I get the following error message after a successful compile, but then upload fails:
esptool write_flash: error: argument <address> <filename>: Address "{upload.erase_cmd}" must be a number
Using Arduin0 1.8.19 with Windows10.
I have used M5Core2 successfully and now have M5Stack-Tough, both use ESP32-S3.
I have loaded the correct board and M5Tough library and selected the correct board, M5Stack-Tough.
I have selected the correct port when the M5Stack-Tough is plugged in.
When I compile and upload any example sketches for M5Tough I get the error message above.
Can anyone help with this message and explain what I need to do?
Did it help? Which board did you choose?
The error message you posted clearly shows that the M5Stack people did the core wrongly, the board definitions are missing some important parameters. Write to their support team and ask for a fix.
