I contacted linxmoton by their forums and they sent me some code. They said to delete the input from the keyboard/remote controller and that I would be good to go. Well the problem is that I can not seem to understand the code.
#include <Servo.h>
#include <PS2X_lib.h>
//#define DEBUG
//comment to disable the Force Sensitive Resister on the gripper
//#define FSRG
//FSRG pin Must be analog!!
#define FSRG_pin A1
//Select which arm by uncommenting the corresponding line
//#define AL5A
//#define AL5B
#define AL5D
//uncomment for digital servos in the Shoulder and Elbow
//that use a range of 900ms to 2100ms
//#define DIGITAL_RANGE
#ifdef AL5A
const float A = 3.75;
const float B = 4.25;
#elif defined AL5B
const float A = 4.75;
const float B = 5.00;
#elif defined AL5D
const float A = 5.75;
const float B = 7.375;
#endif
//PS2 pins
#define DAT 6
#define CMD 7
#define ATT 8
#define CLK 9
//PS2 analog joystick Deadzone
#define Deadzone 4
//Arm Servo pins
#define Base_pin 2
#define Shoulder_pin 3
#define Elbow_pin 4
#define Wrist_pin 10
#define Gripper_pin 11
#define WristR_pin 12
//Onboard Speaker
#define Speaker_pin 5
//Radians to Degrees constant
const float rtod = 57.295779;
//Arm Speed Variables
float Speed = 1.0;
int sps = 3;
//Servo Objects
Servo Elb;
Servo Shldr;
Servo Wrist;
Servo Base;
Servo WristR;
Servo Gripper;
//Arm Current Pos
float X = 4;
float Y = 4;
int Z = 90;
int G = 90;
int WR = 90;
float WA = 0;
//Arm temp pos
float tmpx = 4;
float tmpy = 4;
int tmpz = 90;
int tmpg = 90;
int tmpwr = 90;
float tmpwa = 0;
//PS2X Variables
PS2X ps2x;
int error = 0;
byte type = 0;
boolean mode = true;
#ifdef DEBUG
#endif
error = ps2x.config_gamepad(CLK,CMD,ATT,DAT, true, true); //setup pins and settings: GamePad(clock, command, attention, data, Pressures?, Rumble?) check for error
#ifdef DEBUG
if(error == 0)
Serial.println("Found Controller, configured successful");
else if(error == 1)
Serial.println("No controller found");
else if(error == 2)
Serial.println("not accepting commands");
else if(error == 3)
Serial.println("refusing Pressures mode");
type = ps2x.readType();
switch(type)
case 0:
Serial.println("Unknown");
case 1:
Serial.println("DualShock");
case 2:
Serial.println("GuitarHero");
#endif
Base.attach(Base_pin);
Shldr.attach(Shoulder_pin);
Elb.attach(Elbow_pin);
Wrist.attach(Wrist_pin);
Gripper.attach(Gripper_pin);
WristR.attach(WristR_pin);
int Arm(float x, float y, float z, int g, float wa, int wr) //Here's all the Inverse Kinematics to control the arm
float M = sqrt((y*y)+(x*x));
if(M <= 0)
return 1;
float A1 = atan(y/x);
if(x <= 0)
return 1;
float A2 = acos((A*A-B*B+M*M)/((A*2)*M));
float Elbow = acos((A*A+B*B-M*M)/((A*2)*B));
float Shoulder = A1 + A2;
Elbow = Elbow * rtod;
Shoulder = Shoulder * rtod;
if((int)Elbow <= 0 || (int)Shoulder <= 0)
return 1;
float Wris = abs(wa - Elbow - Shoulder) - 90;
#ifdef DIGITAL_RANGE
Elb.writeMicroseconds(map(180 - Elbow, 0, 180, 900, 2100 ));
Shldr.writeMicroseconds(map(Shoulder, 0, 180, 900, 2100));
#else
Elb.write(180 - Elbow);
Shldr.write(Shoulder);
#endif
Wrist.write(180 - Wris);
Base.write(z);
WristR.write(wr);
#ifndef FSRG
Gripper.write(g);
#endif
Y = tmpy;
X = tmpx;
Z = tmpz;
WA = tmpwa;
#ifndef FSRG
G = tmpg;
#endif
WR = tmpwr;
return 0;
ps2x.read_gamepad(); //update the ps2 controller
int LSY = 128 - ps2x.Analog(PSS_LY);
int LSX = ps2x.Analog(PSS_LX) - 128;
int RSY = 128 - ps2x.Analog(PSS_RY);
int RSX = ps2x.Analog(PSS_RX) - 128;
if(RSY > Deadzone || RSY < -Deadzone)
tmpy = max(Y + RSY/1000.0*Speed, -1);
if(RSX > Deadzone || RSX < -Deadzone)
tmpx = max(X + RSX/1000.0*Speed, -0.5);
if(LSY > Deadzone || LSY < -Deadzone)
tmpwa = constrain(WA + LSY/100.0*Speed, 0, 180);
if(LSX > Deadzone || LSX < -Deadzone)
tmpz = constrain(Z + LSX/100.0*Speed, 0, 180);
if(ps2x.Button(PSB_R1))
#ifdef FSRG
while(analogRead(FSRG_pin) < 400)
Gripper.write(min(Gripper.read() + 2, 170));
if(Gripper.read() == 170)
#ifdef DEBUG
Serial.print(analogRead(FSRG_pin));
Serial.print(" ");
Serial.println(Gripper.read());
#endif
delay(10);
#else
tmpg = min(G + 5*Speed, 170);
#endif
if(ps2x.Button(PSB_R2))
#ifdef FSRG
while(Gripper.read() > 90)
Gripper.write(max(Gripper.read() - 2, 90));
#ifdef DEBUG
#endif
delay(10);
#else
tmpg = max(G - 5*Speed, 10);
#endif
if(ps2x.ButtonPressed(PSB_BLUE))
int pos = Gripper.readMicroseconds();
pos -= pos % 10;
while(pos != 1500)
pos += ((pos - 1500 > 0)? -10 : 10);
Gripper.writeMicroseconds(pos);
delay(25);
tmpg = 90;
G = 90;
if(ps2x.ButtonPressed(PSB_GREEN))
int pos = WristR.readMicroseconds();
pos -= pos % 10;
while(pos != 1500)
WristR.writeMicroseconds(pos);
delay(25);
tmpwr = 90;
WR = 90;
if(ps2x.Button(PSB_L1))
tmpwr = max(WR + 2*Speed, 0);
else if(ps2x.Button(PSB_L2))
tmpwr = min(WR - 2*Speed, 180);
if(ps2x.ButtonPressed(PSB_PAD_UP))
sps = min(sps + 1, 5);
tone(Speaker_pin, sps*500, 200);
else if(ps2x.ButtonPressed(PSB_PAD_DOWN))
sps = max(sps - 1, 1);
Speed = sps*0.20 + 0.60;
if(Arm(tmpx, tmpy, tmpz, tmpg, tmpwa, tmpwr))
#ifdef DEBUG
Serial.print("NONREAL Answer");
#endif
if(tmpx < 2 && tmpy < 2 && RSX < 0)
tmpy = tmpy + 0.05;
Arm(tmpx, tmpy, tmpz, tmpg, tmpwa, tmpwr);
else if(tmpx < 1 && tmpy < 2 && RSY < 0)
tmpx = tmpx + 0.05;
delay(30);
I will delete out what they said and see if it makes a little more sense! I will post the new code when i’m finished.
