Dear Community,
I am working on a project which needs a menu style of interface where I can vary 2 values. I found the rotary encoder example of the M2tklib. Initially, the sketch displays 2 digit values on a range from 0 to 99. I need values at a range from 0 to 999. I found a way to plot 3 digits. However the variables which store the values when changed with the rotary encoder do not reach 999. Specifically, it can go from 0 to 255. The data type of the variables are "uint8_t". I believe that is the reason which does not let me to plot values greater than 255. Changing the data type of the variables gives me errors that I do not know how to solve. Any input is welcomed. I am providing below the code which plots 3 digits.
#include "U8glib.h"
#include "M2tk.h"
#include "utility/m2ghu8g.h"
U8GLIB_SSD1306_128X64 u8g(U8G_I2C_OPT_NONE);
// Forward declaration of the toplevel element
M2_EXTERN_ALIGN(top_menu);
// Simple dialog: Input two values n1 and n2
uint8_t n1 = 0;
uint8_t n2 = 0;
M2_LABEL(el_l1, NULL, "value 1:");
M2_U8NUM(el_u1, "c3", 0, 255, &n1);
M2_LABEL(el_l2, NULL, "value 2:");
M2_U8NUM(el_u2, "c3", 0, 255, &n2);
M2_LIST(list) = { &el_l1, &el_u1, &el_l2, &el_u2 };
M2_GRIDLIST(el_gridlist, "c2", list);
M2_ALIGN(top_menu, "-1|1W64H64", &el_gridlist);
// m2 object and constructor
// Note: Use the "m2_eh_4bd" handler, which fits better to the "m2_es_arduino_rotary_encoder"
M2tk m2(&top_menu, m2_es_arduino_rotary_encoder, m2_eh_4bd, m2_gh_u8g_bf);
// Arduino Setup & Loop
void setup(void) {
// Connect u8glib with m2tklib
m2_SetU8g(u8g.getU8g(), m2_u8g_box_icon);
// Assign u8g font to index 0
m2.setFont(0, u8g_font_7x13r);
// define button for the select message
m2.setPin(M2_KEY_SELECT, 7); // dogm128 shield, 2nd from top
// The incremental rotary encoder is conected to these two pins
m2.setPin(M2_KEY_ROT_ENC_A, 3);
m2.setPin(M2_KEY_ROT_ENC_B, 2);
// check rotary encoder also inside the picture loop
m2.checkKey();
// process events and redraw menu if required
if ( m2.handleKey() != 0 ) {
u8g.firstPage();
do {
m2.checkKey();
// draw menu
m2.draw();
} while( u8g.nextPage() );
What was changed to the initial code to plot 3 digits from 2 digits was the below code
M2_U8NUM(el_u1, "c2", 0, 99, &n1);
M2_U8NUM(el_u2, "c2", 0, 99, &n2);
Trying to change n1, n2 from "uint8_t" to "int" which I though that it would solve my problem gives me the following error;
error: cannot convert 'int*' to 'uint8_t* {aka unsigned char*}' in initialization
#define M2_U8NUM(el,fmt,min,max,variable) m2_el_u8_ptr_t el M2_SECTION_PROGMEM = { { { m2_el_u8num_fn, (fmt) }, (min), (max) }, (variable) }
exit status 1
Error compiling for board Arduino Uno.
Thank you,
C_iak
