Hi!
I want to make a vibration sensor with sdcard datalogger, using lt1609 adc.
Made a small program, to test the adc, it's works fine, can make 10000-15000 readings per second
#include<SPI.h>
int rcPin = 7;
int adcPin = 9;
int sdPin = 10;
int busy = 2;
int ledPin = 3;
unsigned long i=0;
byte LowByte,HighByte;
unsigned int adcValue = 0;
void setup(){
pinMode(ledPin,OUTPUT);
pinMode(adcPin,OUTPUT);
pinMode(sdPin, OUTPUT);
pinMode(rcPin, OUTPUT);
pinMode(busy,INPUT);
digitalWrite(adcPin,HIGH);
digitalWrite(sdPin,HIGH);
SPI.begin();
//SPI.setBitOrder(MSBFIRST);
//SPI.setClockDivider(SPI_CLOCK_DIV4);
//SPI.setDataMode(SPI_MODE0);
delay(100);
digitalWrite(adcPin,LOW);
digitalWrite(rcPin,HIGH);
delay(100);
Serial.println("start");
void loop(){
digitalWrite(rcPin,LOW);
while(!digitalRead(busy)){}
LowByte = SPI.transfer(0xFF);
HighByte = SPI.transfer(0xFF);
adcValue = HighByte * 256 + LowByte;
Serial.println(adcValue);
After this, modified the sd card example, to read the adc, and write the data to the sdcard, but now it's only make 2000-2500 readings per second. The sdcard is a 8Gb sandisk class10 card. What can I do, to make it faster?
#include <SPI.h>
#include <SdFat.h>
const uint8_t chipSelect = 10;
const uint32_t SAMPLE_INTERVAL_MS = 200;
#define FILE_BASE_NAME "Data"
SdFat sd;
SdFile file;
uint32_t logTime;
const uint8_t ANALOG_COUNT = 4;
void writeHeader() {
file.print(F("micros"));
for (uint8_t i = 0; i < ANALOG_COUNT; i++) {
file.print(F(",adc"));
file.print(i, DEC);
file.println();
#define error(msg) sd.errorHalt(F(msg))
unsigned long timer=0;
int rcPin = 7;
int adcPin = 9;
int sdPin = 10;
int busy = 2;
int ledPin = 3;
unsigned long i=0;
const uint8_t BASE_NAME_SIZE = sizeof(FILE_BASE_NAME) - 1;
char fileName[13] = FILE_BASE_NAME ".txt";
SPI.begin();
delay(100);
delay(100);
if (!sd.begin(chipSelect, SPI_HALF_SPEED)) {
sd.initErrorHalt();
if (BASE_NAME_SIZE > 6) {
error("FILE_BASE_NAME too long");
while (sd.exists(fileName)) {
if (fileName[BASE_NAME_SIZE + 1] != '9') {
fileName[BASE_NAME_SIZE + 1]++;
} else if (fileName[BASE_NAME_SIZE] != '9') {
fileName[BASE_NAME_SIZE + 1] = '0';
fileName[BASE_NAME_SIZE]++;
error("Can't create file name");
if (!file.open(fileName, O_CREAT | O_WRITE | O_EXCL)) {
error("file.open");
timer=millis();
file.println(adcValue);
if(millis()>timer+10000){
file.sync();
timer=millis();
