Hello,
I´m trying to use a Feather M0 Adalogger to collect data from a BME280. So I´m using SPI, because the I2C doesn´t work.
For this Project I have this sketch:
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define BME_SCK SCK
#define BME_MISO MISO
#define BME_MOSI MOSI
#define BME_CS 0
#define SEALEVELPRESSURE_HPA (1013.25)
//Adafruit_BME280 bme; //I2C
**//Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI**
**Adafruit_BME280 bme(BME_CS); // hardware SPI**
File myFile;
String Temperature, Pressure, Altitude, Humidity;
String Data;
//delay(2000);
pinMode(0,OUTPUT);
bool status;
status = bme.begin();
if (!status) {
Serial.println("BME280 not connected properly. Check circuit!");
while (1);
Serial.print("Initializing SD card...");
if (!SD.begin(4)) // Num. = CS Pin
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
myFile = SD.open("data.txt", FILE_WRITE);
if (myFile) {
myFile.println( "Temperature(°C), Pressure(hPa), Altitude(m), Humidity(%) \r\n");
myFile.close();
else {
Serial.println("error opening data.txt");
data_logging();
delay(20000);
void data_logging() {
String Temperature = String(bme.readTemperature(),2);
String Pressure = String(bme.readPressure()/ 100.0F,2);
String Altitude = String(bme.readAltitude(SEALEVELPRESSURE_HPA),2);
String Humidity = String(bme.readHumidity(),2);
Data = Temperature + "," + Pressure + "," + Altitude + "," + Humidity ;
Serial.print("Save data: ");
Serial.println(Data);
if (myFile) {
Serial.print("Writing to data.txt...");
myFile.println(Data);
myFile.close();
Serial.println("done.");
In the Line 15 and 16 at begining of the sketch: I use the "Adafruit_BME280 bme ..." (one Line for Software and one for Hardware.)
When I want to use the Line for Software, the Sensor give not the correct Data to the SD-Card.
When I use the Line for Hardware, I get the correct Data from the Sensor.
Where is the difference? Can someone explane?
