Maduino Zero SIM808 GPS Tracker v3.5
Hello ,
I’m using the Maduino Zero SIM808 GPS Tracker v3.5
and I have some problem after reboot the device it’s seem that the unit won’t start
only after connect the usb and open terminal it start to work .
after I open the terminal - all he code work great
I guess it something in the setup part
can someone tell me wht is wrong ?
#include<stdio.h>
#include<string.h>
#define DEBUG true
int POWER_KEY = 9;
bool SIM808_ON = false;
String answer = "";
int answer_size = 0;
String CIPSEND = "";
String UnitName = "Device1";
  pinMode(POWER_KEY, OUTPUT);
  //********Turn on SIM808 when power up*********
  digitalWrite(POWER_KEY, HIGH);
  digitalWrite(POWER_KEY, LOW);
  SerialUSB.begin(115200);
  delay(2000);
  while (!SerialUSB) {
    delay(50); // wait for Arduino Serial Monitor to connect the port
  SerialUSB.println("Start to run! V1.6 ");
  Serial1.begin(115200);
  //********check open************
  sendData("AT", 1000, DEBUG);
  //********if SIM808 off, turn on it*********
  if (!SIM808_ON)
    delay(3000);
    SerialUSB.println("Turn on SIM808");
    delay(10000);
  //GPS test
  sendData("AT+CGNSPWR=1", 1000, DEBUG);//GNSS POWER CONTROL ON
  sendData("AT+CGNSSEQ=\"RMC\"", 1000, DEBUG);//
  sendData("AT+CGNSURC=0", 1000, DEBUG);// printf to serial every 1 second
void loop ()
//rest of the code
String sendData(String command, const int timeout, boolean debug)
  String response = "";
  Serial1.println(command);
  String commandpre = getcommand_pref(command);
  //SerialUSB.println(commandpre);
  long int time = millis();
  while ( (time + timeout) > millis())
    if (commandpre == "AT") {
      if (Serial1.find("OK")) {
        SIM808_ON = true;
        SerialUSB.println("SIM808 opened");
    while (Serial1.available())
      String c = Serial1.readString();
      response += c;
  if (debug)
    SerialUSB.println(response);
  return response;
String getcommand_pref(String command) {
  String command_pref = "";
  char *cstr = new char[command.length() + 1];
  strcpy(cstr, command.c_str());
  char * token = strtok(cstr, "=");
  int i = 0;
  while (token != NULL) {
    //SerialUSB.print(token);
    //SerialUSB.println("  line" + (String)i);
    switch (i) {
      case 0:
        command_pref = token;
      default:
    token = strtok(NULL, ",");
    i = i + 1;
  if (command_pref == "")
    command_pref = command;
  return command_pref;
I want\need it to start working after I connect the power to it
Does someone see the problem ?
Thanks ,
