I am trying to follow this article in order to create a BLE iBeacon out of my ESP32 board, but it keeps throwing a lot of errors about undefined types, even though I installed the correct library and the library has those types.
I compiled for the "DOIT ESP32 DEVKIT V1" and only got one error:
In function 'void setup()':
error: unused variable 'pServer'
BLEServer *pServer = BLEDevice::createServer(); // <-- no longer required to instantiate BLEServer, less flash and ram usage
After commenting out that line it compiled without error.
Maybe some library is not compatible with the S2 version of the processor? I tried to compile for "Adafruit Feather ESP32-S2" and got a bunch of errors with undefined variables, starting with:
libraries/BLE/src/BLEBeacon.h:33:2:
error: 'BLEUUID' does not name a type
BLEUUID getProximityUUID();
In file included from C:\Users\andre\Documents\Arduino\libraries\ESP32_BLE_Arduino\src/BLEAdvertising.h:15,
from C:\Users\andre\Documents\Arduino\libraries\ESP32_BLE_Arduino\src/BLEServer.h:19,
from C:\Users\andre\Documents\Arduino\libraries\ESP32_BLE_Arduino\src/BLEDevice.h:18,
from D:\BLE_iBeacon\BLE_iBeacon.ino:2:
C:\Users\andre\Documents\Arduino\libraries\ESP32_BLE_Arduino\src/FreeRTOS.h:61:28: error: 'ringbuf_type_t' has not been declared
Ringbuffer(size_t length, ringbuf_type_t type = RINGBUF_TYPE_NOSPLIT);
Multiple libraries were found for "BLEDevice.h"
Used: C:\Users\andre\Documents\Arduino\libraries\ESP32_BLE_Arduino
Not used: C:\Users\andre\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.5\libraries\BLE
exit status 1
Error compiling for board ESP32 Dev Module.
What's even more strange is that it seems that if I monitor it in room-assistant, the id changes a bit
Summary
12/15/2022, 10:53:09 PM - error - BluetoothService: Failed to start advertising instance via BLE: Command Disallowed
12/15/2022, 10:53:19 PM - error - BluetoothService: Failed to start advertising instance via BLE: Command Disallowed
12/15/2022, 10:53:22 PM - info - BluetoothLowEnergyService: Discovered nearby BLE peripheral ESP32 as iBeacon with ID 644f76f76a5242bce911fd902c9bb987-0-2 and RSSI -65
12/15/2022, 10:53:30 PM - error - BluetoothService: Failed to start advertising instance via BLE: Command Disallowed
12/15/2022, 10:53:33 PM - info - BluetoothLowEnergyService: Discovered nearby BLE peripheral ESP32 as iBeacon with ID 644f76f76a5242bce911fd902c9bb987-0-3 and RSSI -68
12/15/2022, 10:53:40 PM - error - BluetoothService: Failed to start advertising instance via BLE: Command Disallowed
12/15/2022, 10:53:44 PM - info - BluetoothLowEnergyService: Discovered nearby BLE peripheral ESP32 as iBeacon with ID 644f76f76a5242bce911fd902c9bb987-0-4 and RSSI -70
12/15/2022, 10:53:51 PM - error - BluetoothService: Failed to start advertising instance via BLE: Command Disallowed
12/15/2022, 10:53:55 PM - info - BluetoothLowEnergyService: Discovered nearby BLE peripheral ESP32 as iBeacon with ID 644f76f76a5242bce911fd902c9bb987-0-5 and RSSI -69
12/15/2022, 10:54:01 PM - error - BluetoothService: Failed to start advertising instance via BLE: Command Disallowed
12/15/2022, 10:54:05 PM - info - BluetoothLowEnergyService: Discovered nearby BLE peripheral ESP32 as iBeacon with ID 644f76f76a5242bce911fd902c9bb987-0-6 and RSSI -67
12/15/2022, 10:54:12 PM - error - BluetoothService: Failed to start advertising instance via BLE: Command Disallowed
12/15/2022, 10:54:16 PM - info - BluetoothLowEnergyService: Discovered nearby BLE peripheral ESP32 as iBeacon with ID 644f76f76a5242bce911fd902c9bb987-0-7 and RSSI -67
12/15/2022, 10:54:22 PM - error - BluetoothService: Failed to start advertising instance via BLE: Command Disallowed
12/15/2022, 10:54:27 PM - info - BluetoothLowEnergyService: Discovered nearby BLE peripheral ESP32 as iBeacon with ID 644f76f76a5242bce911fd902c9bb987-0-8 and RSSI -70
No clue why, but at least it partially works. Thank you for the help.
