LTC 2448 SPI Issue
I have an LTC 2448 ADC connected to an Arduino UNO. I can read values from it on channel 0, although it appears to be in differential mode (which is the default on startup). I’m trying to figure out how to set the channel, but everything I’ve tried has no effect.
Here is the datasheet: http://cds.linear.com/docs/en/datasheet/2444589fb.pdf
And here is the code I’ve got so far:
  Interface between Arduino DM board and Linear Tech LTC2440 24-bit ADC
  Nov. 12 2010 John Beale
   LTC2440  <---------->  Arduino
   11: /CS <- to digital pin 10  (SS pin)
    7: MOSI <- to digital pin 11 (MOSI pin)
   12: MISO -> to digital pin 12 (MISO pin)
   13: SCLK <- to digital pin 13 (SCK pin)
   10: /EXT - ground
    1: GND - ground
    2: VDD3 - 5V supply
#include <SPI.h>  // include the SPI library
// set I/O pins used in addition to clock, data in, data out
const byte slaveSelectPin = 10;  // digital pin 10 for /CS
const byte resetPin = 9;  // digital pin 9 for /RESET
const int nsamples = 5;  // how many ADC readings to average together
// SPI_CLOCK_DIV16 gives me a 1.0 MHz SPI clock, with 16 MHz crystal on Arduino
    Serial.begin(115200);      // set up serial comm to PC at this baud rate
    pinMode (slaveSelectPin, OUTPUT);
    pinMode (resetPin, OUTPUT);
    digitalWrite(slaveSelectPin,HIGH);  // chip select is active low
    digitalWrite(resetPin,HIGH);  // reset is active low
    SPI.begin(); // initialize SPI, covering MOSI,MISO,SCK signals
    SPI.setBitOrder(MSBFIRST);  // data is clocked in MSB first
    SPI.setDataMode(SPI_MODE0);  // SCLK idle low (CPOL=0), MOSI read on rising edge (CPHI=0)
    SPI.setClockDivider(SPI_CLOCK_DIV16);  // system clock = 16 MHz, chip max = 1 MHz
    Serial.println("LTC2440 Test");
digitalWrite(slaveSelectPin, LOW);
SPI.transfer(0xb0);
SPI.transfer(0x00);
delay(10);
digitalWrite(slaveSelectPin, HIGH);
// Main Loop:
// acquire 'nsamples' readings, convert to units of volts, and send out on serial port
int i;
long secs;
float mins;
double volts;
long in;         // incoming serial 32-bit word
long sum = 0;
    for (i=0; i<nsamples; i++) {
      in = SpiRead();
      in &= 0x3FFFFFFF; // force high three bits to zero
     // in &= B
      in = in>>5;   // truncate lowest 5 bits
      sum += in;
      delay(198);      // (msec). Total Looptime: +2 msec (overhead for comms)
    // volts =  in * 2.5 / 8.388607;  // 0x7fffff = 8388607
    volts = sum * (0.2980232594);  // microvolts
    volts = volts / nsamples;
    mins = (float) millis() / 60000;   // elapsed time in minutes
    Serial.print(mins);
    Serial.print(", ");
    Serial.println(volts);
} // end main loop
// SpiRead() -- read out 4 bytes from LTC2440 chip via SPI interface
long SpiRead(void) {
  long result = 0;
  long b;
//  long result2 = 0;// MOSI/SDI pin 7 HIGH => 7 Hz, best resolution
  digitalWrite(slaveSelectPin,LOW);   // take the SS pin low to select the chip
  delayMicroseconds(1);              // probably not needed, only need 25 nsec delay
  //int c;
  //SPI.transfer(0xb0);
 // SPI.transfer(0x0);
  b = SPI.transfer(0xff);   // B3
  result = b<<8;
  b = SPI.transfer(0xff);   // B2
  result |= b;
  result = result<<8;
  b = SPI.transfer(0xff);   // B1
  result |= b;
  result = result<<8;
  b = SPI.transfer(0xff);   // B0
  result |= b;
  // take the SS pin high to de-select the chip:
  return(result);
Which is a slight modification of the code from here: http://dangerousprototypes.com/forum/viewtopic.php?f=2&t=4247&p=42053#p42051
I think I understand what commands to send, but I cannot seem to get them into the thing.
Any help or ideas would be greatly appreciated.
Thanks.
