MAC address of Ethernet shield is unexpectedly sent
Hello,i'm french
I'm using Ethernet shields for UDP protocole with Ethernet lib,
my problem is the write command is succesfull send my buffer after the Udp.endPacket(); but mac adresse of the shield Ethernet is send after the buffer like it is in the buffer to send.
WRITE CODE/
Udp.begin(localPort);
Udp.beginPacket(broadcastIP, localPort);
//Udp.println(Ethernet.localIP());
Udp.write(datadetect_CI3100);
Udp.endPacket();
Udp.stop();
Where datadetect_CI3100 is/
char datadetect_CI3100[] = {
0x30, 0x42, 0x36, 0x38, 0x44, 0x32, 0x32, 0x41, 0x54, 0x45, 0x4d, 0x49, 0x4c, 0x43, 0x53, 0x44, 0x4e, 0x41, 0x4c, 0x44, 0x45, 0x52, 0x30, 0x38, 0x30, 0x34, 0x33, 0x65, 0x39, 0x34, 0x34, 0x36, 0x33, 0x30, 0x63, 0x39, 0x62, 0x34, 0x38, 0x30, 0x34, 0x38, 0x30, 0x30, 0x30, 0x30, 0x30, 0x30, 0x01, 0x70, 0x72, 0x74, 0x01, 0x36, 0x30, 0x30, 0x30, 0x01, 0x63, 0x6d, 0x64, 0x01, 0x30, 0x01, 0x73, 0x69, 0x64, 0x01, 0x34, 0x31, 0x38, 0x30, 0x37, 0x2c, 0x37, 0x30, 0x32, 0x34, 0x35, 0x32, 0x36, 0x32, 0x01};
And shields mac adress is/
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
So the view of the data in Wireshark are/
30 42 36 38 44 32 32 41 54 45 4d 49 4c 43 53 44 4e 41 4c 44 45 52 30 38 30 34 33 65 39 34 34 36 33 30 63 39 62 34 38 30 34 38 30 30 30 30 30 30 01 70 72 74 01 36 30 30 30 01 63 6d 64 01 30 01 73 69 64 01 34 31 38 30 37 2c 37 30 32 34 35 32 36 32 01 de ad be ef fe ed 01
In fact "de ad be ef fe ed 01" is send after the Packet !!! why and how can i do to not send this?
thanks
Hello. I'm one of the developers who maintains the Ethernet library....
Since this message was written, the Ethernet library has been updated to version 2.0.0.
mmoarduino:
If this problem still happens with Ethernet 2.0.0, please create a bug report here: (click the green "New issue" button)
Please provide a complete program which I can copy & paste into Arduino and upload to a board to recreate the wrong UDP packet problem. Please also mention which board and shield you are using. I can only investigate this problem if I receive a bug report on the issue tracker with enough clear info to recreate the problem.
