Mains control
Hi All I am using a Decimilla and will need to control mains loads. I am using single outputs for each function. I would like to have LED's in the "loop" for diarnostics e.g. Output pin -> LED -> Relay -> Ground This should led me see the condition of the relays in the event of a failure.
What is the best way to wire in the relays/LED's? series/ parralel to ground?
What relays would you suggest, I will need to control: 240VAC @ upto 13A 120VAC @ upto 20A 24VAC @ 1A
TIA
P.s. is there a ready built relay board for doing this or at least some of it?
Just looking what modules are around on ebay .
http://cgi.ebay.co.uk/Relay-Card-Board-8-chan-240VAC-10-amps-logic-drive_W0QQitemZ200284903038QQcmdZViewItemQQptZUK_Gadgets?hash=item200284903038&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
http://cgi.ebay.co.uk/PCB-Relay-Board-x-8-PLCC-LED-Indication-12vdc_W0QQitemZ400048563657QQcmdZViewItemQQptZUK_Campervan_Caravan_Accessories?hash=item400048563657&_trksid=p3286.c0.m14&_trkparms=72%3A1683|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
I like to put some isolation between low and high voltages non totally right .
Those look good,
They are a bit over kill for what im looking for. I only need 4 relays
They are a bit underkill for what im looking for in terms of power handling
I will be needing to produce these in quantities of approx 100. Is there anyone who would be able to do 100 boards for a decent price? This is of course if I cant find anything suitable that already exists lol.
