Hi. I am causing a lot of trouble, aren't I?
I ran out of "replies" Here is what I would like the code to do.
here is the code for the above:
// RED ALERT Button
//turns off spots 1-7, turns on red LEDs. 10 seconds, turns on 1-t in sequence 500ms apart
//red LEDs turn off
//This only works once when powered on.
//setup LED pins for spots
int dryDock1 = 23;
int dryDock2 = 25;
int dryDock3 = 27;
int dryDock4 = 29;
int dryDock5 = 31;
int dryDock6 = 33;
int dryDock7 = 35;
//Red Alert lights and relay
int redPin1 = 50;
int redPin2 = 52;
int relayPin = 48;
//assign states
int redState = 0;
int redLength = 10000;
int redSwitch = 28;
// time intervals between lights on
const unsigned long eventInterval0 = 10000;
const unsigned long eventInterval1 = 11000;
const unsigned long eventInterval2 = 11500;
const unsigned long eventInterval3 = 12000;
const unsigned long eventInterval4 = 12500;
const unsigned long eventInterval5 = 13000;
const unsigned long eventInterval6 = 13500;
const unsigned long eventInterval7 = 14000;
unsigned long previousTime = 0;
unsigned long currentTime = 0;
pinMode(redPin1, OUTPUT);
pinMode(redPin2, OUTPUT);
pinMode(dryDock1, OUTPUT);
pinMode(dryDock2, OUTPUT);
pinMode(dryDock3, OUTPUT);
pinMode(dryDock4, OUTPUT);
pinMode(dryDock5, OUTPUT);
pinMode(dryDock6, OUTPUT);
pinMode(dryDock7, OUTPUT);
pinMode(relayPin, OUTPUT);
pinMode(redSwitch, INPUT);
redState = digitalRead(redSwitch); // check if button is pushed
if (redState == HIGH)
{currentTime = millis();
if (currentTime <= redLength)
digitalWrite(redPin1, HIGH);
digitalWrite(redPin2, HIGH);
digitalWrite(relayPin, HIGH);
digitalWrite(dryDock1, LOW);
digitalWrite(dryDock2, LOW);
digitalWrite(dryDock3, LOW);
digitalWrite(dryDock4, LOW);
digitalWrite(dryDock5, LOW);
digitalWrite(dryDock6, LOW);
digitalWrite(dryDock7, LOW);
if (currentTime = millis())
previousTime = currentTime;
// /* Updates frequently */
// digitalWrite(redPin1, LOW);
// digitalWrite(redPin2, LOW);
// digitalWrite(relayPin, LOW);
if (currentTime >= eventInterval1)
Serial.println("Ice Ice Baby1");
{ digitalWrite(redPin1, LOW);
digitalWrite(dryDock1, HIGH);
/* Update the timing for the next time around */
// previousTime = currentTime;
/* This is the event */
if (currentTime >= eventInterval2) {
/* Event code */
Serial.println("Ice Ice Baby2");
//digitalWrite(dryDock1, HIGH);
digitalWrite(dryDock2, HIGH);
if (currentTime >= eventInterval3) {
/* Event code */
Serial.println("Ice Ice Baby3");
digitalWrite(dryDock3, HIGH);
if (currentTime >= eventInterval4) {
/* Event code */
Serial.println("Ice Ice Baby4");
digitalWrite(dryDock4, HIGH);
if (currentTime >= eventInterval5) {
/* Event code */
Serial.println("Ice Ice Baby5");
digitalWrite(dryDock5, HIGH);
if (currentTime >= eventInterval6) {
/* Event code */
Serial.println("Ice Ice Baby6");
digitalWrite(dryDock6, HIGH);
if (currentTime >= eventInterval7) {
/* Event code */
Serial.println("Ice Ice Baby7");
digitalWrite(dryDock7, HIGH);
Serial.println("end");
//for (;;) {}
// redState =digitalRead(redSwitch);
// millis();//redState =!redState;
} else
