Mac OS 9 Development?
I'm running Mac OS 9.2.2. Can I use Arduino on my computer? I'm also using Metrowerks CodeWarrior Pro v6.
Gary
Good gods, man, you're living in the dark ages!!!
I would hazard a guess at ... um... no?
You could always try it though. Can you get (or do you have) java on that ancient system? If so you might be able to fudge it so the IDE would run. But the toolchain? No chance whatsoever!
Well the source code is available and if you're really determined it can probably be done ..., then again if you're asking the question the likelihood is not great that you'd be able to complete the work needed.
A more direct answer - I don't believe a version of the IDE for the old version of the platform exists. It'd require UNIX emulations layer that the earlier versions of Mac OS lack.
