Make a mini menu with a button and two leds
Hey
I have 3 LEDs and 2 buttons, 2 of the LEDs are indicator of what state the third LED should eighter blink or fade when startSwitch is pressed, that is chosen by the second button(selectionSwitch).
I do not get it right when I switch the states program1Flag and program2Flag. Can some one guide me what I am missing?
Thanks!
unsigned long startMillis;
unsigned long periodStartMillis;
unsigned long currentMillis;
unsigned long startMillis1;
unsigned long periodStartMillis1;
unsigned long currentMillis1;
unsigned long blinkStartMillis;
unsigned long fadeStartMillis;
unsigned long debounceStartMillis;
unsigned long debounceStartMillis1;
unsigned long debouncePeriod = 20;
const unsigned long period = 50;  //checking button every 50ms
const byte startSwitch = 2;
const byte selectionSwitch = 3;
byte currentButtonState;
byte previousButtonState;
byte currentButtonState1;
byte previousButtonState1;
const unsigned long blinkPeriod = 1000;  //blink period
const unsigned long fadePeriod = 10;  //fade period
const byte led = 10;
const byte program1LED = 6;
const byte program2LED = 5;
byte brightness = 0;  //initial brightness of LED
byte increment = 1;  //amount to change PWM value at each change
bool actionFlag = false;
bool program1Flag = true;
bool program2Flag = false;
boolean debouncing = false;
int lastButtonState = LOW;
int lastButtonState1 = LOW;
unsigned long lastDebounceTime = 0;// the last time the output pin was toggled
unsigned long debounceDelay = 50;
unsigned long lastDebounceTime1 = 0;// the last time the output pin was toggled
unsigned long debounceDelay1 = 50;
  pinMode(startSwitch, INPUT_PULLUP);
  pinMode(selectionSwitch, INPUT_PULLUP);
  pinMode(led, OUTPUT);
  blinkStartMillis = millis();  //start time of blinking LED
  fadeStartMillis = millis();  //start time of fading LED
  periodStartMillis = millis();
  startMillis = millis();
  digitalWrite(program1LED, HIGH);
  currentMillis = millis();
  int reading = digitalRead(startSwitch);
  int reading1 = digitalRead(selectionSwitch);
  // SELECTIONSWITCH
  if (reading1 != lastButtonState1) {
    // reset the debouncing timer
    lastDebounceTime1 = millis();
  if ((millis() - lastDebounceTime1) > debounceDelay1) {
    // whatever the reading is at, it's been there for longer than the debounce
    // delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading1 != currentButtonState1) {
      currentButtonState1 = reading1;
      // only toggle the LED if the new button state is pressed
      if (currentButtonState1 == LOW and program1Flag == true) {
        program1Flag = false;
        program2Flag = true;
        digitalWrite(program1LED, LOW);
        digitalWrite(program2LED, HIGH);
      if (currentButtonState1 == LOW and program2Flag == true) {
        digitalWrite(program2LED, LOW);
  // startSwitch
if (reading != lastButtonState) {
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    if (reading != currentButtonState) {
      currentButtonState = reading;
      // only toggle the LED if the new button state is HIGH
      if (currentButtonState == LOW) {
        actionFlag = !actionFlag;
  if (actionFlag == true && program1Flag == true) //take actions based on the state of the action flag
    blink();
  if (actionFlag == true && program2Flag == true) //take actions based on the state of the action flag
    fade();
    digitalWrite(blinkLedPin, LOW);
  // save the reading. Next time through the loop, it'll be the lastButtonState:
  lastButtonState1 = reading1;
  lastButtonState = reading;
void blink()  //function to blink an LED if the blink period has ended
  if (currentMillis - blinkStartMillis >= blinkPeriod)  //test whether the period has elapsed
    digitalWrite(led, !digitalRead(led));  //if so, change the state of the LED
    blinkStartMillis = currentMillis;  //IMPORTANT to save the start time of the current LED state.
void fade()    //function to fade an LED
  if (currentMillis - fadeStartMillis >= fadePeriod)  //test whether the period has elapsed
    analogWrite(led, brightness);    //set the brightness of the LED
    brightness += increment;    //will wrap round because brightness is an unsigned data type
    fadeStartMillis = currentMillis;  //IMPORTANT to save the start time of the current LED state.
Why are you using the same pin ?
Well, I should have only use one LED and one name... Sorry about that...
Does your sketch compile ?
Try this:
//  Version    YY/MM/DD     Description
//  1.00       21/10/08     Running sketch
#define LEDon                     HIGH
#define LEDoff                    LOW
#define SWITCHreleasd             HIGH
#define SWITCHpressed             LOW
#define ENABLED                   true
#define DISABLED                  false
const byte LEDpin               = 10;
const byte heartbeatLED         = 13;
bool program1Flag               = ENABLED;
bool program2Flag               = DISABLED;
bool actionFlag                 = DISABLED;
byte lastStartSwitchState       = SWITCHreleasd;
byte lastSelectionSwitchState   = SWITCHreleasd;
byte brightness                 = 0;                   //0-255
byte increment                  = 1;
//TIMER stuff
unsigned long heartbeatMillis;
unsigned long switchMillis;
  pinMode(program1LED, OUTPUT);
  pinMode(program2LED, OUTPUT);
  pinMode(LEDpin, OUTPUT);
  pinMode(heartbeatLED, OUTPUT);
} //END of setup()
  //to see if the sketch is blocking,
  //toggle the heartbeat LED every 500ms
  if (millis() - heartbeatMillis >= 500)
    //restart this TIMER
    heartbeatMillis = millis();
    //toggle the LED
    digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
  //is it time to read the switches ?
  if (millis() - switchMillis >= 50)
    switchMillis = millis();
    checkSwitches();
  if (actionFlag == ENABLED && program1Flag == ENABLED)
    blink();
  if (actionFlag == ENABLED && program2Flag == ENABLED)
    fade();
  //other non-blocking code goes here
} //END of loop()
void checkSwitches()
  // s t a r t S w i t c h
  byte currentSwitchState = digitalRead(startSwitch);
  //was there a change in state ?
  if (lastStartSwitchState != currentSwitchState)
    //update to the new state
    lastStartSwitchState = currentSwitchState;
    //is the switch pressed ?
    if (currentSwitchState == SWITCHpressed)
      if (actionFlag == DISABLED)
        digitalWrite(LEDpin, LEDoff);
        brightness = 0;
  } //END of   if (lastStartSwitchState != currentSwitchState)
  // s e l e c t i o n S w i t c h
  currentSwitchState = digitalRead(selectionSwitch);
  if (lastSelectionSwitchState != currentSwitchState)
    lastSelectionSwitchState = currentSwitchState;
    //are we in program #1 AND is the switch pressed ?
    if (program1Flag == ENABLED && currentSwitchState == SWITCHpressed)
      program1Flag = DISABLED;
      digitalWrite(program1LED, LEDoff);
      program2Flag = ENABLED;
      digitalWrite(program2LED, LEDon);
      //start out at 0
      brightness = 0;
      //restart the TIMER
    //are we in program #2 AND is the switch pressed ?
    else if (program2Flag == ENABLED && currentSwitchState == SWITCHpressed)
      digitalWrite(program1LED, LEDon);
      //restart the TIMER
      digitalWrite(program2LED, LEDoff);
  } //END of   if (lastSelectionSwitchState != currentSwitchState)
  //next switch code
} //END of   checkSwitches()
void blink()
  //has the TIMER expired ?
    //restart the TIMER
    //toggle LED
    digitalWrite(LEDpin, !digitalRead(LEDpin));
} //END of blink()
void fade()
    //restart the TIMER
    //next brightness level
    analogWrite(LEDpin, brightness);
} //END of fade()
This works, thanks for the help! The heartbeatmillis is really good indication if the code is blocked, will keep that one in mind!
Thanks! @LarryD
