Maduino 4G Zero Sim Module & MPU9250 Sensor Port Problem
I am using a Maduino Zero 4G LTE(CAT1 A7670) [Maduino Zero 4G LTE(CAT1 A7670) | Makerfabs]. It is an Arduino zero-based board. I'm trying to create a GPS tracker with a dead reckoning (DR) system. I use an MPU9250 sensor [MPU9250 9-DOF 3-Axis Accelerometer, Gyro, & Magnetometer - No Warranty – Makerlab Electronics] for my DR system, but I have a problem when I try it with the module. After uploading the code to the module to test the sensor, the module won't connect to my laptop. The port started malfunctioning, and I couldn't use my module after that. The USB device is not recognized anymore.
This is the code I uploaded:
#include "mpu9250.h"
// Define an MPU9250 object
bfs::Mpu9250 IMU;
  Wire.begin();
  Wire.setClock(400000);
  bool status = IMU.Begin(); // Begin function does not require any arguments
  if (status) {
    // Handle error
    Serial.println("Error initializing MPU9250");
    while (1); // This will halt the program
  // Read the IMU data
  if (IMU.Read()) {
    float ax = IMU.accel_x_mps2();
    float ay = IMU.accel_y_mps2();
    float az = IMU.accel_z_mps2();
    float gx = IMU.gyro_x_radps();
    float gy = IMU.gyro_y_radps();
    float gz = IMU.gyro_z_radps();
    float hx = IMU.mag_x_ut();
    float hy = IMU.mag_y_ut();
    float hz = IMU.mag_z_ut();
    // Print the sensor data
    Serial.print("Accel X: "); Serial.print(ax);
    Serial.print("\tAccel Y: "); Serial.print(ay);
    Serial.print("\tAccel Z: "); Serial.print(az);
    Serial.print("\tGyro X: "); Serial.print(gx);
    Serial.print("\tGyro Y: "); Serial.print(gy);
    Serial.print("\tGyro Z: "); Serial.print(gz);
    Serial.print("\tMag X: "); Serial.print(hx);
    Serial.print("\tMag Y: "); Serial.print(hy);
    Serial.print("\tMag Z: "); Serial.print(hz);
I used the bolder flight systems InvenSense IMU, eigen, and unit conversions. I didn't have any problem when compiling.
I wonder if this module has a code reset or hardware reset option. Can I fix this? I hope someone can help me; I can't afford to spend another module since I tried to budget with what I planned for my thesis.
