(Major headache...!) - 1 line code crashes arduino
im making a drawing arduino, the code is messy (amature programmer) but faily simple…
only problem is when i uncomment either a call to;
drawLine(x,y);
random(x,y);
in the drawBoxP(int x, int y, int size, int count) function and upload the sketch the aruino doesnt hold LED high for 5 seconds but crashes Serial (even tho its not used) and forces TX high instead…???;
im sure im missing something simples and messy cooding to blame…
any help would be much apreaciated…
phil
int data[50][50] = { ########### DATA ARRAY (0-255 int) ###############}
int StepUnit = 30;
int w= 38StepUnit;
int h= 28
StepUnit;
int x1= w/2;
int y1= h;
int a1= sqrt(pow(x1,2)+pow(y1,2));
int b1= sqrt(pow((w-x1),2)+pow(y1,2));
// Stepper motor objects: A is left, B is right
Stepper StepperA(motorStepsA, motorPinA1,motorPinA2, motorPinA3,motorPinA4);
Stepper StepperB(motorStepsB, motorPinB1,motorPinB2, motorPinB3,motorPinB4);
void moveTo(int x2, int y2) {
// Turn the stepper motors to move the marker from the current point (x1, y1) to (x2, y2)
// Note: This only moves in a perfectly straight line if
// the distance is the same in both dimensions; this should be fixed, but it works well
// a2 and b2 are the final lengths of the left and right strings
int a2 = sqrt(pow(x2,2)+pow(y2,2));
int b2 = sqrt(pow((w-x2),2)+pow(y2,2));
int stepA;
int stepB;
if (a2>a1) {
stepA=1;
if (a1>a2) {
stepA=-1;
if (a2==a1) {
stepA=0;
if (b2>b1) {
stepB=1;
if (b1>b2) {
stepB=-1;
if (b2==b1) {
stepB=0;
// Change the length of a1 and b1 until they are equal to the desired length
while ((a1!=a2) || (b1!=b2)) {
if (a1!=a2) {
a1 += stepA;
StepperA.step(stepA);
if (b1!=b2) {
b1 += stepB;
StepperB.step(-stepB);
x1 = x2;
y1=y2;
void drawLine(int x2, int y2)
/Serial.print(“DL:”);
Serial.print(x1);
Serial.print(":");
Serial.print(y1);
Serial.print("/");
Serial.print(x2);
Serial.print(":");
Serial.println(y2);
int X = x2-x1;
int Y = y2-y1;
int topX = x1;
int topY = y1;
int L = (int)sqrt(pow(X,2)+pow(Y,2));
for (int i = 0; i <= L; i++)
int x = (int)(X * (double)((i+0.0)/L));
int y = (int)(Y * (double)((i+0.0)/L));
moveTo(x+topX,y+topY);
void drawBoxP(int dbpsx, int dbpsy, int dbpsize, int dbpcount)
int dbps = dbpsize/2;
int dbpminX = dbpsx-dbps;
int dbpminY = dbpsy-dbps;
int dbpmaxX = dbpsx + dbps;
int dbpmaxY = dbpsy + dbps;
//THESE ARE THE FUNCTION CALLS THAT FORCE CRASH
// drawLine(dbpminX,dbpminY);
// drawLine(dbpminX,dbpmaxY);
// drawLine(dbpmaxX,dbpmaxY);
// drawLine(dbpmaxX,dbpminY);
for (int dbpi = 0; dbpi<dbpcount;dbpi++)
// blink(20);
// int dbptx = random(dbpminX,dbpmaxX);
//int dbpty = random(dbpminY,dbpmaxY);
//drawLine(dbptx,dbpty);
int blink(int time)
digitalWrite(13,HIGH);
delay(time);
digitalWrite(13,LOW);
StepperA.setSpeed(4);
StepperB.setSpeed(4);
// Serial.begin(9600);
delay(2000);
randomSeed(analogRead(0));
pinMode(13,OUTPUT);
delay(5000);
int rows = 50;
int cols = 50;
int size = 10;
int count=0;
int sX = x1-((cols*size)/2);
int sY = y1+20;
int nX = sX;
int nY = sY;
int xX = sX+(colssize);
int xY = sY+(rows
size);
drawLine(nX,nY);
drawLine(nX,xY);
drawLine(xX,xY);
drawLine(xX,nY);
drawLine(nX,nY);
for (int yi = 0; yi < rows; yi++)
for (int xi = 0; xi < cols; xi++)
count++;
int px = sX+(sizexi);
int py = sY+(size
yi);
int i = (data[yi][xi]/5.0);
drawBoxP(px,py,size,i);
Please modify your post and put code tags ( [#] button) around the code.
Which board are you using?
int data[50][50]
This is 5000 bytes of data, which is more than there is space for data on the Arduino (unless you have a MEGA with 1280 or 2560 CPU.) Neither the Arduino IDE nor the CPU itself detects this sort of error, causing all sorts of strange crash-like behavior.
While you are fixing the oversize array, take a look at this statement:
and this page: http://arduino.cc/en/Reference/Pow The pow() function expects two floats, not two ints. So, a cast is performed to convert the ints to floats, so that pow can effectively do this for you: X * X.
Instead of the casts and the overhead of a relatively inefficient algorithm, just multiply the number by itself.
One last observation. Executable code must be in a function.
int w= 38*StepUnit;
int h= 28*StepUnit;
int x1= w/2;
int y1= h;
None of this code will do what you think it will.
