Luci bug on http interface
Bad Gateway The process did not produce any response
Oups, what did i wrong ? the reload is long, and for some time i got this message. For example when i want to add a WIFI client connexion : BAD GATEWAY, no modifications on value are effectives.
if il look on the processes running : 8338 root 1648 S hostapd -P /var/run/wifi-phy0.pid -B /var/run/hostapd-phy0.conf
http://forum.arduino.cc/index.php?topic=221985.msg1657258#msg1657258
Thank you, so i must use Firefox.
Well still : Bad Gateway The process did not produce any response
EVEN ON LOGIN on the luci Web interface.
BUT
I think i have found an explanation .. I'm running a web Javascript script on a local page with refesh every N seconds .. if i close this page, everything seems to work correctly.
