Lunar Lander code
Re: http://forum.arduino.cc/index.php?topic=8688.0
   Serial.println("\t\t\t\t LUNAR");
   Serial.println("\t       CREATIVE COMPUTING MORRISTOWN, NEW JERSEY");
   Serial.println("\n\n");
   Serial.println("THIS IS A COMPUTER SIMULATION OF AN APOLLO LUNAR");
   Serial.println("LANDING CAPSULE.\n\n");
   Serial.println("THE ON-BOARD COMPUTER HAS FAILED (IT WAS MADE BY");
   Serial.println("XEROX) SO YOU HAVE TO LAND THE CAPSULE MANUALLY.");
float L, A, V, M, N, G, Z, K, T, S, W, I, J;
float input(char *p)
   int ans;
   byte n;
restart:
   ans = 0;
   if (p == NULL)
       Serial.print("? ");
       Serial.print(p);
   for (;;) {
       if (Serial.available()) {
           n = Serial.read();
           Serial.print(n, BYTE);
           if ((n == '\r') || (n == '\n')) {
           else if (n == '\010') {     // backspace
              Serial.print(" \010");
              ans /= 10;
           else if (isdigit(n)) {
               ans = ans*10 + (n - '0');
           else {
               Serial.println("\n\rERROR: BAD INPUT.  TRY AGAIN");
               goto restart;
   return (float)ans;
void landing()
   W = 3600.0 * V;
   Serial.print("ON MOON AT ");
   Serial.print(L);
   Serial.print(" SECONDS - IMPACT VELOCITY ");
   Serial.print(W);
   Serial.println(" MPH");
   if (W <= 1.2)
       Serial.println("PERFECT LANDING!");
   else if (W <= 10.0)
       Serial.println("GOOD LANDING (COULD BE BETTER)");
   else if (W <= 60.0) {
       Serial.println("CRAFT DAMAGE... YOU'RE STRANDED HERE UNTIL A RESCUE");
       Serial.println("PARTY ARRIVES.  HOPE YOU HAVE ENOUGH OXYGEN!");
       Serial.println("SORRY THERE WERE NO SURVIVORS. YOU BLEW IT!");
       Serial.print("IN FACT, YOU BLASTED A NEW LUNAR CRATER ");
       Serial.print(W*0.277);
       Serial.println(" FEET DEEP!");
   Serial.println("\n\n\nTRY AGAIN?");
void sub420()
   float q, q2, q3, q4, q5;
   q  = S * K/M;
   q2 = q * q;
   q3 = q * q2;
   q4 = q * q3;
   q5 = q * q4;
   J=V+G*S+Z*(-q - (q2/2.0) - (q3/3.0) - (q4/4.0) - (q5/5.0));
   I=A-G*S*S/2.0-V*S+Z*S*(q/2.0 + q2/6.0 + q3/12.0 + q4/20.0 + q5/30.0);
void sub330()
   L += S;
   T -= S;
   M -= S*K;
   A = I;
   V = J;
void sub340() {
   float D;
   for ( ;S >= 5.0e-3; ) { // line 340
       D = V + sqrt(V*V+2.0*A*(G-Z*K/M));
       S = 2.0 * A / D;
       sub420();
       sub330();
   char line[80];
   Serial.println("\nSET BURN RATE OF RETRO ROCKETS TO ANY VALUE BETWEEN");
   Serial.println("0 (FREE FALL) AND 200 (MAXIMUM BURN) POUNDS PER SECOND.");
   Serial.println("SET NEW BURN RATE EVERY 10 SECONDS.\n");
   Serial.println("CAPSULE WEIGHT 32,500 LBS; FUEL WEIGHT 16,500 LBS.");
   Serial.println("\n\n\nGOOD LUCK");
   L=0;
   Serial.println("\nSEC\tMI + FT \tMPH\tLB FUEL\t\tBURN RATE\n");
   A=120.0; V=1.0; M=33000.0; N=16500.0; G=1.0e-3; Z=1.8;
   for (;;) {                        // line 150
       sprintf(line, " %-d\t %d  %-4d\t %d\t %d\t\t",
                        (int)L, (int)floor(A),
                         (int)floor(5280.0*(A-floor(A))),
                     (int)(3600.0*V), (int)(M-N));
       Serial.print(line);
       K = input(NULL);
       T = 10.0;
       for (;;) {                    // line 160
           if ((M-N) < 1.0e-3) {
               Serial.print("FUEL OUT AT ");
               Serial.print(L);
               Serial.println(" SECONDS");
               S = (-V + sqrt(V*V + 2*A*G))/G;
               V += G*S;
               L += S;
               landing();
               return;      // Game over, Man!
           if (T < 1.0e-3)  // line 170
           S = T;
           if (M < (N+S*K))
               S = (M-N)/K;
           sub420();
           if (I <= 0.0) {
               sub340();
               landing();
               return;
           if ((V <= 0.0) || (J >= 0.0)) {
               sub330();
               continue;     // back to line 160
           // line 370
           do {
               W = (1.0 - M*G/(Z*K))/2.0;
               S = M*V/(Z*K*(W+sqrt(W*W+V/Z))) + 0.05;
               sub420();
               if (I <= 0.0) {
                   sub340();
                   landing();
                   return;
               sub330();
               if (J > 0.0)
           } while (V > 0.0);
are there perhaps some explanations available about the meanings of the variable names?
and perhaps some comments about the processed calculations? e.g.
J=V+GS+Z(-q - (q2/2.0) - (q3/3.0) - (q4/4.0) - (q5/5.0));
I=A-GSS/2.0-VS+ZS*(q/2.0 + q2/6.0 + q3/12.0 + q4/20.0 + q5/30.0);
edit, update:
As there was no information given, I wrote my own version from the scratch… :slight_smile:
dsyleixa:
Fun program, but looks like the original author was trying to save bytes on variable names!
From a quick look at the code, I assume the variables might represent:
  • L=Absolute time (s)
  • A=Altitute (miles)
  • V=Velocity (miles/sec, positive down)
  • M=Total capsule weight (lbs, fuel + tare weight)
  • N=Tare weight (lbs)
  • G=Gravitational constant (miles/sec^2)
  • Z=? factor for velocity correction due to proportion of fuel burn weight reduction (miles/sec)
  • K=Fuel Burn rate (lb/sec)
  • T=Normal Time interval step (s, basis for relative calcs)
  • S=Adjusted Time interval step (s, used when finer precision time-step required, eg. when normal step would deplete fuel)
  • W=Velocity (miles/hr, positive down)
  • I=Next Altitute (miles)
  • J=Next Velocity (miles/sec)
  • Q=Proportion of capsule weight reduction during interval (fraction)
thank you very much! 8)
