make Arduino act as EEPROM
hi everyone, i'm trying to power a gopro hero3 through the bus connector, so i need Arduino to act as a simple eeprom. In this case i need to write value 9 to address 0 of eeprom so that the camera recognises arduino as a valid accessory.
http://www.benthicscience.com/beta/products/custom-builds/gopro-hero3-bus-access
how can i make Arduino act as an eeprom so that each time the gopro reads the bus Arduino returns the requested value?
thank a lot
A single byte addressable EEPROM is possible. But since the Arduino uses a software library, it sometimes stretches the clock. If the Master is not capable to do that, the Arduino will not work.
http://arduino.cc/en/Tutorial/MasterReader http://arduino.cc/en/Tutorial/MasterWriter
The Arduino should use the onRequest and onReceive handlers. The onRequest for EEPROM data, the onReceive to receive the address byte.
The Arduino as I2C Slave does not know how many bytes are read by the Master with onRequest. So you do not know how much the address byte should be incrementend. That is not implemented in the library.
So what do you think is wrong with this code
#include <Wire.h>
#include <EEPROM.h>
  EEPROM.write(0,9); //Write 0x09 at address 0 of the eeprom
  Wire.begin(0);     //Join I2C bus with address 0
  Wire.onRequest(requestEvent); // register Event
void requestEvent()
  Wire.write(EEPROM.read(0));
The I2C address is the address of the I2C device. The EEPROM register address selecting is the address inside the EEPROM. It is written to the EEPROM before data is read.
I2C address '0' is reserved. You have to find the I2C address of the original EEPROM, and use that for Wire.begin.
You sketch also needs the onReive, to receive the single byte register address.
what do you mean for ''address of the original EEPROM"?
The "I2C address of the original EEPROM".
Every Slave on a I2C bus had an address. The Wire.begin( slave_address) use a 7-bit address. http://arduino.cc/en/Reference/WireBegin
In the link they mention the "Microchip 24AA0", I think the I2C address for that chip is 0x50 to 0x57.
If you want to emulate that chip, you have to start with: Wire.begin( 0x50); However, if address 0x51 ... 0x57 is used, you can't emulate the other I2C addresses.
#include <Wire.h>
  Wire.begin(0x50);     //Join I2C bus with address 0x50
  Wire.onRequest(requestEvent); // register requestEvent
  Wire.onReceive(receiveEvent); // register receiveEvent
void requestEvent()
  Serial.println("requestEvent");
void receiveEvent(int howMany)
    Serial.println("receiveEvent");
    Wire.write(0x09); //is it OK???
so the code should be like this?
p.s. Wire.onRequest() and WIre.onReceive() are ok in the loop or should they be in the setup???
They are registering event handlers. That needs to be done once.
As PaulS wrote, they need to be in setup().
You write a message with Serial.println() from requestEvent() and receiveEvent(). That might not work at all, or just once. Since those function are interrupt handlers, it might (it will) cause a conflict with the interrupt driven Serial library. So you need extra code to work around that.
Make a global variable: volatile boolean flagRequest;
Set it 'true' in the requestEven().
Check in the loop if it is 'true', set it to 'false' and write a message with Serial.println().
#include <Wire.h>
volatile boolean RequestArrived, receiveCalled;
  RequestArrived = false;
  receiveCalled = false;
  Wire.begin(0x50);
  if(receiveCalled)
    char c = Wire.read();
    Serial.print("received ");
    Serial.println(byte(c));
  if(RequestArrived)
    Serial.println("request");
void requestEvent()
  RequestArrived = true;
  receiveCalled = true;
from your suggestions i wrote this code that is supposed to be working fine, but it never reaches the request. it only calls the receiveEvent.
i even trid to change the bitrate of the I2C bus from 100KHz to 400KHz but the result is always the same. do you think it could be a clock problem?
i noticed even another fact: if my Arduino UNO slaves triggers the receiveEvent at least, if use the same code with an Arduino DUE i do NOT have any response, any idea? Moreover GoPro Hero3 works at 3V3 so i should expect the opposite, shouldn't i?
The way you use the flags is good. However, the Wire.read() should be in the receiveEvent(), I don't know if that buffer is still valid after the receiveEvent() has finished. I think not.
Just add a few global volatile variables:
volatile int receiveHowMany;
volatile int receiveData;
Fill them in the receiveEvent() and print them in the loop().
Perhaps you can also try I2C address 0x50 up to 0x57, and see what the other I2C addresses do.
I don't know why the Due has a different response. But timing and clock stretching has always been a problem when using an Arduino as I2C Slave. If the GoPro doesn't support it, only hardware EEPROM chips can be used.
thanks for your support. But my problem is that i do not have any response from the request event, the receive seems to be OK yet.
It starts with the receive, that is why I want to know what is received.
For an EEPROM, first the address (for the location inside the EEPROM) is send. That is what you receive. I assume you receive a single byte of ‘0x00’. After that the EEPROM is read or written to the location that just has been send.
OK, in my case i have receive 0x00 with the receive event but then nothing happens
Okay, the problem is clear.
There are still a few bugs in the Wire library. But in this case I think it has to do with the Arduino delaying the I2C bus by stretching the clock pulse. A hardware chip does not do that.
A few week ago, someone had a Master, which was a microcontroller with a software I2C (pin toggle I2C). That software did not implement the clock stretching.
If the GoPro uses a hardware I2C, it might implement it, but also the software has to take care of it.
So I'm sorry, but my conclusion it that it probably will not work. Can you do something totally different ? Using a hardware EEPROM chip, and fill it somehow with the Arduino and let the GoPro read it.
