Magnetic Levitation
Hey everybody. I was trying to follow along with this exampleHERE and I just can’t get it to work. There’s a few things in the code that just don’t make sense to me and I’m hoping someone can help me out. I did my best to reverse engineer the code just to see exactly what it is doing and I even tried to write my own version but it was even worse.
There are of course differences in our setup. For example, I have a ~10ohm coil(according to the comments in the code this somehow affect PWM value?) and my power supply is 12V2A. With the COIL_IDLE_VALUE = 50, for example, my sensor puts out a value at ~700. With that in mind I put the set point to 730, but it just gets sucked up every time.
Questions:
The PWM control seems different between Pins 3 and 11, does it matter what pin I use?
Can you tell what CONTROL_BIAS is for if/how it affects anything?
Is there a way to calculate best value for PWM with my setup?
PID values, is there any way to calculate those without wildly guessing?
I found a PID library and a PIDAutotune library in the Playground but I just couldn’t figure out how to integrate it into the code. There any way to do that here?
The code put my post over 9000 characters :frowning:
MagneticLevitation.ino (7.38 KB)
The code on it’s own fits:-
   Magentic Levitation
   1) connect the digital pin PIN_COIL to the MOSFET gate for electromagnet activation.
   2) connect the analog input pin PIN_HALL_SENSOR to the hall sensor signal pin (the other
      two pins shall be wired to gnd and +5V).
   3) (optional) connect the digital pin PIN_CTRL_INDICATOR to the LED that indicates when the
      controller loop is running.
   4) run Arduino, on the serial port the following commands are available:
      - press 's' or 'S' to decrease or increase the setpoint,
      - press 'p' or 'P' to decrease or increase the P gain,
      - press 'd' or 'D' to decrease or increase the D gain,
      - press 'i' or 'I' to decrease or increase the I gain,
      - press 'x' or 'X' to show the current settings
   5) the system enters in IDLE mode, with a minimum PWM command that allows the orientation of the
      permanent magnet, when in range the system goes in CONTROL mode. When the magnet is too close to
      the coil, the system switches in OFF mode by turning off the PWM command.
   version 1.0: 23/12/2011 -  E.Assenza
const int PIN_COIL = 11; // Pins 3 and 11 are connected to Timer 2.
const int PIN_HALL_SENSOR = 1;
const int PIN_CTRL_INDICATOR = 8;
// Coil resistance 3 ohm, max 1 A = 3 Volt max.
const int COIL_MAX_PWM_VALUE = 160;
// Minimum magnetic field when in idle mode (needed to properly orientate the magnet).
const int COIL_IDLE_VALUE = 50;
// Proximity thresholds, when the magnetic field is in this range enters in control mode.
const int MAG_PROX_THRESHOLD_MIN = 585;
const int MAG_PROX_THRESHOLD_MAX = 615;
// Magnetic field limits, when outside this range enters in idle mode.
const int MAG_LIMIT_MIN = 560;
const int MAG_LIMIT_MAX = 700;
// Control loop frequency.
const int CTRL_LOOP_PERIOD_MS = 1;
// Control loop bias value (PWM midpoint)
const int CONTROL_BIAS = 65;
// Set point corresponding to the control bias
const int CONTROL_SETPOINT = 597;
const int MAX_ERR_INTEGRAL = 10000;
// PID controller parameters
const float PGain = 2.1;
const float DGain = 23.6;
const float IGain = 0.001;
const float P_INCR = 0.1;
const float D_INCR = 0.1;
const float I_INCR = 0.001;
// State machine constants.
const byte MODE_OFF = 0;
const byte MODE_IDLE = 1;
const byte MODE_CONTROL = 2;
const char     *gAppName = "Arduino Magnetic Levitation";
byte            gMode;
int             gSetPoint;
int             gSensorReadout;
int             gPrevSensorReadout;
int             gPwmCommand;
int             gIntegral;
float           gBias;
float           gP;
float           gD;
float           gI;
unsigned long   gMillisCounter;
void setupCoilPWM()
   // Setup the timer 2 as Phase Correct PWM, 3921 Hz.
   pinMode(3, OUTPUT);
   pinMode(11, OUTPUT);
   // Timer 2 register: WGM20 sets PWM phase correct mode, COM2x1 sets the PWM out to channels A and B.
   TCCR2A = 0;
   TCCR2A = _BV(COM2A1) | _BV(COM2B1) | _BV(WGM20);
   // Set the prescaler to 8, the PWM freq is 16MHz/255/2/<prescaler>
   TCCR2B = 0;
   TCCR2B = _BV(CS21);
void writeCoilPWM(uint8_t pin, int val)
   if( pin == 3 )
      OCR2B = val;
   else if( pin == 11 )
      OCR2A = val;
      OCR2A = 0;
      OCR2B = 0;
void processCommand( int cmd )
   char tmp[64];
   switch(cmd)
      case 'p':
         gP -= P_INCR;
         if( gP < 0 ) gP = 0;
      case 'P':
         gP += P_INCR;
      case 'd':
         gD -= D_INCR;
         if( gD < 0 ) gD = 0;
      case 'D':
         gD += D_INCR;
      case 'i':
         gI -= I_INCR;
         if( gI < 0 ) gI = 0;
      case 'I':
         gI += I_INCR;
      case 's':
         gSetPoint --;
      case 'S':
         gSetPoint ++;
      case 'x':
      case 'X':
         sprintf(tmp, "s(%d) c(%d) h(%d) P(%u) D(%u) I(%u,%d)\n", gSetPoint, gPwmCommand, gSensorReadout, (uint16_t)(gP*1000.0), (uint16_t)(gD*1000.0), (uint16_t)(gI*1000.0), gIntegral );
         Serial.print(tmp);
      default:
byte executeOffMode()
   digitalWrite(PIN_CTRL_INDICATOR, LOW);
   // turn off magnetic field
   gPwmCommand = 0;
   writeCoilPWM(PIN_COIL, gPwmCommand);
   gSensorReadout = analogRead(PIN_HALL_SENSOR);
   if( gSensorReadout <= MAG_LIMIT_MIN )
      // Switch to idle mode.
      return MODE_IDLE;
      return MODE_OFF;
byte executeIdleMode()
   // Apply minimum magnetic field.
   gPwmCommand = COIL_IDLE_VALUE;
   if( (gSensorReadout >= MAG_PROX_THRESHOLD_MIN) && (gSensorReadout <= MAG_PROX_THRESHOLD_MAX) )
      // Switch to control mode.
      gIntegral = 0;
      return MODE_CONTROL;
   else if( gSensorReadout > MAG_LIMIT_MAX )
      return MODE_OFF;
      return MODE_IDLE;
byte checkOutOfLimits(int val)
   if( val <= MAG_LIMIT_MIN )
      return MODE_IDLE;
   else if( val >= MAG_LIMIT_MAX )
      return MODE_OFF;
byte executeControlMode()
   int err;
   int der;
   byte mode = MODE_CONTROL;
   // Execute control loop at frequency = 1/CTRL_LOOP_PERIOD_MS.
   if( (signed long)( millis() - gMillisCounter ) >= 0)
      gMillisCounter = millis() + CTRL_LOOP_PERIOD_MS;
      digitalWrite(PIN_CTRL_INDICATOR, HIGH);
      gPrevSensorReadout = gSensorReadout;
      // Read hall sensor.
      // Check if out of limits (the magnet is out of coil range).
      if( (mode = checkOutOfLimits(gSensorReadout)) != MODE_CONTROL )
         return mode;
      err = (gSetPoint - gSensorReadout);
      der = (gPrevSensorReadout - gSensorReadout);
      gIntegral += err;
      gIntegral = constrain( gIntegral, -MAX_ERR_INTEGRAL, MAX_ERR_INTEGRAL);
      gPwmCommand = gBias + (int)(gP*err) + (int)(gD*der) + (int)(gI*gIntegral);
      gPwmCommand = constrain( gPwmCommand, 0, COIL_MAX_PWM_VALUE);
      // Apply output.
      // Write data to serial port.
      Serial.write( (uint8_t)0xAF );
      Serial.write( (uint8_t)gSetPoint );
      Serial.write( (uint8_t)(gSetPoint >> 8) );
      Serial.write( (uint8_t)gSensorReadout );
      Serial.write( (uint8_t)(gSensorReadout >> 8) );
      Serial.write( gPwmCommand );
   return mode;
   setupCoilPWM();
   pinMode(PIN_CTRL_INDICATOR, OUTPUT);
   gMillisCounter = 0;
   gMode = MODE_IDLE;
   gSetPoint = CONTROL_SETPOINT;
   gBias = CONTROL_BIAS;
   gSensorReadout = 0;
   gIntegral = 0;
   gP = PGain;
   gD = DGain;
   gI = IGain;
   // User commands.
   if( Serial.available() )
      processCommand( Serial.read() );
   // State machine.
   switch( gMode )
      case MODE_OFF:
         gMode = executeOffMode();
      case MODE_IDLE:
         gMode = executeIdleMode();
      case MODE_CONTROL:
         gMode = executeControlMode();
      default:
OK thanks
Have you got the halleffect sensor facing the right way?
Or have you got the current going through the coil the right way?
Tom... :slight_smile:
Yeah, the sensor and current are definitely going the right way.
UPDATE: I've been messing around with the values and I'm able to levitate a magnet for maybe 2 seconds before it starts oscillating and falls down. After that, I eliminated the Derivative controller and got even better times but it still starts oscillation and falls.
What are you using as a power supply?
Tom.. :slight_smile:
It's AC-DC wall wart. It's output is 12V 2A.
Can you measure the 12V supply while the project is operating, and when it starts to have problems please?
Thanks.. Tom.. :slight_smile:
It stays at 12V constantly.
What happens if you remove (zero) D and I of your PID?
Hey! what values do you use for it to stay for some time before oscillation, my own is still oscillating could any body help please?
I have over come the oscillation with the pull up levitation by using an H-bridge .
When the reading on the hall effect sensor is 12 points above the levitation value the polarity of the electromagnet is reversed to push down on the levitated magnet. Just a little tap to stop the bounce.
the magnet stays suspended for ever if not Jared.
