make a responsive power saving keypad
hi
i am trying to make a zigbee remote so i copied a code from Nick Gammon's website which is for a power efficient keypad. i uploaded the code,
although the code is working but it is not very responsive as after pressing key for many times , key is printed on the serial monitor only once and whent i press two keys one after another only one key is printed.
the code is
/* @file CustomKeypad.pde
|| @version 1.0
|| @author Alexander Brevig
|| @contact alexanderbrevig@gmail.com
|| @description
|| | Demonstrates changing the keypad size and key values.
#include <Keypad.h>
#include <avr/sleep.h>
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
  {'0','1','2','3'},
  {'4','5','6','7'},
  {'8','9','A','B'},
  {'C','D','E','F'}
byte rowPins[ROWS] = {12, A1, A2, A4}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {A5, A3, A0, 13}; //connect to the column pinouts of the keypad
//initialize an instance of class NewKeypad
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
#define NUMITEMS(arg) ((unsigned int) (sizeof (arg) / sizeof (arg [0])))
// turn off interrupts until we are ready
ISR (PCINT0_vect)
  PCICR = 0;  // cancel pin change interrupts
  } // end of ISR (PCINT0_vect)
ISR (PCINT1_vect)
  } // end of ISR (PCINT1_vect)
ISR (PCINT2_vect)
  } // end of ISR (PCINT2_vect)
void setup(){
   PCMSK0 |= _BV (PCINT4);     // pin D12
  PCMSK1 |= _BV (PCINT9);     // pin A1
  PCMSK1 |= _BV (PCINT10);    // pin A2
  PCMSK1 |= _BV (PCINT12);    // pin A4
void reconfigurePins ()
  byte i;
  // go back to all pins as per the keypad library
  for (i = 0; i < NUMITEMS (colPins); i++)
    pinMode (colPins [i], OUTPUT);
    digitalWrite (colPins [i], HIGH);
    }  // end of for each column
  for (i = 0; i < NUMITEMS (rowPins); i++)
    pinMode (rowPins [i], INPUT);
    digitalWrite (rowPins [i], HIGH);
    }   // end of for each row
  }  // end of reconfigurePins
  void goToSleep ()
  byte i;
  // set up to detect a keypress
    digitalWrite (colPins [i], LOW);   // columns low
    digitalWrite (rowPins [i], HIGH);  // rows high (pull-up)
   // now check no pins pressed (otherwise we wake on a key release)
    if (digitalRead (rowPins [i]) == LOW)
       reconfigurePins ();
       return;
       } // end of a pin pressed
  // overcome any debounce delays built into the keypad library
  delay (50);
  // at this point, pressing a key should connect the high in the row to the
  // to the low in the column and trigger a pin change
  set_sleep_mode (SLEEP_MODE_PWR_DOWN);
  sleep_enable();
  byte old_ADCSRA = ADCSRA;
  // disable ADC to save power
  ADCSRA = 0;
  PRR = 0xFF;  // turn off various modules
  PCIFR  |= _BV (PCIF0) | _BV (PCIF1) | _BV (PCIF2);   // clear any outstanding interrupts
  PCICR  |= _BV (PCIE0) | _BV (PCIE1) | _BV (PCIE2);   // enable pin change interrupts
  // turn off brown-out enable in software
  MCUCR = _BV (BODS) | _BV (BODSE);
  MCUCR = _BV (BODS);
  sleep_cpu ();
  // cancel sleep as a precaution
  sleep_disable();
  PRR = 0;    // enable modules again
  ADCSRA = old_ADCSRA; // re-enable ADC conversion
  // put keypad pins back how they are expected to be
  reconfigurePins ();
  }  // end of goToSleep
void loop(){
  char customKey = customKeypad.getKey();
  if (customKey){
    Serial.println(customKey);
  }if (!customKey)
     // no key pressed? go to sleep
     goToSleep ();
     return;
I doubt that his code was formatted that badly. I doubt that his comments were that incorrect.
That code goes (back) to sleep pretty quick after it wakes up. Perhaps you need to stay awake for a while.
arpitgupta363:
[Snip...] when i press two keys one after another only one key is printed.
That's how the keypad is designed. If you would like to be able to press more than one key at a time then you should check out the Multikey sketch in File->Examples->Keypad->MultiKey. It shows how to use the function getKeys().
