Mach3 arduino modbus MPG RÉSOLUE
bonsoir
je voudrais utiliser arduino avec mach3 pour les IO's ; j'utilise le code de Tim W. avec Modbus_Slave.h.
tous vas pour le mieux sauf le Contrôle du MPG, impossible de faire fonction l'encoder avec les axes.
es que quelqu'un peut SVP me dire comment faire.
dans l'attente de vos lires , je vous remercie d'avance.
     Modbus Slave designed for Mach 3 CNC Software
 Written by: Tim W. Shilling, March 4, 2012.
 Released into the Public Domain
//  Supportted Functions
//  1:  Read Coil
//  2:  Read Descrete Input
//  3:  Read Holding Reg
//  4:  Read Input Reg
//  5:  Write Single Coil
//  6:  Write Single Reg
//  7   Read Exception
//  15: Write Multiple Coils
//  16: Write Multiple Holding Reg
// Notes on Timing:
// Original Design implemented Timer 1 and 0, but these conflict with the PWM generators
// Timers dropped for millis and micros functions.  Not as accurate but fine for this purpose
//################# INCLUDES #################
#include <Modbus_Slave.h>    // Ensure you have included the libraries in the Arduino Libraries folder
//################# DEFINES ##################
#define Baudrate 57600       //Desired Baud Rate, Recommend, 9600, 19200, 56800, 115200
#define Freq 16000000        //Don't Touch unless using a differnt board, Freq of Processor
#define Slave_Address 0x01   //Address of MODBus Slave
#define Kill_Time 2000       //2 Sec (2000msec) keep alive, 0 => OFF
//############  REGISTER DEFINES ############# // Each Register is 16bit
#define Digital_IO_Register 0
#define PWM_Register        10
#define AN_Register         30
#define Timer_Register      50
#define IO_Config_Register  60
#define Kill_IO_Register    70
#define PWMIOMap_Register   80
#define ANIOMap_Register    81
#define General_Config      90
#define Error_Register      91
#define Digital_IO_Pins     14   //Total number of Digital IO pins, Limits update scanner pin count
#define Number_Of_Registers 100
//############ GLOBAL VARIABLES ##############
unsigned char Data[256];                                         // All received data ends up in here, also used as output buffer
unsigned short Index = 0;                                        // Current Location in Data
unsigned short Register[Number_Of_Registers];                    // Where all user data, Coils/Registers are kept
ModBusSlave ModBus(Slave_Address,Register,Number_Of_Registers);  // Initialize a new ModBus Slave, Again, you must have my Arduino ModBusSlave Library
unsigned long Last_Time=0;
unsigned long Time = 0;
unsigned long LongBreakTime;                                            //Time for 3.5 characters to be RX
//################## Setup ###################
// Takes:   Nothing
// Returns: Nothing
// Effect:  Opens Serial port 1 at defined Baudrate
//          Configures all Pins
//          Initiallized Timer 1
  //################ Initialize IO #################     // 0 => Output, 1 => Input, opposite of normal Arduino, but my habit from other platforms, 0 looks like an O and 1 looks like an I
  Register[IO_Config_Register]    = 0b1111111111111111;  // UNO and MEGA  PIN 00-15
  Register[IO_Config_Register+1]  = 0b0000000000000000;  // MEGA          PIN 16-31
  Register[IO_Config_Register+2]  = 0b0000000000000001;  // MEGA          PIN 32-47
  Register[IO_Config_Register+3]  = 0b0000000000000000;  // MEGA          PIN 48-64
  Register[IO_Config_Register+4]  = 0b1111111111111111;  // AN Digital    PIN A0-A16
  //################ Kill IO Register #################  // 0 => Leave, 1 => Kill
  Register[Kill_IO_Register]    = 0b1111111111111111;    // UNO and MEGA  PIN 00-15
  Register[Kill_IO_Register+1]  = 0b1111111111111111;    // MEGA          PIN 16-31
  Register[Kill_IO_Register+2]  = 0b1111111111111111;    // MEGA          PIN 32-47
  Register[Kill_IO_Register+3]  = 0b1111111111111111;    // MEGA          PIN 48-64
  Register[Kill_IO_Register+3]  = 0b1111111111111111;    // AN Digital    PIN A0-A16
  //################ PWM IO Register #################   // 0 => Normal I/O, 1 => PWM I/O
  Register[PWMIOMap_Register]   = 0b0000111001100000;    // UNO and MEGA  PWM 01-16 0b0000111001101000
  //################ AN IO Register #################    // 0 => Digital, 1=> Analog
  Register[ANIOMap_Register]    = 0b0000000000000011;    // UNO and MEGA 0b1111111111111111
  Config_IO();
  LongBreakTime = (long)((long)28000000.0/(long)Baudrate);
  if(Baudrate > 19200)
    LongBreakTime = 1750;                                // 1.75 msec
  Serial.begin(Baudrate);                                // Open Serial port at Defined Baudrate
  Time = micros();                                       // Preload Time variable with current System microsec
//################ Main Loop #################
// Takes:   Nothing
// Returns: Nothing
// Effect:  Main Program Loop
unsigned long LongKillTime = (long)((long)Kill_Time * (long)1000);      //Time ellapsed between RX that causes system Kill
unsigned long Keep_Alive = 0;                                           // Keep Alive Counter Variable
  Update_Time();
  if(Keep_Alive >= LongKillTime){               // Communications not Received in Kill_Time, Execute Lost Comm Emerency Procedure
    if(Kill_Time != 0){                         // If Kill_Time is 0, then disable Lost Comm Check
      Keep_Alive = LongKillTime;                // Avoid Keep_Alive rollover
      ModBus.Error = 0xff;                      // Set error code to Lost Comm
      Register[Error_Register] = ModBus.Error;  // Set Error Register
      Kill_IO();                                // Kill what should be killed
      digitalWrite(13,1);                       // Indicate Error with Solid LED
    Update_Pin_States();                        // Update Digital Pins
    Update_AN_States();                         // Update Analog Pins
    if(ModBus.Error != 0){                      // Flash Error LED is ModBus Error != 0
      digitalWrite(13,bitRead(Time,11));        // Toggle LED
    else                                        // If no Error
      digitalWrite(13,0);                       // Turn off LED
  //######################## RX Data ###############################
  if (Serial.available() > 0)                   // If Data Avilable
    Data[Index] = (unsigned char)Serial.read(); // Read Next Char
    Keep_Alive = 0;                             // Reset Keep Alive counter
    Last_Time = micros();                       // Update Last_Time to current Time
    Index++;                                    // Move Index Counter Forward
  //##################### Process Data #############################
  if(Index > 0)                                 // If there are bytes to be read
    if(Keep_Alive >= LongBreakTime)             // Transmission Complete, 3.5 char spacing observered
      Register[Timer_Register] = (unsigned int)(millis() / 125.0);  // Converts to 1/8sec and load into Register
      ModBus.Process_Data(Data,Index);          // Process Data
      if(ModBus.Error == 0)                     // If no Errors, then...
        Last_Time = micros();                   // Set Last_Time to current time
      else                                      // If there was an error
        Register[Error_Register] = ModBus.Error;// Set Error Code
      Index = 0;                                // Reset Index to 0, no bytes to read
//################ Update Time #################
// Takes:   Nothing
// Returns: Nothing
// Effect:  Updates Timer Register
//          Updates KeepAlive Count
void Update_Time()
  Last_Time = Time;                             // Set Last_Time to Current Time
  Time = micros();
  if(Time < Last_Time)                          // Counter has rolled over, should take 70 Min
    Last_Time = 0;                              // Introduces a small clitch in timing by not accounting for how bad the roll over was.  Happens every 70 Min
                                                // Result is Delta will be smaller than it should be, Kill and Character Spacing will be usec longer than they should
  Keep_Alive += Time - Last_Time;               // Increment Keep Alive counter
//EOF
BONSOIR
Problème du MPG mach3 résolue.
Si sa peut aider quelqu'un voici la solution ,tres simple , bien sur, apres avoir galerais presque un moi .
dans le code du modbus avec mach3 y a pas besoin d'utilise le formule de l'encoder typique , il faut juste
ajouter la bibliothèque ENCODER.h bien sur , désigne les pins et , LE ET ;D assigner la valeur du
XXX.read() directement au registre que vous utiliser dans le BRAIN de mach3 voila tous simple.
