Macro fail
So i wrote this code for a vending machine type of code. Here it the code:
(And here it is using code tags, the </> button on the menu. Moderator)
int pengerTotal;
int brusPris = 8;
boolean reset = false;
 pinMode(2, INPUT_PULLUP); // 1 krone
 pinMode(3, INPUT_PULLUP); // 5 kroner
 pinMode(11, INPUT_PULLUP); // Coca-cola
 pinMode(12, INPUT_PULLUP); // Solo
 pinMode(4, OUTPUT);
 pinMode(5, OUTPUT);
 pinMode(6, OUTPUT);
 pinMode(7, OUTPUT);
 pinMode(8, OUTPUT);
 pinMode(9, OUTPUT);
 pinMode(10, OUTPUT);
 pinMode(13, OUTPUT); // LED (Grønn)
 if ((digitalRead(2) == LOW) && (pengerTotal < brusPris)) {
   pengerTotal = pengerTotal + 1;
   if (pengerTotal == 1) penger (0, 1, 1, 0, 0, 0, 0);
   if (pengerTotal == 2) penger (1, 1, 0, 1, 1, 0, 1);
   if (pengerTotal == 3) penger (1, 1, 1, 1, 0, 0, 1);
   if (pengerTotal == 4) penger (0, 1, 1, 0, 0, 1, 1);
   if (pengerTotal == 5) penger (1, 0, 1, 1, 0, 1, 1);
   if (pengerTotal == 6) penger (0, 0, 1, 1, 1, 1, 1);
   if (pengerTotal == 7) penger (1, 1, 1, 0, 0, 0, 0);
   if (pengerTotal == 8) penger (1, 1, 1, 1, 1, 1, 1);
   if (pengerTotal == 9) penger (1, 1, 1, 0, 0, 1, 1);
 if ((digitalRead(3) == LOW) && (pengerTotal < brusPris)) {
   pengerTotal = pengerTotal + 5;
   if (pengerTotal > brusPris) {
     pengerTotal = pengerTotal - 5;
 if (pengerTotal == brusPris && digitalRead(11) LOW || digitalRead(12) == LOW; {
 digitalWrite(12, HIGH);
   reset = true;
   delay(10000);
 if (reset == true); {
 pengerTotal = 0;
 penger(0, 0, 0, 0, 0, 0, 0);
   digitalWrite(12, LOW);
   reset = false;
void penger(int a, int b, int c, int d, int e, int f, int g) {  //these could be bytes, as none will exceed 255
 digitalWrite(4, a);
 digitalWrite(5, b);
 digitalWrite(6, c);
 digitalWrite(7, d);
 digitalWrite(8, e);
 digitalWrite(9, f);
 digitalWrite(10, g);
 return;
I get this error message:
C:\Users\dan\Desktop\Arduino\venmachine\venmachine.ino:46:50: note: in expansion of macro ‘LOW’
Any idea on how to solve this? If you need more info let me know.
Try explaining, in English, just what this statement is supposed to mean. LOW almost always appears, in an if statement, AFTER the == operator. The == operator NEVER appears outside of the parentheses of an if statement.
Finally, the presence of a semicolon at the end of an if statement is, 99.999999% of the time, completely wrong.
PengerTotal means Money total and the brusPris means drink cost. Its kinda hard translating for me..
You need == between (11) and LOW, and delete the ; at the end.
I would also add more ( ) in that line.
 if ((pengerTotal == brusPris) && ((digitalRead(11) == LOW) || (digitalRead(12) == LOW))} {
Or perhaps
 if ((pengerTotal == brusPris) && (digitalRead(11) == LOW)) || (digitalRead(12) == LOW)} {
I like your penger() function.
That is a lot cleaner than many examples I have seen to drive a 7 segment display when a complete port is not available and the outputs are across multiple ports.
Haha thanks! I got some help today to make this code, im rather new to this. I know got the stupidest error, but my head has had enough of this today:
If i could get help on the last error i showed it would be great, i literally cant find where the error is
The compiler generates text, not pictures. Post the TEXT of the error message AND the code that causes it AS TEXT!
For a start the ; after the close bracket is rubbish - remove it.
if (reset == true) {
Most likely it seem the error relates to the statement BEFORE the IF since the message says...
"expected ")" before "if"
Missing equals in the previous if...
Ends with a ;, instead of a close bracket )...
Correct code:
 if (pengerTotal == brusPris && digitalRead(11) == LOW || digitalRead(12) == LOW) {
    reset = true;
    delay(10000);
You're also probably missing some brackets. This logic...
(pengerTotal == brusPris && digitalRead(11) == LOW) || digitalRead(12) == LOW
Is NOT the same as this logic...
pengerTotal == brusPris && (digitalRead(11) == LOW || digitalRead(12) == LOW)
C has a precedence for && and ||, but I certainly don't remember what it is. I expect 99% of C programmers are the same and use brackets to ensure understanding.
