Hi, recently after having performed and validated the calibration of my sensors I tried to use the Mahony filter to correctly acquire yaw pitch roll, only that I keep getting the tuning wrong because the data doesn't add up to me.
the magnetometer, accelerometer and gyroscope have already been calibrated and verified with specific codes (magnetic north heading and values around the axes for gyro and acc). now on this code I tried to change the Kp and Ki gains but nothing, the data is never consistent with the movements.
So I'm asking if I'm doing something wrong in the code and how to correctly tune the filter (what procedure to do, I had tried the Ziegler Nichols method but nothing works)
#include <Wire.h>
#include <math.h>
/*MPU6050*/
#define MPU6050_ADDRESS 0x68
#define MPU6050_REG_ACCEL_XOUT_H 0x3B
#define MPU6050_REG_GYRO_XOUT_H 0x43
float accBiasX = 0, accBiasY = 0, accBiasZ = 0;
float gyroBiasX = 0, gyroBiasY = 0, gyroBiasZ = 0;
/*QMC5883L*/
#define QMC5883L_ADDRESS 0x0D
#define QMC5883L_REG_X_LSB 0x00
#define QMC5883L_REG_Y_LSB 0x02
#define QMC5883L_REG_Z_LSB 0x04
// Definizione dei valori di CAL_PARAM
float CAL_PARAM[9] = {-0.0150011772491854,-0.0106985402435778,0.0355930495987404,0.610897253682805,0.582287592807394,0.592696731175137,0.0762073179374682,0.0361950160491302,0.0452707353405034};
float h_calib[3]; // Vettore per i risultati della calibrazione
/*MAHONY*/
#define Kp 30.0
#define Ki 0.00
static float declination = 3.7;
unsigned long now = 0, last = 0; //micros() timers
float deltat = 0; //loop time in seconds
unsigned long now_ms, last_ms = 0; //millis() timers
unsigned long print_ms = 100; //print every "print_ms" milliseconds
static float q[4] = {1.0, 0.0, 0.0, 0.0};
static float yaw, pitch, roll; //Euler angle output
/*SET GLOBAL*/
Wire.begin();
pinMode(2, OUTPUT);
/*SET MPU6050*/
Wire.beginTransmission(MPU6050_ADDRESS);
Wire.write(0x6B); // Power Management register
Wire.write(0); // Accendi il dispositivo (wakes up the MPU-6050)
Wire.endTransmission(true);
/*SET QMC5883L*/
Wire.beginTransmission(QMC5883L_ADDRESS);
Wire.write(0x09); // Registri di controllo
Wire.write(0x0D); // Modalità continuativa con 50Hz
Wire.endTransmission();
/*CALIB MPU6050*/
calibrateMPU6050();
/* DATA MPU6050*/
int16_t accX, accY, accZ;
int16_t gyroX, gyroY, gyroZ;
Wire.write(MPU6050_REG_ACCEL_XOUT_H);
Wire.endTransmission(false);
Wire.requestFrom(MPU6050_ADDRESS, 6);
if (Wire.available() >= 6) {
accX = Wire.read() << 8 | Wire.read();
accY = Wire.read() << 8 | Wire.read();
accZ = Wire.read() << 8 | Wire.read();
// Leggi i dati del giroscopio dal MPU6050
Wire.write(MPU6050_REG_GYRO_XOUT_H);
gyroX = Wire.read() << 8 | Wire.read();
gyroY = Wire.read() << 8 | Wire.read();
gyroZ = Wire.read() << 8 | Wire.read();
/*CALIB MPU6050*/
float accX_calibrated = ((float)accX - accBiasX) / 16384.0 * 9.81;
float accY_calibrated = ((float)accY - accBiasY) / 16384.0 * 9.81;
float accZ_calibrated = ((float)accZ - accBiasZ) / 16384.0 * 9.81;
float gyroX_calibrated = ((float)gyroX - gyroBiasX) / 131.0;
float gyroY_calibrated = ((float)gyroY - gyroBiasY) / 131.0;
float gyroZ_calibrated = ((float)gyroZ - gyroBiasZ) / 131.0;
/*DATA QMC5883L*/
int16_t magX, magY, magZ;
Wire.write(QMC5883L_REG_X_LSB);
Wire.requestFrom(QMC5883L_ADDRESS, 6);
magX = Wire.read() | (Wire.read() << 8); // legge dato, poi legge segno e sposta sx
magY = Wire.read() | (Wire.read() << 8);
magZ = Wire.read() | (Wire.read() << 8);
/*CALIB QMC5883L*/
float magX_scaled = ((float)magX * 2.0) / 32767.0;
float magY_scaled = ((float)magY * 2.0) / 32767.0;
float magZ_scaled = ((float)magZ * 2.0) / 32767.0;
// Definizione dei valori mX_s, mY_s, mZ_s
float mX_s = ((float)magX * 2.0) / 32767.0;
float mY_s = ((float)magY * 2.0) / 32767.0;
float mZ_s = ((float)magZ * 2.0) / 32767.0;
// Applicazione della formula di calibrazione
h_calib[0] = (mX_s - CAL_PARAM[0]) / CAL_PARAM[3];
h_calib[1] = ((mY_s - CAL_PARAM[1]) / CAL_PARAM[4] - ((mX_s - CAL_PARAM[0]) / CAL_PARAM[3]) * sin(CAL_PARAM[6])) / cos(CAL_PARAM[6]);
h_calib[2] = ((mZ_s - CAL_PARAM[2]) / CAL_PARAM[5] - ((mX_s - CAL_PARAM[0]) / CAL_PARAM[3]) * sin(CAL_PARAM[7]) * cos(CAL_PARAM[8]) - (sin(CAL_PARAM[8]) / cos(CAL_PARAM[6])) * ((mY_s - CAL_PARAM[1]) / CAL_PARAM[4] - (mX_s - CAL_PARAM[0]) / CAL_PARAM[3]) * sin(CAL_PARAM[6])) / (cos(CAL_PARAM[7]) * cos(CAL_PARAM[8]));
/*MAHORY UPDATE*/
now = micros();
deltat = (now - last) * 1.0e-6; //seconds since last update
last = now;
MahonyQuaternionUpdate(accX_calibrated, accY_calibrated, accZ_calibrated, gyroX_calibrated, gyroY_calibrated, gyroZ_calibrated,
h_calib[0], h_calib[1], h_calib[2], deltat);
roll = atan2((q[0] * q[1] + q[2] * q[3]), 0.5 - (q[1] * q[1] + q[2] * q[2]));
pitch = asin(2.0 * (q[0] * q[2] - q[1] * q[3]));
yaw = atan2((q[1] * q[2] + q[0] * q[3]), 0.5 - ( q[2] * q[2] + q[3] * q[3]));
// to degrees
yaw *= 180.0 / PI;
pitch *= 180.0 / PI;
roll *= 180.0 / PI;
// http://www.ngdc.noaa.gov/geomag-web/#declination
//conventional nav, yaw increases CW from North, corrected for local magnetic declination
yaw = -yaw + declination;
if(yaw<0) yaw += 360.0;
if(yaw>360.0) yaw -= 360.0;
now_ms = millis(); //time to print?
if (now_ms - last_ms >= print_ms) {
last_ms = now_ms;
// print angles for serial plotter...
// Serial.print("ypr ");
Serial.print(yaw, 0);
Serial.print(", ");
Serial.print(pitch, 0);
Serial.print(", ");
Serial.println(roll, 0);
void MahonyQuaternionUpdate(float ax, float ay, float az, float gx, float gy, float gz, float mx, float my, float mz, float deltat){
// Vector to hold integral error for Mahony method
static float eInt[3] = {0.0, 0.0, 0.0};
// short name local variable for readability
float q1 = q[0], q2 = q[1], q3 = q[2], q4 = q[3];
float norm;
float hx, hy, bx, bz;
float vx, vy, vz, wx, wy, wz;
float ex, ey, ez;
// Auxiliary variables to avoid repeated arithmetic
float q1q1 = q1 * q1;
float q1q2 = q1 * q2;
float q1q3 = q1 * q3;
float q1q4 = q1 * q4;
float q2q2 = q2 * q2;
float q2q3 = q2 * q3;
float q2q4 = q2 * q4;
float q3q3 = q3 * q3;
float q3q4 = q3 * q4;
float q4q4 = q4 * q4;
// already done in loop()
// Normalise accelerometer measurement
norm = sqrt(ax * ax + ay * ay + az * az);
if (norm == 0.0f) return; // Handle NaN
norm = 1.0f / norm; // Use reciprocal for division
ax *= norm;
ay *= norm;
az *= norm;
// Normalise magnetometer measurement
norm = sqrt(mx * mx + my * my + mz * mz);
mx *= norm;
my *= norm;
mz *= norm;
// Reference direction of Earth's magnetic field
hx = 2.0f * mx * (0.5f - q3q3 - q4q4) + 2.0f * my * (q2q3 - q1q4) + 2.0f * mz * (q2q4 + q1q3);
hy = 2.0f * mx * (q2q3 + q1q4) + 2.0f * my * (0.5f - q2q2 - q4q4) + 2.0f * mz * (q3q4 - q1q2);
bx = sqrt((hx * hx) + (hy * hy));
bz = 2.0f * mx * (q2q4 - q1q3) + 2.0f * my * (q3q4 + q1q2) + 2.0f * mz * (0.5f - q2q2 - q3q3);
// Estimated direction of gravity and magnetic field
vx = 2.0f * (q2q4 - q1q3);
vy = 2.0f * (q1q2 + q3q4);
vz = q1q1 - q2q2 - q3q3 + q4q4;
wx = 2.0f * bx * (0.5f - q3q3 - q4q4) + 2.0f * bz * (q2q4 - q1q3);
wy = 2.0f * bx * (q2q3 - q1q4) + 2.0f * bz * (q1q2 + q3q4);
wz = 2.0f * bx * (q1q3 + q2q4) + 2.0f * bz * (0.5f - q2q2 - q3q3);
// Error is cross product between estimated direction and measured direction of the reference vectors
ex = (ay * vz - az * vy) + (my * wz - mz * wy);
ey = (az * vx - ax * vz) + (mz * wx - mx * wz);
ez = (ax * vy - ay * vx) + (mx * wy - my * wx);
if (Ki > 0.0f)
eInt[0] += ex; // accumulate integral error
eInt[1] += ey;
eInt[2] += ez;
// Apply I feedback
gx += Ki*eInt[0];
gy += Ki*eInt[1];
gz += Ki*eInt[2];
// Apply P feedback
gx = gx + Kp * ex;
gy = gy + Kp * ey;
gz = gz + Kp * ez;
// Integrate rate of change of quaternion
// small correction 1/11/2022, see https://github.com/kriswiner/MPU9250/issues/447
gx = gx * (0.5*deltat); // pre-multiply common factors
gy = gy * (0.5*deltat);
gz = gz * (0.5*deltat);
float qa = q1;
float qb = q2;
float qc = q3;
q1 += (-qb * gx - qc * gy - q4 * gz);
q2 += (qa * gx + qc * gz - q4 * gy);
q3 += (qa * gy - qb * gz + q4 * gx);
q4 += (qa * gz + qb * gy - qc * gx);
// Normalise quaternion
norm = sqrt(q1 * q1 + q2 * q2 + q3 * q3 + q4 * q4);
norm = 1.0f / norm;
q[0] = q1 * norm;
q[1] = q2 * norm;
q[2] = q3 * norm;
q[3] = q4 * norm;
float vector_dot(float a[3], float b[3]){
return a[0] * b[0] + a[1] * b[1] + a[2] * b[2];
void vector_normalize(float a[3]){
float mag = sqrt(vector_dot(a, a));
a[0] /= mag;
a[1] /= mag;
a[2] /= mag;
void calibrateMPU6050() {
delay(2000);
digitalWrite(2, HIGH);
delay(100);
digitalWrite(2, LOW);
delay(100);
const int numSamples = 1000;
long accX_sum = 0, accY_sum = 0, accZ_sum = 0;
long gyroX_sum = 0, gyroY_sum = 0, gyroZ_sum = 0;
for (int i = 0; i < numSamples; ++i) {
// Read accelerometer data
// Read gyroscope data
accX_sum += accX;
accY_sum += accY;
accZ_sum += accZ;
gyroX_sum += gyroX;
gyroY_sum += gyroY;
gyroZ_sum += gyroZ;
delay(10);
for (int i = 0; i < 2; i++) {
delay(100);
delay(100);
accBiasX = (float)accX_sum / numSamples;
accBiasY = (float)accY_sum / numSamples;
accBiasZ = (float)accZ_sum / numSamples;
gyroBiasX = (float)gyroX_sum / numSamples;
gyroBiasY = (float)gyroY_sum / numSamples;
gyroBiasZ = (float)gyroZ_sum / numSamples;
