apparently noone else can get a file from that site either. even using a browser that works shows the hex file link is broken. actually not a link at all and cut and paste dont work. maybe its a language barrier but mcu4life dont seem to have a handle on this. as can be seen in my photo there are no "switches". power cycling and manual reset dont help with either of the two hex files ive posted. what i need is a file that somebody has actually verified before i put lots more effort into this. i do appreciate the attempt to help though.
p.s. so the search goes on. they are using usbasp for now but the application needs isp pins that must be disconnected every time which is inconvenient. it would be nice to use rx/tx instead.
john1993:
sorry it was a wrong mega128 i saw. will try to upload the hex i used.
ahhhh... thanks. your website works a lot better than the other one. i downloaded the m128 file and will give it a try. btw i see you use the same chinese breakout board that i use for my m2560 projects. it has both .5mm and .8mm pitch and works from m8/328 and m128 up to the m2560. i love those.
