Lua script with Log
Hi, i have a problem with my code
Hi, i have used Lua but i have a problem when i recive datas of serial then i want a log file.
first I write in the serial port and I collect the answer in Result. I want all Result in a file as a log.
This is my script. Thanks.
port= "/dev/tty/1"
serialout= io.open(port,"w")
serialin= io.open(port,"r")
while true do
	serialout:write("½".."@")
	Result= LeerSerial()
end
function LeerSerial()
		while true do
			serialData= serialin:read();serialin:flush()
			if string.len(serialData)>0 then
				serData = serialData
			end
			if  string.len(serialData) == 0 then
				return serData
			end
		end
end
That doesn't look much like Arduino code.
HI,
please if you post code, use [ code ] tags (without the spaces) . can be inserted with the # button above the smilies
check - Programming in Lua : 21.1 -
sorry, I modify my post. I know that this isnt arduino code but I want use Lua to control Arduino by one external router.
