSV16X_ID)
while (1);
/* Restore default configuration */
lsm6dsv16x_reset_set(&dev_ctx, LSM6DSV16X_RESTORE_CTRL_REGS);
do {
lsm6dsv16x_reset_get(&dev_ctx, &rst);
} while (rst != LSM6DSV16X_READY);
/* Enable Block Data Update */
lsm6dsv16x_block_data_update_set(&dev_ctx, PROPERTY_ENABLE);
/* Set full scale */
lsm6dsv16x_xl_full_scale_set(&dev_ctx, LSM6DSV16X_4g);
lsm6dsv16x_gy_full_scale_set(&dev_ctx, LSM6DSV16X_2000dps);
* Set FIFO watermark (number of unread sensor data TAG + 6 bytes
* stored in FIFO) to FIFO_WATERMARK samples
lsm6dsv16x_fifo_watermark_set(&dev_ctx, FIFO_WATERMARK);
/* Set FIFO batch of sflp data */
fifo_sflp.game_rotation = 1;
fifo_sflp.gravity = 1;
fifo_sflp.gbias = 1;
lsm6dsv16x_fifo_sflp_batch_set(&dev_ctx, fifo_sflp);
/* Set FIFO mode to Stream mode (aka Continuous Mode) */
lsm6dsv16x_fifo_mode_set(&dev_ctx, LSM6DSV16X_STREAM_MODE);
/* Set Output Data Rate */
lsm6dsv16x_xl_data_rate_set(&dev_ctx, LSM6DSV16X_ODR_AT_30Hz);
lsm6dsv16x_gy_data_rate_set(&dev_ctx, LSM6DSV16X_ODR_AT_30Hz);
lsm6dsv16x_sflp_data_rate_set(&dev_ctx, LSM6DSV16X_SFLP_30Hz);
lsm6dsv16x_sflp_game_rotation_set(&dev_ctx, PROPERTY_ENABLE);
* here application may initialize offset with latest values
* calculated from previous run and saved to non volatile memory.
gbias.gbias_x = 0.0f;
gbias.gbias_y = 0.0f;
gbias.gbias_z = 0.0f;
lsm6dsv16x_sflp_game_gbias_set(&dev_ctx, &gbias);
/* Wait samples */
while (1) {
uint16_t num = 0;
/* Read watermark flag */
lsm6dsv16x_fifo_status_get(&dev_ctx, &fifo_status);
if (fifo_status.fifo_th == 1) {
num = fifo_status.fifo_level;
sprintf((char *)tx_buffer, "-- FIFO num %d \r\n", num);
tx_com(tx_buffer, strlen((char const *)tx_buffer));
while (num--) {
lsm6dsv16x_fifo_out_raw_t f_data;
int16_t *axis;
float quat[4];
float gravity_mg[3];
float gbias_mdps[3];
/* Read FIFO sensor value */
lsm6dsv16x_fifo_out_raw_get(&dev_ctx, &f_data);
switch (f_data.tag) {
case LSM6DSV16X_SFLP_GYROSCOPE_BIAS_TAG:
axis = (int16_t *)&f_data.data[0];
gbias_mdps[0] = lsm6dsv16x_from_fs125_to_mdps(axis[0]);
gbias_mdps[1] = lsm6dsv16x_from_fs125_to_mdps(axis[1]);
gbias_mdps[2] = lsm6dsv16x_from_fs125_to_mdps(axis[2]);
sprintf((char *)tx_buffer, "GBIAS [mdps]:%4.2f\t%4.2f\t%4.2f\r\n",
gbias_mdps[0], gbias_mdps[1], gbias_mdps[2]);
case LSM6DSV16X_SFLP_GRAVITY_VECTOR_TAG:
gravity_mg[0] = lsm6dsv16x_from_sflp_to_mg(axis[0]);
gravity_mg[1] = lsm6dsv16x_from_sflp_to_mg(axis[1]);
gravity_mg[2] = lsm6dsv16x_from_sflp_to_mg(axis[2]);
sprintf((char *)tx_buffer, "Gravity [mg]:%4.2f\t%4.2f\t%4.2f\r\n",
gravity_mg[0], gravity_mg[1], gravity_mg[2]);
case LSM6DSV16X_SFLP_GAME_ROTATION_VECTOR_TAG:
sflp2q(quat, (uint16_t *)&f_data.data[0]);
sprintf((char *)tx_buffer, "Game Rotation \tX: %2.3f\tY: %2.3f\tZ: %2.3f\tW: %2.3f\r\n",
quat[0], quat[1], quat[2], quat[3]);
default:
sprintf((char *)tx_buffer, "------ \r\n\r\n");
* @brief Write generic device register (platform dependent)
* @param handle customizable argument. In this examples is used in
* order to select the correct sensor bus handler.
* @param reg register to write
* @param bufp pointer to data to write in register reg
* @param len number of consecutive register to write
uint16_t len)
HAL_I2C_Mem_Write(handle, LSM6DSV16X_I2C_ADD_L, reg,
I2C_MEMADD_SIZE_8BIT, (uint8_t*) bufp, len, 1000);
HAL_GPIO_WritePin(CS_up_GPIO_Port, CS_up_Pin, GPIO_PIN_RESET);
HAL_SPI_Transmit(handle, ®, 1, 1000);
HAL_SPI_Transmit(handle, (uint8_t*) bufp, len, 1000);
HAL_GPIO_WritePin(CS_up_GPIO_Port, CS_up_Pin, GPIO_PIN_SET);
i2c_lld_write(handle, LSM6DSV16X_I2C_ADD_H & 0xFE, reg, (uint8_t*) bufp, len);
#endif
return 0;
* @brief Read generic device register (platform dependent)
* @param reg register to read
* @param bufp pointer to buffer that store the data read
* @param len number of consecutive register to read
uint16_t len)
HAL_I2C_Mem_Read(handle, LSM6DSV16X_I2C_ADD_L, reg,
I2C_MEMADD_SIZE_8BIT, bufp, len, 1000);
reg |= 0x80;
HAL_SPI_Receive(handle, bufp, len, 1000);
i2c_lld_read(handle, LSM6DSV16X_I2C_ADD_H & 0xFE, reg, bufp, len);
#endif
return 0;
* @brief Send buffer to console (platform dependent)
* @param tx_buffer buffer to transmit
* @param len number of byte to send
static void tx_com(uint8_t *tx_buffer, uint16_t len)
HAL_UART_Transmit(&huart2, tx_buffer, len, 1000);
CDC_Transmit_FS(tx_buffer, len);
sd_lld_write(&SD2, tx_buffer, len);
#endif
* @brief platform specific delay (platform dependent)
* @param ms delay in ms
#if defined(NUCLEO_F411RE) | defined(STEVAL_MKI109V3)
HAL_Delay(ms);
osalThreadDelayMilliseconds(ms);
#endif
* @brief platform specific initialization (platform dependent)
TIM3->CCR1 = PWM_3V3;
TIM3->CCR2 = PWM_3V3;
HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_1);
HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_2);
HAL_Delay(1000);
#endif
