#define C_PLUS 1 //CHANGE TO 1 IF YOU USE THE M5STICK-C PLUS
#if C_PLUS == 1
#include <M5StickCPlus.h>
#else
#include <M5StickC.h>
#endif
#include <WiFi.h>
#include <WiFiAP.h>
#include <WiFiClient.h>
#include <WiFiGeneric.h>
#include <WiFiMulti.h>
#include <WiFiScan.h>
#include <WiFiServer.h>
#include <WiFiSTA.h>
#include <WiFiType.h>
#include <WiFiUdp.h>
#include <SocketIoClient.h>
#include <Arduino_JSON.h>
#include <PinButton.h>
#include <Preferences.h>
#define GRAY 0x0020 // 8 8 8
#define GREEN 0x0200 // 0 255 0
#define RED 0xF800 // 255 0 0
/* USER CONFIG VARIABLES
* Change the following variables before compiling and sending the code to your device.
bool CUT_BUS = true; // true = Programm + Preview = Red Tally; false = Programm + Preview = Yellow Tally
bool LAST_MSG = false; // true = show log on tally screen
//Wifi SSID and password
const char * networkSSID = "ReCo-Audio";
const char * networkPass = "SeCo-2021";
//For static IP Configuration, change USE_STATIC to true and define your IP address settings below
bool USE_STATIC = false; // true = use static, false = use DHCP
IPAddress clientIp(192, 168, 2, 5); // Static IP
IPAddress subnet(255, 255, 255, 0); // Subnet Mask
IPAddress gateway(192, 168, 2, 1); // Gateway
//Tally Arbiter Server
const char * tallyarbiter_host = "192.168.178.156"; //IP address of the Tally Arbiter Server
const int tallyarbiter_port = 4455;
/* END OF USER CONFIG */
//M5StickC variables
PinButton btnM5(37); //the "M5" button on the device
PinButton btnAction(39); //the "Action" button on the device
Preferences preferences;
uint8_t wasPressed();
const byte led_program = 10;
const int led_preview = 26; //OPTIONAL Led for preview on pin G26
//Tally Arbiter variables
SocketIoClient Socket;
JSONVar BusOptions;
JSONVar Devices;
JSONVar DeviceStates;
String DeviceId = "unassigned";
String DeviceName = "Unassigned";
String ListenerType = "m5-stickc";
bool mode_preview = false;
bool mode_program = false;
String LastMessage = "";
//General Variables
int currentScreen = 0; //0 = Tally Screen, 1 = Settings Screen
int currentBrightness = 11; //12 is Max level
pinMode (led_preview, OUTPUT);
while (!Serial);
// Initialize the M5StickC object
logger("Initializing M5StickC+.", "info-quiet");
M5.begin();
setCpuFrequencyMhz(80); //Save battery by turning down the CPU clock
btStop(); //Save battery by turning off BlueTooth
M5.Lcd.setRotation(3);
M5.Lcd.setCursor(0, 0);
M5.Lcd.fillScreen(TFT_BLACK);
M5.Lcd.setTextSize(1);
logger("Tally Arbiter M5StickC+ Listener Client booting.", "info");
// Enable interal led for program trigger
pinMode(led_program, OUTPUT);
digitalWrite(led_program, HIGH);
preferences.begin("tally-arbiter", false);
if(preferences.getString("deviceid").length() > 0){
DeviceId = preferences.getString("deviceid");
if(preferences.getString("devicename").length() > 0){
DeviceName = preferences.getString("devicename");
preferences.end();
delay(100); //wait 100ms before moving on
connectToNetwork(); //starts Wifi connection
socket.loop();
btnM5.update();
btnAction.update();
if (btnM5.isClick()) {
switch (currentScreen) {
case 0:
showSettings();
currentScreen = 1;
case 1:
showDeviceInfo();
currentScreen = 0;
if (btnAction.isClick()) {
updateBrightness();
void showSettings() {
//displays the current network connection and Tally Arbiter server data
M5.Lcd.setTextColor(WHITE, BLACK);
M5.Lcd.println("SSID: " + String(networkSSID));
M5.Lcd.println(WiFi.localIP());
M5.Lcd.println();
M5.Lcd.println("Tally Arbiter Server:");
M5.Lcd.println(String(tallyarbiter_host) + ":" + String(tallyarbiter_port));
M5.Lcd.println();
M5.Lcd.println("Battery:");
int batteryLevel = floor(100.0 * (((M5.Axp.GetVbatData() * 1.1 / 1000) - 3.0) / (4.07 - 3.0)));
batteryLevel = batteryLevel > 100 ? 100 : batteryLevel;
if(batteryLevel >= 100){
M5.Lcd.println("Battery charging..."); // show when M5 is plugged in
else {
M5.Lcd.println("Battery:" + String(batteryLevel) + "%");
void showDeviceInfo() {
//displays the currently assigned device and tally data
evaluateMode();
void updateBrightness() {
if(currentBrightness >= 12) {
currentBrightness = 7;
else {
currentBrightness++;
M5.Axp.ScreenBreath(currentBrightness);
void logger(String strLog, String strType) {
if (strType == "info") {
Serial.println(strLog);
M5.Lcd.println(strLog);
else {
void connectToNetwork() {
logger("Connecting to SSID: " + String(networkSSID), "info");
WiFi.disconnect(true);
WiFi.onEvent(WiFiEvent);
WiFi.mode(WIFI_STA); //station
WiFi.setSleep(false);
if(USE_STATIC == true) {
WiFi.config(clientIp, gateway, subnet);
WiFi.begin(networkSSID, networkPass);
delay(1000); //Delay is needed to actually figure out, if connection is established
void WiFiEvent(WiFiEvent_t event) {
switch (event) {
case SYSTEM_EVENT_STA_GOT_IP:
logger("Network connected!", "info");
logger(WiFi.localIP().toString(), "info");
connectToServer(); //if connection to wifi is established, actually start to connect the socket
case SYSTEM_EVENT_STA_DISCONNECTED:
logger("Network connection lost!", "info");
logger("WiFi: Trying to reconnect", "info");
WiFi.reconnect(); //if the connection to WiFi is lost (for whatever reason, try to reconnect
void ws_emit(String event, const char *payload = NULL) {
if (payload) {
String msg = "[\"" + event + "\"," + payload + "]";
socket.sendEVENT(msg);
String msg = "[\"" + event + "\"]";
void connectToServer() {
logger("Connecting to Tally Arbiter host: " + String(tallyarbiter_host), "info");
socket.onEvent(socket_event);
socket.begin(tallyarbiter_host, tallyarbiter_port);
void socket_event(socketIOmessageType_t type, uint8_t * payload, size_t length) {
switch (type) {
case sIOtype_CONNECT:
socket_Connected((char*)payload, length);
case sIOtype_DISCONNECT:
case sIOtype_ACK:
case sIOtype_ERROR:
case sIOtype_BINARY_EVENT:
case sIOtype_BINARY_ACK:
// Not handled
case sIOtype_EVENT:
String msg = (char*)payload;
String type = msg.substring(2, msg.indexOf("\"",2));
String content = msg.substring(type.length() + 4);
content.remove(content.length() - 1);
logger("Got event '" + type + "', data: " + content, "info-quiet");
if (type == "bus_options") BusOptions = JSON.parse(content);
if (type == "reassign") socket_Reassign(content);
if (type == "flash") socket_Flash();
if (type == "messaging") socket_Messaging(content);
if (type == "deviceId") {
DeviceId = content.substring(1, content.length()-1);
SetDeviceName();
showDeviceInfo();
currentScreen = 0;
if (type == "devices") {
Devices = JSON.parse(content);
SetDeviceName();
if (type == "device_states") {
DeviceStates = JSON.parse(content);
processTallyData();
void socket_Connected(const char * payload, size_t length) {
logger("Connected to Tally Arbiter server.", "info");
String deviceObj = "{\"deviceId\": \"" + DeviceId + "\", \"listenerType\": \"" + ListenerType + "\"}";
char charDeviceObj[1024];
strcpy(charDeviceObj, deviceObj.c_str());
ws_emit("bus_options");
ws_emit("device_listen_m5", charDeviceObj);
void socket_Flash() {
//flash the screen white 3 times
M5.Lcd.fillScreen(WHITE);
//then resume normal operation
case 0:
showDeviceInfo();
case 1:
showSettings();
String strip_quot(String str) {
if (str[0] == '"') {
str.remove(0, 1);
if (str.endsWith("\"")) {
str.remove(str.length()-1, 1);
return str;
void socket_Reassign(String payload) {
String oldDeviceId = payload.substring(0, payload.indexOf(','));
String newDeviceId = payload.substring(oldDeviceId.length()+1);
oldDeviceId = strip_quot(oldDeviceId);
newDeviceId = strip_quot(newDeviceId);
String reassignObj = "{\"oldDeviceId\": \"" + oldDeviceId + "\", \"newDeviceId\": \"" + newDeviceId + "\"}";
char charReassignObj[1024];
strcpy(charReassignObj, reassignObj.c_str());
ws_emit("listener_reassign_object", charReassignObj);
ws_emit("devices");
delay(200);
delay(200);
delay(200);
DeviceId = newDeviceId;
preferences.putString("deviceid", newDeviceId);
preferences.end();
SetDeviceName();
void socket_Messaging(String payload) {
String strPayload = String(payload);
int typeQuoteIndex = strPayload.indexOf(',');
String messageType = strPayload.substring(0, typeQuoteIndex);
messageType.replace("\"", "");
int messageQuoteIndex = strPayload.lastIndexOf(',');
String message = strPayload.substring(messageQuoteIndex + 1);
message.replace("\"", "");
LastMessage = messageType + ": " + message;
evaluateMode();
void processTallyData() {
for (int i = 0; i < DeviceStates.length(); i++) {
if (getBusTypeById(JSON.stringify(DeviceStates[i]["busId"])) == "\"preview\"") {
if (DeviceStates[i]["sources"].length() > 0) {
mode_preview = true;
else {
if (getBusTypeById(JSON.stringify(DeviceStates[i]["busId"])) == "\"program\"") {
mode_program = true;
else {
evaluateMode();
String getBusTypeById(String busId) {
for (int i = 0; i < BusOptions.length(); i++) {
if (JSON.stringify(BusOptions[i]["id"]) == busId) {
return JSON.stringify(BusOptions[i]["type"]);
return "invalid";
void SetDeviceName() {
for (int i = 0; i < Devices.length(); i++) {
if (JSON.stringify(Devices[i]["id"]) == "\"" + DeviceId + "\"") {
String strDevice = JSON.stringify(Devices[i]["name"]);
DeviceName = strDevice.substring(1, strDevice.length() - 1);
preferences.putString("devicename", DeviceName);
preferences.end();
evaluateMode();
void evaluateMode() {
M5.Lcd.setCursor(0, 30);
M5.Lcd.setTextSize(2);
if (mode_preview && !mode_program) {
logger("The device is in preview.", "info-quiet");
M5.Lcd.setTextColor(BLACK);
M5.Lcd.fillScreen(GREEN);
digitalWrite (led_preview, HIGH);
else if (!mode_preview && mode_program) {
logger("The device is in program.", "info-quiet");
M5.Lcd.fillScreen(RED);
digitalWrite(led_program, LOW);
digitalWrite(led_preview, LOW);
else if (mode_preview && mode_program) {
logger("The device is in preview+program.", "info-quiet");
if (CUT_BUS == true) {
else {
M5.Lcd.fillScreen(YELLOW);
else {
M5.Lcd.setTextColor(GRAY);
M5.Lcd.println(DeviceName);
if (LAST_MSG == true){
M5.Lcd.println(LastMessage);
Please edit your post to add code tags ("</>" editor button).
See the "How to get the best out of the forum" post for instructions on what to post.
What errors do you get?
Tom...
Read the forum guidelines to see how to properly post code and some information on how to get the most from this forum.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
Please include the entire error message. It is easy to do. There is a button (lower right of the IDE window) called "copy error message". Copy the error and paste into a post in code tags. Paraphrasing the error message leaves out important information.
on line 233 i get the error: variable or field 'socket_event' declaired void
Arduino:1.8.16 (Windows 10), Board:"M5Stick-C-Plus, Default, 750000, None"
D:\Bureaublad\StickM5\StickM5.ino:27: warning: "GREEN" redefined
In file included from D:\Documenten\Arduino\libraries\M5StickCPlus\src/M5Display.h:7,
from D:\Documenten\Arduino\libraries\M5StickCPlus\src/M5StickCPlus.h:69,
from D:\Bureaublad\StickM5\StickM5.ino:4:
D:\Documenten\Arduino\libraries\M5StickCPlus\src/utility/In_eSPI.h:542: note: this is the location of the previous definition
#define GREEN 0x07E0 /* 0, 255, 0 */
StickM5:233:19: error: variable or field 'socket_event' declared void
StickM5:233:19: error: 'socketIOmessageType_t' was not declared in this scope
StickM5:233:55: error: expected primary-expression before '*' token
StickM5:233:57: error: 'payload' was not declared in this scope
StickM5:233:73: error: expected primary-expression before 'length'
D:\Bureaublad\StickM5\StickM5.ino: In function 'void loop()':
StickM5:114:3: error: 'socket' was not declared in this scope
socket.loop();
D:\Bureaublad\StickM5\StickM5.ino:114:3: note: suggested alternative: 'Socket'
socket.loop();
Socket
D:\Bureaublad\StickM5\StickM5.ino: In function 'void showSettings()':
D:\Bureaublad\StickM5\StickM5.ino:149:58: warning: 'uint16_t AXP192::GetVbatData()' is deprecated [-Wdeprecated-declarations]
In file included from D:\Documenten\Arduino\libraries\M5StickCPlus\src/M5StickCPlus.h:70,
D:\Documenten\Arduino\libraries\M5StickCPlus\src/AXP192.h:28:11: note: declared here
uint16_t GetVbatData(void) __attribute__((deprecated));
D:\Bureaublad\StickM5\StickM5.ino: In function 'void ws_emit(String, const char*)':
StickM5:220:5: error: 'socket' was not declared in this scope
D:\Bureaublad\StickM5\StickM5.ino:220:5: note: suggested alternative: 'Socket'
Socket
StickM5:223:5: error: 'socket' was not declared in this scope
D:\Bureaublad\StickM5\StickM5.ino:223:5: note: suggested alternative: 'Socket'
Socket
D:\Bureaublad\StickM5\StickM5.ino: In function 'void connectToServer()':
StickM5:229:3: error: 'socket' was not declared in this scope
D:\Bureaublad\StickM5\StickM5.ino:229:3: note: suggested alternative: 'Socket'
Socket
StickM5:229:18: error: 'socket_event' was not declared in this scope
D:\Bureaublad\StickM5\StickM5.ino:229:18: note: suggested alternative: 'socket_Flash'
socket_Flash
D:\Bureaublad\StickM5\StickM5.ino: At global scope:
D:\Bureaublad\StickM5\StickM5.ino:233:19: note: suggested alternative: 'socket_Messaging'
socket_Messaging
exit status 1
