My power supply is a 36v and 10a.
Motor is High Torque Nema 23 CNC Stepper Motor 113mm 3Nm(425oz.in) 23HS45
Driver is M542T
My wiring is:
Pul+ e Dir+ --> +5v arduino
Pul- --> Pin 9
Dir- --> Pin 8
Spepper pin are
A+ --> Black
A- --> Green
B+ --> Red
B- --> Blue
Problem: when the code start, the motor provide holding torque and the green light of m542t turn on (well); when the code reaches the instruction where I set the signal level of Pulse pin to HIGH, the red alarm light of my m542t turn on and the motor han no more torque. I do not think is the output voltage from my Arduino the problem ....anyway I tried with 3 different arduino mega shield
My code is:
// Pin numbers
int pulPin = 9;
int dirPin = 8;
int loops = 0;
pinMode(pulPin, OUTPUT);
pinMode(dirPin, OUTPUT);
digitalWrite(pulPin, LOW);
digitalWrite(dirPin, LOW);
delay(3000);
Serial.println("init");
Serial.println("high");
digitalWrite(pulPin, HIGH);
delayMicroseconds(800);
Serialprintln("low");
The vendor of motor,driver and power supply ( Stepperonline) say:
"The connection is correct and power supply is OK.
When power on showing holding torque means the drive and motor are OK.
You connect PUL+ and DIR+ to +5V, so your control signal should be lower level voltage.
And we can't tell if your program is correct."
Could anyone give me some help to resolve the problem? ... I do not know what else to try
