I recently began attending school at college, and every student is issued an ID that has a magnetic strip on the back like a credit card.
I'd like to have my Arduino be able to pull the raw data off a swiped card and be able to do different actions based on which (different roomates) card is swiped.
I don't have much experience with Arduino programming, so I'm looking for guidance on a sketch + card reader that should work with the controller or a tutorial on how to wire up the reader. I've searched around at other projects, but haven't found one with a link to buy the same reader to ensure that it will work. My budget is about $25 for the reader.
Sorry for walking in cold on the topic and thanks for any help!
Mag readers are mostly 3 wire systems. I replaced them many times in ATMs and gas pumps as well as time clocks. You would be better off buying an OEM replacement for a machine like that since its wires and not USB. But I would think you could snip the end and find its very much the same. If you wanted another route you can look at this http://www.ebay.com/itm/Magnetic-Stripe-Card-Reader-Magtek-21045002-/110747797136?pt=LH_DefaultDomain_0&hash=item19c9154690
Or many others like it on ebay. Although I've never seen one with so many wires so it code be a dual reader.
I've been reading some more on the topic, and while I'm about to give up and use a USB reader with a laptop instead, the possibility of using a Square Credit Card Reader as my card reader instead is very tantalizing.
Square makes a card reader that plugs into phones as a mic input, and then their software reads cards. I've plugged the reader into a mic input on my PC, and swiping a card generates a tangible waveform as an audio signature.. I feel like if I knew just a little bit more about what I'm doing, I'd be able to decode the audio and identify the dorm cards we're using.
I bought a used Magtek Ps/2 reader (for about 17 usd) and works pretty well with my arduino
Really easy to use, just add the keyboard library and I replaced some strings in the interpretation. And the SD shield was homemade from a chinese sd reader ~2-3 usd so you are still on budget hehehe.
When I swipe my school's id, I get this string of ascii numbers:
981721502142461182224624686172182182222286111150
I'm wondering if anyone has any insight to get this data into a readable format. In the reader's datasheet it says the data should be separated like this:
Track 1 start character?? End character??
Track 2 start character?? End character??
Track 3 start character?? End character??
Enter key is end character of the whole data packet.
I guess that Serial.print is giving you a decimal representation of the ascii code received from the reader, but since you haven't separated the bytes it's impossible to tell what the byte values were.
If you think the values are ascii characters, you could convert the byte to a char before printing which would cause the print method to print the byte as-is. However, if it encountered a non-printable character then the output may not be too helpful. It's worth a try though, just in case it turns out that the data is actually printable ascii.
If it's not ascii then you can either print it in decimal with a separator (for example, space) between each byte, or print it in hex so that the number of characters printed per byte is known.
Several years ago I bought a surplus $5 mag card reader from electronics goldmine. It was a basic model with just a clock and a data signal line and I believe it was a track 2 only reader. Track 1 is what the majority of the cards (or at least the most common) use only, I think I read in my research at the time.
There was a arduino sketch someone posted at the time to get the arduino to decode the data stream and resend it out the serial port. It worked pretty well, but all the various cards I swiped just tended to have a rather long random series of numbers as your example. Note below in the specs that there is a standard defined ASCII start and end character for the protocol. My sketch showed those start and ending characters, where your serial data version is a higher level unit and may strip off the message start and stop characters.
I suspect that most issurers of these cards just put a long unique random number onto the card that then their central computer systems uses as an ID index into their complete database for the holder of the card. Only my Calif Drivers licence seem to have a simple clear text data which I recall correctly was the license number (same as printed on the front) and my data of birth. So I think most just record straight ASCII number characters on them as you have printed on your posting.
Data packet format??Suitable to all magnetic card reader?
Subject Specification
Track standard Comply with ISO7811
Decoding method F2F (FM)
Starting character Track 1“%” Track 2“?” Track 3“+”
Card reading Data bit
Track 1 79
Characters (7-bit)
Track 2 40
Characters(5-bit)
Track 3 107
characters(5-bit)
Card thickness 0.2~0.84 mm
Suitable Voltage DC5V±0.5V
Static current 10mA/5V
Track reading width 1.5mm
Magstripe passing speed 15 - 120 cm/sec (6-50inch/sec)
Magnetic head life span More than 800,000 passes
Error rate Lower than 0.5%
Interface RS232,USB,PS/2 Track 3 start character?? End character??
Are these the byte separations you're referring to @PeterH? I have a feeling that this isn't ASCII now, however, as that didn't really help. Do you think you could tell me how to find out the number of characters per byte, or pass along any further ideas in decoding this? I would be very much appreciate your help!!
Sorry for bumping an old thread, but I see the Arduino Mega has a USB-to-TTL converter. Would buying a USB magnetic card reader still work for the tutorials online provided I use the USB-to-TTL converter built onto the board?
Spongeworthy:
