I'm reasonably new to LVGL. I'm creating a GUI which basically controls appliances around the house. It talks to other ESP32's which is attached to the appliances. I've created the TabView, TabView Buttons and Header Labels which all work perfectly fine. They are exactly what I want. I then started adding buttons and the word 'Text' has suddenly appeared to the left of the Header Label...... and I cannot for the life of me work out where it has come from. I commented out all of the buttons and the word 'Text' no longer appears, so it has something to do with the button coding. I apologise in advance if it is something simple and I'm having a blonde day, but it is wrecking my head. If someone can help it would be appreciated.
Here's the code: -
//***************** Tabbed GUI ***********************
void lv_create_main_gui(void) {
//CLEAR SCREEN
lv_obj_clean(lv_scr_act());
/*Create a Tab view object*/
lv_obj_t * tabview;
tabview = lv_tabview_create(lv_screen_active());
lv_tabview_set_tab_bar_position(tabview, LV_DIR_LEFT);
lv_tabview_set_tab_bar_size(tabview, 95);
//Set background colour on all tabs
lv_obj_set_style_bg_color(tabview, lv_palette_lighten(LV_PALETTE_YELLOW, 1), 0);
lv_obj_t * tab_buttons = lv_tabview_get_tab_bar(tabview);
lv_obj_set_style_bg_color(tab_buttons, lv_palette_darken(LV_PALETTE_BLUE, 5), 0);
lv_obj_set_style_text_color(tab_buttons, lv_palette_lighten(LV_PALETTE_BLUE, 5), 0);
lv_obj_set_style_border_side(tab_buttons, LV_BORDER_SIDE_RIGHT, LV_PART_ITEMS | LV_STATE_CHECKED);
/*Add tabs (the tabs are page (lv_page) and can be scrolled*/
lv_obj_t * tab1 = lv_tabview_add_tab(tabview, "Lounge");
lv_obj_t * tab2 = lv_tabview_add_tab(tabview, "Kitchen");
lv_obj_t * tab3 = lv_tabview_add_tab(tabview, "Printing");
lv_obj_t * tab4 = lv_tabview_add_tab(tabview, "Bedroom");
lv_obj_t * tab5 = lv_tabview_add_tab(tabview, "Cameras");
lv_obj_t * tab6 = lv_tabview_add_tab(tabview, "To Do");
lv_obj_t * tab7 = lv_tabview_add_tab(tabview, "Shopping");
//******* Header Style *******
static lv_style_t style;
lv_style_init(&style);
lv_style_set_text_font(&style, &lv_font_montserrat_20);
//**** Living Room *************
lv_obj_t * Header_label = lv_label_create(tab1);
lv_obj_add_style(Header_label, &style, 0);
lv_label_set_long_mode(Header_label, LV_LABEL_LONG_WRAP);
lv_label_set_text(Header_label, "Living Room");
lv_obj_set_width(Header_label, 180);
lv_obj_set_style_text_align(Header_label, LV_TEXT_ALIGN_CENTER, 0);
lv_obj_align(Header_label, LV_ALIGN_CENTER, 0, -100);
// Create Big Light Button with event handling
lv_obj_t * BigLight_label = lv_label_create(tab1);
lv_obj_t * BigLight_Btn = lv_button_create(tab1);
lv_obj_set_width(BigLight_label, 160);
lv_obj_set_width(BigLight_Btn, 180);
lv_obj_add_event_cb(BigLight_Btn, event_handler_BigLight, LV_EVENT_ALL, NULL);
lv_obj_align(BigLight_Btn, LV_ALIGN_CENTER, 0, -50);
lv_obj_add_flag(BigLight_Btn, LV_OBJ_FLAG_CHECKABLE);
lv_obj_remove_flag(BigLight_Btn, LV_OBJ_FLAG_PRESS_LOCK);
BigLight_label = lv_label_create(BigLight_Btn);
lv_obj_set_style_bg_color(BigLight_Btn, lv_color_hex(0x5d91e9), LV_PART_MAIN);
lv_label_set_text(BigLight_label, "Big Light");
lv_obj_center(BigLight_label);
Serial.println("BigLight Status ON RETURN: ");
Serial.println(BigLight);
if(BigLight == HIGH){
lv_obj_add_state(BigLight_Btn, LV_STATE_CHECKED);
// Create Small Light Button with event handling
lv_obj_t * SmallLight_label = lv_label_create(tab1);
lv_obj_t * SmallLight_Btn = lv_button_create(tab1);
lv_obj_set_width(SmallLight_label, 160);
lv_obj_set_width(SmallLight_Btn, 180);
lv_obj_align(SmallLight_Btn, LV_ALIGN_CENTER, 0, -10);
lv_obj_add_event_cb(SmallLight_Btn, event_handler_SmallLight, LV_EVENT_ALL, NULL);
lv_obj_add_flag(SmallLight_Btn, LV_OBJ_FLAG_CHECKABLE);
lv_obj_remove_flag(SmallLight_Btn, LV_OBJ_FLAG_PRESS_LOCK);
SmallLight_label = lv_label_create(SmallLight_Btn);
lv_obj_set_style_bg_color(SmallLight_Btn, lv_color_hex(0x5d91e9), LV_PART_MAIN);
lv_label_set_text(SmallLight_label, "Small Light");
lv_obj_center(SmallLight_label);
if(SmallLight == HIGH){
lv_obj_add_state(SmallLight_Btn, LV_STATE_CHECKED);
// Create Lamp Button with event handling
lv_obj_t * Lamp_label = lv_label_create(tab1);
lv_obj_t * Lamp_Btn = lv_button_create(tab1);
lv_obj_set_width(Lamp_label, 160);
lv_obj_set_width(Lamp_Btn, 180);
lv_obj_align(Lamp_Btn, LV_ALIGN_CENTER, 0, 30);
lv_obj_add_event_cb(Lamp_Btn, event_handler_Lamp, LV_EVENT_ALL, NULL);
lv_obj_add_flag(Lamp_Btn, LV_OBJ_FLAG_CHECKABLE);
lv_obj_remove_flag(Lamp_Btn, LV_OBJ_FLAG_PRESS_LOCK);
Lamp_label = lv_label_create(Lamp_Btn);
lv_obj_set_style_bg_color(Lamp_Btn, lv_color_hex(0x5d91e9), LV_PART_MAIN);
lv_label_set_text(Lamp_label, "Table Lamp");
lv_obj_center(Lamp_label);
if(Lamp == HIGH){
lv_obj_add_state(Lamp_Btn, LV_STATE_CHECKED);
// Create a Blinds Button with event handling
lv_obj_t * blinds_label = lv_label_create(tab1);
lv_obj_t * Blinds_Btn = lv_button_create(tab1);
lv_obj_set_width(blinds_label, 160);
lv_obj_set_width(Blinds_Btn, 180);
lv_obj_add_event_cb(Blinds_Btn, event_handler_Blinds, LV_EVENT_ALL, NULL);
lv_obj_align(Blinds_Btn, LV_ALIGN_CENTER, 0, 70);
lv_obj_add_flag(Blinds_Btn, LV_OBJ_FLAG_CHECKABLE);
lv_obj_remove_flag(Blinds_Btn, LV_OBJ_FLAG_PRESS_LOCK);
blinds_label = lv_label_create(Blinds_Btn);
lv_obj_set_style_bg_color(Blinds_Btn, lv_color_hex(0x5d91e9), LV_PART_MAIN);
lv_label_set_text(blinds_label, "Blinds");
lv_obj_center(blinds_label);
if(Blinds == HIGH){
lv_obj_add_state(Blinds_Btn, LV_STATE_CHECKED);
//******** Kitchen *************
Header_label = lv_label_create(tab2);
lv_label_set_text(Header_label, "Kitchen");
Header_label = lv_label_create(tab3);
lv_label_set_text(Header_label, "Printing Room");
//******** Bedroom *************
Header_label = lv_label_create(tab4);
lv_label_set_text(Header_label, "Bedroom");
//******** Cameras *************
Header_label = lv_label_create(tab5);
lv_label_set_text(Header_label, "Cameras");
//********** To Do *************
Header_label = lv_label_create(tab6);
lv_label_set_text(Header_label, "To Do List");
//******** Shopping ************
Header_label = lv_label_create(tab7);
lv_label_set_text(Header_label, "Shopping");
lv_obj_remove_flag(lv_tabview_get_content(tabview), LV_OBJ_FLAG_SCROLLABLE);
