MacOS drivers for STM32 bootloader (blue pill)
I went through the following so far:
programmed the STM32 USB bootloader generic_boot20_pc13.bin into the blue pill.
I cannot see any STM32 related boards. From my understanding I first have to install the Maple drivers. I found instructions for Windows but lacking those for macOS.
To add some observation:
connecting the blue pill creates a device
crw-rw-rw-  1 root   wheel           22,  10  3 Nov 11:51 tty.usbmodem141301
crw-rw-rw-  1 root   wheel           22,  11  3 Nov 11:51 cu.usbmodem141301
and lsusb gives:
Bus 020 Device 027: ID 1eaf:0004 Leaflabs Maple serial interface
Looks like everything is there? Only I cannot add any STM32 boards in board manager. Funnily the entry at Port /dev/cu.usbmodem141301 is named "STM32 Marple bootloader". What has Miss Marple got to do with this? :open_mouth:
Seems I found the solution:
go into preferences, add additonal Boars URL:
http://dan.drown.org/stm32duino/package_STM32duino_index.json
The go to Board Manager and type in the search field "STM32". STM32F1xx gets listed. Install it.
Your topic title have been changed to better fit the question
Answered with the solution myself:
go into preferences, add additonal Boadrs URL:
Go into tools->Boardmanager
Enter STM32 in the search field
Choose STM32F1xx/GD32F1xx boards
Choose latest version,
Install
Go into Boards and choose Generic STM32F103C Series
Only programming seems to fail. When uploading a small blinky app, I'm getting:
dfu-util 0.8
dfu-util: Invalid DFU suffix signature
dfu-util: A valid DFU suffix will be required in a future dfu-util release!!!
Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.
Copyright 2010-2014 Tormod Volden and Stefan Schmidt
This program is Free Software and has ABSOLUTELY NO WARRANTY
Please report bugs to http://sourceforge.net/p/dfu-util/tickets/
Opening DFU capable USB device...
ID 1eaf:0003
Run-time device DFU version 0110
Claiming USB DFU Interface...
Setting Alternate Setting #2 ...
dfu-util: Invalid dfuse address: /private/var/folders/kc/xxxxx/T/AppTranslocation/xxxxx-xxxxx/d/Arduino.app/Contents/Java
Beim Hochladen des Sketches ist ein Fehler aufgetreten
Determining device status: state = dfuIDLE, status = 0
dfuIDLE, continuing
DFU mode device DFU version 0110
Device returned transfer size 1024
In the boards.txt file should be correct DFU signature for the board. Unfortunately, I am not in my PC now and can't look to my boards file
I'm inclined to think it's a dfu-util issue. Version or command line invocation and parameter passing. One could use another programmer, STM32CubeProgrammer. But how to set up the configuration for this I don't know.
I modified the maple_upload script and disabled the dfuse_addr parameter to being empty, being a dirty hack though.
#if [ $# -eq 5 ]; then
#    dfuse_addr="--dfuse-address $5"
#else
    dfuse_addr=""
#fi
