ZebH
1
Hi all,
I want to make a cstring equal variable1 and variable2 and varaible3.
So if:
Variable1 = 1
Variable2 = 2
Variable3 = 3
the result is 123.
My question is how can I do this? Can I modify the strcpy command to achieve this?
Any help with this would be awesome!
Thanks!
Zeb
char buffer[20];
int total = (100 * variable1) + (10 * variable2) + variable3;
itoa(total, buffer, 10);
Serial.println(buffer);
Why do you want to do this ?
gcjr
3
int var1 = 1;
int var2 = 2;
int var3 = 3;
char s [20];
sprintf (s, "%d%d%d", var1, var2, var3);
Serial.println (s);
ZebH
4
Hi, thanks for your help!
UKHeliBob:
char buffer[20];
Does this work when "Variable1", "Variable2" and "Variable3" are cstrings?
Thanks very much!
Zeb
ZebH
5
Because this code:
char variable1[] = "1";
char variable2[] = "2";
char variable3[] = "3";
char buffer[20];
throws up this error:
invalid operands of types 'int' and 'char [2]' to binary 'operator*'
About this line:
Thanks again,
Zeb
ZebH
6
Sorry in my original post I didn't explain clearly that "Variable1", "Varaible2" and "Varaible3" are cstrings!
Sorry about that!
Zeb
ZebH
7
All good, actually just used the strcat command:
char var1[] = "1";
char var2[] = "2";
char var3[] = "3";
char str[80];
strcpy (str,var1);
strcat (str,var2);
strcat (str,var3);
Serial.println (str);
Thanks heaps for your help!
Zeb
If you wanted to concatenate C style strings then why did you not say so in the first place ?
It is so much easier to provide help when in possession of the full facts
