Make a small trackpad.
I want to make a small trackpad. I have seen one from hackaday.io where they have used a Arduino and a paper. But I want to make something that can sense tapping, and swiping. So I guess a trackpad is what I want to make.
But here to the hard part, i want it to me width to be: 30 mm, Height: 10 mm and thickness: 2 mm.
How and is it possible.
Thanks for awesomeness.
It appears that it’s possible:- NailO
But I doubt if you could make one yourself.
OldSteve:
It appears that it's possible:- NailO
Is there something else there is to use to register swipe, and tap?
mogren3000:
In the size that you’re after? I doubt it, but someone else might know of something.
And even the “Nailo” appears to be thicker than 2mm, which is your stated goal.
You can use an accelerometer to register a tap, but not a swipe.
Probably too big for your application, but Sparkfun sells this Nintendo DS Screen Kit. Might be helpful...
