Βlynk.begin() messes up my readings (Json,Nodemcu,Blynk,MSP432)
I use MSP432 to send sensor values through serial to NodeMCU and then send them via wifi to Blynk.
the problem shows up when i uncomment this line:
Blynk.begin(auth, ssid, pass);
my sensor values that gets parsed by a Json object suddenly becomes 0.00;
here is the code:
#define BLYNK_TEMPLATE_ID           "TMPLvNuI6u_g"
#define BLYNK_DEVICE_NAME           "Quickstart Device"
#define BLYNK_AUTH_TOKEN            "M_JWokpG5OMGsLitRvyH6TNzpfYGDsgc"
#define BLYNK_PRINT Serial
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <Wire.h>
#include <ArduinoJson.h>
SoftwareSerial nodemcu(D7,D8);
BlynkTimer timer; //announcing the timer
char auth[] = BLYNK_AUTH_TOKEN;
char ssid[] = "TheVoid";
char pass[] = "000000gggggg";
float temp, temp0, hum, pt1, pt2, pt3, pt4;
long pres;
void datareceive()
    Serial.println("datareceive starting...");
    StaticJsonBuffer<1024> JsonBuffer;
    JsonObject& data = JsonBuffer.parseObject(nodemcu);
    if (data == JsonObject::invalid()) {
      Serial.println("Invalid Json Object");
      JsonBuffer.clear();
      return;
     temp = data["temperature"];
     hum  = data["humidity"]   ;
     pres = data["pressure"]   ;
     pt1  = data["pt1"]        ;
     pt2  = data["pt2"]        ;
     pt3  = data["pt3"]        ;
     pt4  = data["pt4"]        ;
    Serial.println("datareceive succeed");
void datasend()
      Serial.println("datasend starting...");
  // You can send any value at any time.
  // Please don't send more that 10 values per second.
    //Blynk.virtualWrite(V0, temp);
//    Blynk.virtualWrite(V1, hum);
//    Blynk.virtualWrite(V2, pres);
//    Blynk.virtualWrite(V3, pt1);
//    Blynk.virtualWrite(V4, pt2);
//    Blynk.virtualWrite(V5, pt3);
//    Blynk.virtualWrite(V6, pt4);
    Serial.println(temp);
    Serial.println("datasend succeed");
    Serial.println("---------------------");
void setup(){
    nodemcu.begin(9600);
    // You can also specify server:
    //Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
    //Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
    // Setup a function to be called every second
    timer.setInterval(1000L, datareceive);
    timer.setInterval(1000L, datasend);
void loop(){
    Blynk.run();
    timer.run();
thanks for any advice
Gio
