Okey i have cleaned the code and organised it , i have tried somethign but it didnt worked
( im a newbie in arduino srry)
#include <stdio.h>
#include <DS1302.h>
#include <Wire.h>
#include <ArduCAM.h>
#include <SPI.h>
#include <SD.h>
#include "memorysaver.h"
#include <RTClib.h>
#include <dht.h>
//This demo can only work on OV5640_MINI_5MP_PLUS or OV5642_MINI_5MP_PLUS platform.
#if !(defined (OV5640_MINI_5MP_PLUS)||defined (OV5642_MINI_5MP_PLUS))
#error Please select the hardware platform and camera module in the ../libraries/ArduCAM/memorysaver.h file
#endif
#define FRAMES_NUM 0x00
// set pin 7 as the slave select for the digital pot:
const int CS = 7;
// Pin for day/hour/month for each file that are stored in the sd
const uint8_t SD_CS = 10;
#define SD_CS 9
File file; // test file
bool is_header = false;
//int total_time = 0;
#if defined (OV5640_MINI_5MP_PLUS)
ArduCAM myCAM(OV5640, CS);
#else
ArduCAM myCAM(OV5642, CS);
#endif
uint8_t read_fifo_burst(ArduCAM myCAM);
// Define the humidty and temp sensor object and define the pin where the information go
dht DHT;
#define DHT11_PIN 3
// Pin connection for the clock
const int kCePin = 5; // Chip Enable
const int kIoPin = 6; // Input/Output
const int kSclkPin = 4; // Serial Clock
// Create a DS1302 object (clock object ).
DS1302 rtc(kCePin, kIoPin, kSclkPin);
char buf[30];
// Define the code and the placement for the date of each file who are put in the ( when there are create)
void printTime(uint16_t* date,uint16_t* time ) {
// Get the current time and date from the chip.
Time t = rtc.time();
// Name the day of the week.
const String day = dayAsString(t.day);
// Format the time and date and insert into the temporary buffer.
snprintf(buf, sizeof(buf), "%s %04d-%02d-%02d %02d:%02d:%02d", day.c_str(),t.date,t.yr, t.mon, t.hr, t.min, t.sec);
Serial.println("yy");
*date = FAT_DATE(t.yr,t.mon, t.date);
*time = FAT_TIME(t.hr, t.min, t.sec);
String dayAsString(const Time::Day day) {
switch (day) {
case Time::kMonday: return "Lundi";
case Time::kTuesday: return "Mardi";
case Time::kWednesday: return "Mercredi";
case Time::kThursday: return "Jeudi";
case Time::kFriday: return "Vendredi";
case Time::kSunday: return "Samedi";
case Time::kSaturday: return "Dimanche";
return "(unknown day)";
// Take the time from the clock to synchronize it with the file who is put a in the sd
SdFile::dateTimeCallback(printTime);
snprintf(buf, sizeof(buf), "%s %04d-%02d-%02d %02d:%02d:%02d",day.c_str(),
// camera code
uint8_t vid, pid;
uint8_t temp;
#if defined(__SAM3X8E__)
Wire1.begin();
#else
Wire.begin();
#endif
Serial.println(F("ArduCAM Start!"));
// set the CS as an output:
pinMode(CS, OUTPUT);
digitalWrite(CS, HIGH);
// initialize SPI:
SPI.begin();
//Reset the CPLD
myCAM.write_reg(0x07, 0x80);
delay(100);
myCAM.write_reg(0x07, 0x00);
delay(100);
while(1){
//Check if the ArduCAM SPI bus is OK
myCAM.write_reg(ARDUCHIP_TEST1, 0x55);
temp = myCAM.read_reg(ARDUCHIP_TEST1);
if(temp != 0x55)
Serial.println(F("SPI interface Error!"));
delay(1000);continue;
}else{
Serial.println(F("SPI interface OK."));break;
while(1){
//Check if the camera module type is OV5640
myCAM.rdSensorReg16_8(OV5640_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV5640_CHIPID_LOW, &pid);
if ((vid != 0x56) || (pid != 0x40)){
Serial.println(F("Can't find OV5640 module!"));
delay(1000); continue;
}else{
Serial.println(F("OV5640 detected."));break;
#else
while(1){
//Check if the camera module type is OV5642
myCAM.rdSensorReg16_8(OV5642_CHIPID_HIGH, &vid);
myCAM.rdSensorReg16_8(OV5642_CHIPID_LOW, &pid);
if ((vid != 0x56) || (pid != 0x42)){
Serial.println(F("Can't find OV5642 module!"));
}else{
Serial.println(F("OV5642 detected."));break;
#endif
//Initialize SD Card
while(!SD.begin(SD_CS))
Serial.println(F("SD Card Error!"));delay(1000);
Serial.println(F("SD Card detected."));
//Change to JPEG capture mode and initialize the OV5640 module
myCAM.set_format(JPEG);
myCAM.InitCAM();
myCAM.set_bit(ARDUCHIP_TIM, VSYNC_LEVEL_MASK);
myCAM.clear_fifo_flag();
myCAM.write_reg(ARDUCHIP_FRAMES, FRAMES_NUM);
// read the information from the humidity and temp sensor
int chk = DHT.read11(DHT11_PIN);
// Read the value in A0 from the IR sensor
int sensorValue = analogRead(A0);
float voltage = sensorValue * (5.0 / 1023.0);
// Condition for taking a picture
if (voltage < 3) {
myCAM.flush_fifo();
myCAM.OV5640_set_JPEG_size(OV5640_320x240);delay(1000);
#else
myCAM.OV5642_set_JPEG_size(OV5642_320x240);delay(1000);
#endif
//Start capture
myCAM.start_capture();
Serial.println(F("start capture."));
while ( !myCAM.get_bit(ARDUCHIP_TRIG, CAP_DONE_MASK));
Serial.println(F("CAM Capture Done."));
Serial.print(F("capture total_time used (in miliseconds):"));
read_fifo_burst(myCAM);
Serial.print(F("save capture total_time used (in miliseconds):"));
else {}
uint8_t temp = 0, temp_last = 0;
uint32_t length = 0;
static int i = 0;
static int k = 0;
char str[8];
File outFile;
byte buf[256];
length = myCAM.read_fifo_length();
Serial.print(F("The fifo length is :"));
Serial.println(length, DEC);
if (length >= MAX_FIFO_SIZE) //8M
Serial.println("Over size.");
return 0;
if (length == 0 ) //0 kb
Serial.println(F("Size is 0."));
return 0;
myCAM.CS_LOW();
myCAM.set_fifo_burst();//Set fifo burst mode
i = 0;
while ( length-- )
temp_last = temp;
temp = SPI.transfer(0x00);
//Read JPEG data from FIFO
if ( (temp == 0xD9) && (temp_last == 0xFF) ) //If find the end ,break while,
buf[i++] = temp; //save the last 0XD9
//Write the remain bytes in the buffer
myCAM.CS_HIGH();
outFile.write(buf, i);
//Close the file
outFile.close();
Serial.println(F("OK"));
is_header = false;
myCAM.CS_LOW();
i = 0;
if (is_header == true)
//Write image data to buffer if not full
if (i < 256)
buf[i++] = temp;
//Write 256 bytes image data to file
myCAM.CS_HIGH();
outFile.write(buf, 256);
i = 0;
buf[i++] = temp;
myCAM.CS_LOW();
else if ((temp == 0xD8) & (temp_last == 0xFF))
is_header = true;
myCAM.CS_HIGH();
//Create a avi file
k = k + 1;
itoa(k, str, 10);
strcat(str, ".jpg");
//Open the new file
outFile = SD.open(str, O_WRITE | O_CREAT | O_TRUNC);
file = SD.open("Humidité & Temperature.TXT", FILE_WRITE);
file.println("DHT.temperature,DHT.humidty");
if (! outFile)
Serial.println(F("File open failed"));
while (1);
myCAM.CS_LOW();
buf[i++] = temp_last;
buf[i++] = temp;
myCAM.CS_HIGH();
return 1;
I have tried to definne the fonction like this and thats doesnt work
getHumidityReading = DHT.humidity
getTemperatureReading == DHT.temperature
auto humidity = getHumidityReading();
auto temperature = getTemperatureReading();
auto image = takePicture();
auto imageFilename = generateImageFilename();
storeImageToSdCard(imageFilename, image);
auto sensorValuesFilename = generateSensorValuesFilename();
storeSensorValuesToSdCard(humidity, temperature);
