Maybe not a best idea for a topic but what is called the chip or component
they use on bicycles or to measure the speed of a motor thru a magnetic
field. I remember how it works and what is it for but I don't remember the
actual name.
(magnetic sensor)
Comes in a transistor form way with 3 pins or like a zener diode tube or the
chip style with 3~4pins.
Domino60:
Yep, thanks a lot, that's what I was looking for.
Which one Hall or Reed? I'm gonna guess reed, due to your physical appearance comparison to a zener diode. Reed switches are often small glass tubes.
I've a general question - why glass and not plastic? I have broken several reed switches while making on/off switches for 'altoids box' circuits. They are soo delicate!
My opinion about hall and reed.
Reed switches in a glass tube are good for big magnetic fields/magnets cause they come in
different dimensions and different magnetic fields (stronger..etc) and they are easy to be protected
in a thin layer of hot glue or heat shrink tube or both not making a mess.
Hall magnetic chip's serve more purposes and they are sensitive to magnetic fields like a coil from
a motor or transformer, it's really good for sensitive measures like cables in the wall ..etc
For example for a bicycle to measure the speed I would of chose hall cause they are more sensitive
and can measure faster the change of a magnetic fiend while the wheel spins really fast, in the other
way the reed tube switch if there is no a strong enough magnetic field it will not activate in every
spin of the wheel and give you wrong data/speed.
