Main millis within a function !
The subject topic of this post maybe wrong, best I could think of Sorry.... :o
I need to run a dc motor every 30secs run forward 2 secs and then backward 2 secs.
Using a servo or a relay is not an option for this test project.
This is my objective using an arduino and it works as a stand alone program
const int outA = 11;
const int outB = 12 ;
	pinMode(outA,OUTPUT);
	pinMode(outB,OUTPUT);
	digitalWrite(outA,LOW);  // Motor Stop 0
	digitalWrite(outB,LOW);  // Motor Stop 0
	delay (10000);   // Arduino settle down on Power ON !
	digitalWrite(outA,HIGH);  // Motor Forward +
	digitalWrite(outB,LOW);  // Motor Forward -
	delay(2000); // 2 seconds go forward
	digitalWrite(outA,LOW);  // Motor Backward -
	digitalWrite(outB,HIGH);  // Motor Backward +
	delay (2000); // 2 seconds go backward
	delay(30000);  // 30 seconds wait
But I needed it to work as a function when called, so using millis I have managed it to get it working with the 2 second on/off
//ON and OFF Times 2 seconds
const unsigned int onTime = 2000;
const unsigned int offTime = 2000;
 //Do Nothing Time
const unsigned int OverallTime = 30000;
// Store the last time we used
unsigned long previousMillis=0;
// Action wait period could be onTime or offTime
int interval = onTime;
// we keep track of the Output state on or off
 boolean AOutstate = true;  // ON
 boolean BOutstate = false;  // OFF
  pinMode(outA, OUTPUT);
void loop(){
  Motor_Action();
void Motor_Action() {
  // Set the Outputs according to the loop state !
  digitalWrite(outA, AOutstate);
  digitalWrite(outB, BOutstate);
  // capture and keep track of the time/clock!
  // Check the time against the main time/clock!
  if ((unsigned long)(currentMillis - previousMillis) >= interval) {
    //Change the Output state
      if (AOutstate) {
      // If Motor is currently Forward, set time to go Backward
	delay(2000);
      interval = offTime;
    else  if (BOutstate) {
      // If Motors is currently Backward, set time to go Forward
	delay(2000);
      interval = onTime;
      //#############  This Section ##################
        interval = OverallTime;                                         //####
        digitalWrite(outA,LOW);  // Motor Stop 0                //####
        digitalWrite(outB,LOW);  // Motor Stop 0                //####
    // Toggle the Output pins state
    AOutstate = !(AOutstate);
    BOutstate = !(BOutstate);
    // Save the current time to compare and check later
Where I would like help is getting an overall time of 30 secs when the function waits with the digital out's LOW
any and all help is appreciated :slight_smile:
So you want it not to take any action for 30 seconds and not have the motor running?
Simply have the thing check if millis() is greater than 30000. Then it can handle the turning the motor on/off after millis exceeds 30000.
so
(if millis() > 30000){
domotorcontrol()
The suggestion in Reply #1 would just prevent the motor from working during the first 30 seconds after the Arduino is powered up or reset. I don't think that is what the OP wants.
@RajFM, post your millis() program without any irrelevant commented out pieces and I will have a look at it. I don't know what I should be looking at in the code in your Original Post.
I think what you need to do to have different times is to put different values in the variable interval depending on what stage your program is at.
...R
Yes you are correct, it waits for 30" first and then runs the loop without a break.
I have attached the file if it will be easier and also below , I have removed the extra comments,
what I don't have in this revised code is the 30" section when the program pulls down the outputs LOW and waits.
Thanks
 //Do Nothing Time
unsigned long previousOverall_Millis = 0;
void loop(){
  Motor_Action();
    if (AOutstate) {
      interval = offTime;
        Serial.println("Pump BACKWARD");
      interval = onTime;
     Serial.println("Pump FORWARD");
millis_pump.ino (1.36 KB)
RajFM:
the result of subtracting an unsigned long from an unsigned long is an unsigned long... no need to again cast it to an unsigned long
That sounds like a state machine to me.
3 states
State 0 : wait 30 seconds then start the motor forward and change to state 1
State 1 : stay in this state for 2 seconds then change motor direction and change to state 2
State 2 : stay in this state for 2 seconds then turn off the motor and change to state 0
Pseudo code
switch (state)
  case 0:
    if 30 seconds has passed (use millis() for this)
         start motor forward
         state = 1
         save millis() value
   break
  case 1:
    if 2 seconds has passed
         reverse motor direction
         state = 2
         save millis() value
    break
  case 2:
        stop motor
         state = 0
         save millis() value
    break
Here is a starting point:
const int outB = 12;
//Do Nothing Time
byte counter;
unsigned long previousMillis = 0;
unsigned long currentMillis;
unsigned long operateMillis;
  pinMode(outB, OUTPUT);
  Motor_Action();
void Motor_Action()
  if (millis() - operateMillis < OverallTime)
    //not time yet
    return;
  if (currentMillis - previousMillis >= interval)
    if (AOutstate)
      interval = offTime;
    else  if (BOutstate)
      interval = onTime;
    counter++;
    if (counter > 2)
      //initialize
      digitalWrite(outA, LOW);
      digitalWrite(outB, LOW);
      AOutstate = true;
      BOutstate = false;
      //set up next iteration
      operateMillis = millis();
      counter = 0;
Edit:
cosmetic changes.
RajFM:
Who is correct?
I thought you wanted the code to
  • do something
  • wait 30 secs
  • do the something again
  • wait 30 secs
  • etc etc
...R
Robin2:
Who is correct?
  • do something
  • wait 30 secs
  • wait 30 secs
  • etc etc
...R
Sorry should have clarified, it was for your reply for the suggestion in reply 1.
Thanks
:o :confused: :-\ :cry:
BulldogLowell:
Good catch, thank you for pointing out how I could/should streamline the code better, I have replaced it
See example in post #6
@larryd reply#6
Thank you for the revised code , I will test and play with it.
@ UKHeliBob
Thank you, I did read your sticky post on " Using millis() for timing. A beginners guide" before posting this post just to check if I missed anything and did learn a few tricks .
//Do Nothing Time
byte AOutstate = HIGH;
byte BOutstate = LOW;
byte counter;
  Motor_Action();
void Motor_Action()
    //not time yet
    return;
  if (millis() - previousMillis >= interval)
    previousMillis = millis();
    Serial.println (previousMillis);
    if (counter > 1)
      //initialize for next cycle
      counter = 0;
      Serial.println("Pump OFF \n");
      AOutstate = true;
      BOutstate = false;
      return;
    counter++;
    if (AOutstate == HIGH)
      interval = offTime;
    else  if (BOutstate == HIGH)
      interval = onTime;
    AOutstate = !AOutstate;
    BOutstate = !BOutstate;
@larryd Thank you for taking the time and solving my code , totally awesome!
Thanks
larryd:
//Do Nothing Time
byte counter;
  Motor_Action();
void Motor_Action()
    //not time yet
    return;
    if (counter > 1)
      counter = 0;
      AOutstate = true;
      BOutstate = false;
return;
counter++;
      interval = offTime;
      interval = onTime;
