Magnetic Levitation
Hello,
I am working on a Magnetic Levitation project using Arduino. I was using Arduino Unobut somehow I burnt the board. Now I have a Arduino Mega 2560. Can the same code for Arduino Uno work for Mega? I am attaching the code below. thank you for your help.
Shambo Mukherjee
int anaPin = 1; // Arduino Analogic Pin 1;
int digPin = 5; // Arduino Digital Pin 5;
int subPin = 7; // Arduino Digital Pin 7;
int addPin = 8; // Arduino Digital Pin 8;
int anaVal = 0; // Analogic Read(Hall Sensor) Value;
boolean digVal = 0; // Digital Write(Electromagnet) Value;
int levVal = 228; // Levitation Poit Value;
int dlyVal = 250; // Delay Value Micro Seconds;
// Levitator initialization Begin;
Serial.begin(57600);
Serial.println("Levitator");
Serial.println("Starting...");
// Digital Pins Work Mode Setup;
pinMode(digPin, OUTPUT);
pinMode(subPin, INPUT_PULLUP);
pinMode(addPin, INPUT_PULLUP);
// Levitator initialization End;
Serial.println("Started.");
// Hall Sensor Read (Magnetic Field Intensity);
anaVal = analogRead(anaPin);
// Increase The Value Of Levitation Point;
if (digitalRead(addPin) == LOW)
levVal++;
value_log();
delay(250);
// Decrease The Value Of Levitation Point;
if (digitalRead(subPin) == LOW)
levVal--;
value_log();
delay(250);
// Check the Levitation Point;
if (anaVal < levVal)
digVal = LOW;
else // if (anaVal > levVal)
digVal = HIGH;
// Turn ON/OFF The Electromagnet;
// With Base on Sensor Value and the Levitation Point;
digitalWrite(digPin, digVal);
delayMicroseconds(dlyVal);
void value_log()
// Analogic/Digital/Levitation Values Print;
// Show the Hall Sensor Value;
Serial.print("anaVal=[");
Serial.print(anaVal);
Serial.print("]-");
// Show the Electromagnet state On=1/Off=0;
Serial.print("digVal=[");
Serial.print(digVal);
Serial.print("]-");
// Show the Levitation Point Value;
Serial.print("levVal=[");
Serial.print(levVal);
Serial.println("];");
      levVal++;
      value_log();
      delay(250);
      levVal--;
      value_log();
      delay(250);
There can, potentially, be a long time between reading the "current" value and using the value.
It would be better if the value was actually current at the time you use it.
There is nothing in that code that cares which Arduino it is running on.
Ok thank you so much
