I have MAX30100 oxygen/heartbeat sensor in M5Stack Heart Unit with which i communcicate via I2C.
Arduino example :scan for I2C is able to see the device and prints it's address but i am not able to communicate with it. Lib for MAX30100 just freezes on initialization.
How can i fix that? May there be problem in Max30100 library, or examples ino file??
Post a complete sketch that tries to communicate with the sensor. What address does the scanner report and what happens when you run the sketch ? Which Arduino board are you using ?
So I am using Arduino UNO board, scaner report address 0x57 (it agrees with unit datasheet, so it is correct i suppose). When i run it and monitor COM port it shows first message: "Initializing pulse oximeter..", and nothing else. No error, no success message.
Also I use minimal example from library:
#include <Wire.h>
#include "MAX30100_PulseOximeter.h"
#define REPORTING_PERIOD_MS 1000
PulseOximeter pox;
uint32_t tsLastReport = 0;
Serial.print("Initializing pulse oximeter..");
Delay(1000);
if (!pox.begin()) {
Serial.println("FAILED");
for(;;);
Serial.println("SUCCESS");
// Register a callback for the beat detection
pox.setOnBeatDetectedCallback(onBeatDetected);
// Make sure to call update as fast as possible
pox.update();
// Asynchronously dump heart rate and oxidation levels to the serial
// For both, a value of 0 means "invalid"
if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
Serial.print("Heart rate:");
Serial.print(pox.getHeartRate());
Serial.print("bpm / SpO2:");
Serial.print(pox.getSpO2());
Serial.println("%");
tsLastReport = millis();
I also tried connecting via tester examle, but again no responser after initializing print.
It's part of tester code, to point where it is not working anyway:
