Hi every I need to connect an m66311p led controller to my Arduino uno, some one please could show me how to do it and send me some code as an example. I need to use this chip cause the project is using old parts from devices not in use. Thank a lot.
This chip is basically a 16 bit shift register so wire it up like you would wire up like a shift register. There are plenty of tutorials on line that show you how to do this.
We don’t do that here, we help you get things right when you are stuck. Again just look at the code on line for using two shift registers because this chip is basically two 8 bit shift registers in one package.
Thanks a lot for you answer.
