Make a LinkSprite Serial Web Server Using Arduino
How to make a linksprite serial web server using Arduino Ethernet sheild
LinkSprite has a serial web server that allow to use AT command to configure, and otherwise, is a transparent DTU. It's data sheet can be download at:
http://www.cutedigi.com/product_info.php?products_id=4204
http://www.linksprite.com/product_info.php?products_id=3536
In this tutorial, we are going to show how to make a Linksprite serial web server using ardino ethernet shield.
Hardware:
It requires a router. We use a Netgear one.
The Arduino Duemilanove USB board, which can be ordered from:http://www.cutedigi.com/product_info.php?cPath=277&products_id=4221
The Arduino Ethernet Shield, which can be ordered from: http://www.cutedigi.com/product_info.php?cPath=277&products_id=4222
Sketch:
 * Serial Web Server
 * http://www.cutedigi.com
 * tech@cutedigi.com
 *  8/11.2009
 * use under GNU
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 10, 0, 0, 177 };
Server server(5000);
int incomingByte = 0;      // for incoming serial data
  Ethernet.begin(mac, ip);
  server.begin();
  Client client = server.available();
  if (Serial.available() > 0)
    server.write(Serial.read());
  if (client) {
        char c = client.read();
        if(c!=NULL)
           Serial.print(c);
Quick Test:
We will download a serial port monitor from: http://www.linksprite.com/pub/software/LinkSprite-NEC-serial-v1.0.rar
The TCP/IP debugger from: http://www.simplecomtools.com/tcptesttool.html
