I created a header file using arduino, and am trying to figure out how to compress it down so that it is in the proper format. For example, if you look at a library .h file the line breaks don't actually create a new line, but if you copy the .h file and paste it into the arduino IDE it will break the lines accordingly. If you copy from the arduino IDE and paste back into the .h file though the line breaks are the same as the arduino's IDE, and the program will not work.
How do I create the proper format for the .h file?
