The machine stops while working. It only works if you disconnect and put back the connection.
What is the expected problem?
**** Connected to COM7 @ 115200 baud ****
Grbl 1.1h ['
for help]
$0 = 10 (Step pulse time, microseconds)
$1 = 25 (Step idle delay, milliseconds)
$2 = 0 (Step pulse invert, mask)
$3 = 0 (Step direction invert, mask)
$4 = 0 (Invert step enable pin, boolean)
$5 = 0 (Invert limit pins, boolean)
$6 = 0 (Invert probe pin, boolean)
$10 = 1 (Status report options, mask)
$11 = 0.010 (Junction deviation, millimeters)
$12 = 0.002 (Arc tolerance, millimeters)
$13 = 0 (Report in inches, boolean)
$20 = 0 (Soft limits enable, boolean)
$21 = 1 (Hard limits enable, boolean)
$22 = 1 (Homing cycle enable, boolean)
$23 = 0 (Homing direction invert, mask)
$24 = 25.000 (Homing locate feed rate, mm/min)
$25 = 500.000 (Homing search seek rate, mm/min)
$26 = 250 (Homing switch debounce delay, milliseconds)
$27 = 5.000 (Homing switch pull-off distance, millimeters)
$30 = 1000 (Maximum spindle speed, RPM)
$31 = 0 (Minimum spindle speed, RPM)
$32 = 0 (Laser-mode enable, boolean)
$100 = 800.000 (X-axis travel resolution, step/mm)
$101 = 800.000 (Y-axis travel resolution, step/mm)
$102 = 800.000 (Z-axis travel resolution, step/mm)
$110 = 1000.000 (X-axis maximum rate, mm/min)
$111 = 1000.000 (Y-axis maximum rate, mm/min)
$112 = 600.000 (Z-axis maximum rate, mm/min)
$120 = 30.000 (X-axis acceleration, mm/sec^2)
$121 = 30.000 (Y-axis acceleration, mm/sec^2)
$122 = 30.000 (Z-axis acceleration, mm/sec^2)
$130 = 300.000 (X-axis maximum travel, millimeters)
$131 = 180.000 (Y-axis maximum travel, millimeters)
$132 = 50.000 (Z-axis maximum travel, millimeters)
ok
$G
[GC:G0 G54 G17 G21 G90 G94 M5 M9 T0 F0 S0]
ok
[Error] Error while processing response <<Idle|MPos:0.0‚b‚r‚‚‚b‚r‚‚‚âMé0,0>>
<Idle|MPos:0.000,0.000,0.000|FS:0 ٍj
[Error] Error while processing response <<Idle|MPos:0.‚‚b‚r‚‚‚b‚r‚‚‚âMé0,0>>
[Error] Error while processing response <<Idle|MPké0.000,0.000,0.000|FS:0,0>>
[Error] Error while processing response <<Idle|MPos:0.000 r‚‚‚b‚r‚‚‚âMé0,0|Ov:100,100,100>>
[Error] Error while processing response <<Idle|MPos:0.000,r‚‚‚b‚r‚‚‚âMé0,0>>
[Error] Error while processing response <<Idle5A½حé0.000,0.000,0.000|FS:0,0>>
[Error] Error while processing response <<Idle|MPo.'r‚‚‚b‚r‚‚‚b‚r‚‚‚âMé0,0>>
<Idle|MPos:0.000,0.000,0.000|F*'b‚ٍj
[Error] Error while processing response <<Idle|MPos:0.000,0.000,r‚‚‚âMé0,0>>: empty String
[Error] Error while processing response <<IdlY5A½حé0.000,0.000,0.000|FS:0,0>>
[Error] Error while processing response <<Idle|Sُحé0.000,0.000,0.000|FS:0,0>>
[Error] Error while processing response <<Idle|MPos:0.000,0.00b‚r‚‚‚âMé0,0>>
[Error] Error while processing response <<Id«ٌ5A½حé0.000,0.000,0.000|FS:0,0>>
[Error] Error while processing response <<Idle|Mُحé0.000,0.000,0.000|FS:0,0>>
<Idle|MPos:0.000,0.000,0.000|FS:0,ٍj
[Error] Error while processing response <<Idle|MPos:0.000,0.0‚b‚r‚‚‚âMé0,0>>
[Error] Error while processing response <<Idle|MPos:0.000,0.000 r‚‚‚âMé0,0>>
<Idle|MPos:0.000,0.000,0.000|FS:0,0|Ov:1‚bٹ‚‚bٹ‚‚ٍj
[Error] Error while processing response <<I«ٌ5A½حé0.000,0.000,0.000|FS:0,0>>
[Error] Error while processing response <<Idle|MPos:0.000,0.0‚b‚r‚‚‚âMé0,0|Ov:100,100,100>>
<Idle|MPos:0.000,0.000,0.000|ش¥‚b‚ٍj
[Error] Error while processing response <<Idle|MPos:0.00b‚r‚‚‚b‚r‚‚‚âMé0,0>>
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000j
[Error] Error while processing response <<Id«ٌ5A½حé0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>>
[Error] Error while processing response <<Idle|MPos:0.000,0.‚‚b‚r‚‚‚âMé0,0>>
[Error] Error while processing response <<Idle|MPos:0.000,0.000,0.000|FS:0,0>Cل<Idle|MPos:0.000,0.000,0.000|FS:0,0>>: For input string: "0>Cل<Idle"
[Error] Error while processing response <<I«ٌ5A½حé0.000,0.000,0.000|FS:0,0|Ov:100,100,100>>
[Error] Error while processing response <<R«ٌ5A½حé0.000,0.000,0.000|FS:0,0>>
<Idle|MPos:0.000,0.000,0.000|FS:b‚ٍj
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:r‚‚‚b‚r‚‚‚b‚r‚‚‚ٍj
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0.000,0.000,0 ‚‚ٍj
[Error] Error while processing response <<Idle|MPos:0 ‚‚b‚r‚‚‚b‚r‚‚‚âMé0,0>>
[Error] Error while processing response <<Idle|MPos:r‚‚‚b‚r‚‚‚b‚r‚‚‚âMé0,0>>
<Idle|MPos:0.000,0.000,0.000|FS:0,0j
[Error] Error while processing response <<Idle|MPos:0.000 r‚‚‚b‚r‚‚‚âMé0,0>>
[Error] Error while processing response <<Idle|MPos:0.000,0 ‚‚b‚r‚‚‚âMé0,0|Ov:100,100,100>>
<Idle|MPos:0.000,0.000,0.000|FS:0,0|WCO:0 ‚‚b‚r‚‚‚b‚r‚‚‚ٍj
[Error] Error while processing response <<Idle|MPos'r‚‚‚b‚r‚‚‚b‚r‚‚‚âMé0,0>>
ل<Idle"
[Error] Error while processing response <<Idle|MPos:0.000,0.‚‚b‚r‚‚‚âMé0,0|Ov:100,100,100>>
[Error] Error while processing response <<Idle|MPos:0.000,0 ‚‚b‚r‚‚‚âMé0,0>>
