Make an Active Buzzer Beep
Hi all,
im a bit confused on how i can get my buzzer to beep however many times from an integer input.
int num;
int buzzPin = 8;
String msg = "Please input your number: ";
pinMode(buzzPin,OUTPUT);
Serial.println(msg);
while(Serial.available()==0);
num = Serial.parseInt();
Please use a code block to post your code.
If the only functionality you need is to beep the buzzer then just use a for loop and delay() calls to time the beep. Make your best attempt and we can help.
ToddL1962:
i want to be able to input a number through the serial monitor, and it beep that many times. I used a for loop and it would beep constantly even with delays in place.
jacklythgoee:
Then please post your attempt and we can find the issue.
To get the value of the Serial input, you can use something like this: (here's a page with more details)
In your code you are only starting to read if there is nothing there (Serial.available()==0)
This will take the number from the serial input when it is detected (more than 0) and pass it to the function called "buzzerBeep"
  if (Serial.available() > 0) {
    buzzerBeep(Serial.parseInt());
Here is the function:
void buzzerBeep(int beeps) {
  for(int x = 0; x < beeps; x++){
    digitalWrite(buzzPin, HIGH);
    digitalWrite(buzzPin, LOW);
What that does is take the number of beeps from the serial input, and turn the buzzer on and off again that many times with a one second delay in between.
Here's the final code:
int number;
int buzzPin = 8;
  pinMode(buzzPin, OUTPUT);
Do note this doesn't repeat the question for simplicity, it only asks it once in the setup.
I hope this helps :slight_smile:
